Air Bag Light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Brian9191, Oct 1, 2020.
  1. Oct 1, 2020 at 10:14 AM
    Brian9191
    Brian9191 [OP] New Member
    Brian
    2006 Toyota Tacoma Base 4x4 5 Speed Manual Trans
    None
    Ok troops, I have a 2006 4 banger taco 5 speed manual base. So my airbag light is on. I have done some research. From what I have read, its either the clock spring, or the sensor on the bumper. Now, so my question is this, how many of you replaced the sensor and that took care of the problem? I know a sensor is around $100 and a clock spring is around $250 to $300.
  2. Oct 1, 2020 at 10:28 AM
    Cb Colorado
    Cb Colorado Active Member
    Black 2008 Tacoma SR5
    OME 885 Bilstein 5100 front and rear RCI Rock Sliders 285/70/17 BFG KO2
    From what i've seen there is a recall on the clock spring from Toyota, double check to see if you are on that. I was but im not sure if being a second owner can qualify for these recalls?
  3. Oct 1, 2020 at 11:48 AM
    Brian9191
    Brian
    None
    Ok thanks.
  4. Oct 1, 2020 at 12:13 PM
    Brian9191
    Brian
    None
    Update. Called the dealership and was advised the clock spring was replaced in 2013. I was advised, it would cost $100 for a scan and to diagnostic the problem. All that just to tell me what needs replaced lol. So, it could be the passenger side air bag, seat belt buckles or the bumper sensors. I have more research to conduct.
