air bag removal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Badbud, Jun 11, 2011.
  1. Jun 11, 2011 at 10:04 PM
    Badbud
    Badbud [OP] Member
    BUD
    Alanta ga
    2007 prerunner
    How do you remove the drivers side air bag on a 2007?
  2. Jun 11, 2011 at 10:08 PM
    TacomaBuzz
    TacomaBuzz Well-Known Member
    CT
    2014 RegCab 4x4 TX Special Edition
    Sirius, Bugflector,back-rack, stepsides.
    Front end collision:notsure:
    Haha, just kidding do a search, it's been done . You planning on removing it temporary or permanent??
  3. Jun 11, 2011 at 10:10 PM
    Badbud
    Badbud [OP] Member
    BUD
    Alanta ga
    2007 prerunner
    Got to replace the clockspring, Air bag lights on
  4. Jun 11, 2011 at 10:14 PM
    Jerry Bear
    Jerry Bear Well-Known Member
    Jerry
    Mesquite, Texas
    2010 Access Cab
    tint, topper, receiver hitch, trailer wiring, topper lighting, cruise control, intermittent wipers, backup camera, auto-dim mirror
    Assuming that you are talking about the air bag in the steering wheel, not the one in the roof or the seat:
    Pop out the cover on each side of the steering wheel. Loosen the exposed T-30 Torx screw. The screw is held by a small plastic piece so that it doesn't fall out. Don't remove it, just loosen it until it just hangs there.
    Pull the center of the steering wheel straight out.
    Be sure to take all appropriate precautions for handling an explosive device.
  5. Jun 11, 2011 at 10:45 PM
    Badbud
    Badbud [OP] Member
    BUD
    Alanta ga
    2007 prerunner
    Sounds like you have done this before, thanks
