Air bag sensor corroded, dealer wants to change entire harness, $2700
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pierrefonds, Jul 2, 2015.
  1. Jul 2, 2015 at 3:33 PM
    Pierrefonds
    Pierrefonds [OP] Member
    Dan
    Montreal, Canada
    Tacoma SR5
    none so far, just bought the truck 3 days ago...
    Hello, the driver side air bag connector is apparently corroded and the dealer wants to change the entire harness. $2700 plus installation. Has anyone ever cleaned a connector and if so how do I proceed?
    Thanks!
  2. Jul 2, 2015 at 3:35 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Uh. warranty?
  3. Jul 2, 2015 at 3:35 PM
    Jefes Taco
    Jefes Taco Well-Known Member
    Denver, CO
    14' DCLB TRD Sport supercharged
    What year? What are the Federal Safety laws concerning airbags in Canada?
  4. Jul 2, 2015 at 3:38 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    You can buy the connectors from: myairbags.com
    As long as we are talking about the steering wheel air bag connectors.
  5. Jul 2, 2015 at 3:38 PM
    VolcomTacoma
    Jeff
    NorCal
    I think they mean the sensors....pretty sure you can buy just the sensors as well. I'd check your own wiring and see if its corroded or not
  6. Jul 2, 2015 at 3:40 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    As for your next step. If you can get away with cleaning them do it with a little pick style brush and from that point apply a liberal amount of dielectric great inside of them. That problem will never happen again.
  7. Jul 2, 2015 at 3:48 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    SRS warranty is 5 years / 100,000 km in Canada, a hair longer than in the US (60,000 mi). Pierrefonds may or may not be covered depending on when the truck was put in service and current milage.
  8. Jul 2, 2015 at 4:12 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Buy a spray can of Deoxit. Disconnect the connector spray both connections plug it back in, done.
  9. Jul 2, 2015 at 4:55 PM
    tasnowma
    tasnowma Well-Known Member
    David
    MA
    06’ DCSB SPORT. 16’ DCLB SPORT. 14’ DCLB SPORT
    Premium tech package with JBL, 2" Rough Country lift, 265/70/17 BFG Rugged Terrains, AVS in-channel rain guards, all weather floor mats, bed mat...
    Are you talking about 1 of the 2 front bumper air bag sensors? If so...
    My abs light came on about a year ago. I checked the code and got a faulty driver side front air bag sensor. Switched the sensor to the passenger side and checked the code again... The code then switched to the passenger side. That explained it! Faulty sensor. Bought one on eBay for $40 and all was good. $40 compared to what? $2700? Dealers are absolute thieves.
    However! My abs light came on again recently and its throwing the code for the same sensor. Looks like I'm gonna have to pull it out and clean, scrape, grease it up as suggested in this thread. Hopefully I can get it to last a few more months til I trade it in. Good luck!
  10. Jul 2, 2015 at 4:55 PM
    tasnowma
    David
    MA
    How well does this actually work?
    whoareyou133 likes this.
  11. Jul 2, 2015 at 5:54 PM
    Pierrefonds
    Dan
    Montreal, Canada
    Tacoma SR5
    Thanks for the replies. 2010 US truck brought to Canada, not under warranty even after filing a dispute with Toyota. Dealer claims it is driver side front sensor, just behind the bumper, connector is corroded. Local garage is worried cleaning the connector will set off the airbags when the battery is reconnected.
  12. Jul 2, 2015 at 6:03 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Discount the battery, discharge the system, clean the connector yourself, plug it back in, double check the connection, check it again, reconnect battery, done deal.
    Try not to set off your airbags.
    CanadaToy likes this.
  13. Jul 2, 2015 at 6:16 PM
    tasnowma
    David
    MA
    Can't win with these goons! I sure as hell WOULD NOT pay $2700 out of pocket to fix it. I dealt with this pretty extensively about a year ago when I did mine. Here's what you gotta do...
    Do you know how to do the little jumper wire in your OBD? To get codes and whatnot? Do some research on that... it's very helpful and you can do it from home.
    Get a couple free hours to work on your truck
    Unplug the battery for a good 10 mins before doing any kind of ABS work
    Unhook the harness from the driver side sensor and check for corrosion
    Remove 2 sensor 10mm bolts
    Check sensor and harness... If you have green bullshit on there, scrape, clean and apply that Deoxit shit like ^he said.
    Refasten sensor, reconnect harness... reconnect battery.
    Turn truck on...
    If that doesn't relieve the ABS light... switch the driver side sensor with the passenger side sensor (ALWAYS UNPLUG BATTERY BEFORE POKING AT THESE THINGS)
    Check the OBD code... if it switches to the passenger side being faulty, you know you just have a faulty sensor. They are on ebay right now for $75.
    Try to fix them, try to switch them, if that fails, replace. 2 bolts and a harness.. easy peasy!
    If this fails and your harness is completely shot, well then you're screwed. Personally, I still wouldn't take it to them... I'd find a junk yard and yank the harness and wires out of the truck and replace mine with it. The absolute last thing I would do is pay someone $2700 to fix it. That is absolutely ludicrous. Good luck bro.
  14. Jul 3, 2015 at 4:36 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    That is what it was designed for it does not do any thing else it works amazingly well on some pretty nasty connections especially on small connections that are hard to get to as I assume the OP is dealing with. I have used this stuff for years on all things electronic I don't know what's in it but it does leave a slightly oily protective film. Be advised it's not cheap you don't get a lot but it goes a long way. Some auto parts stores carry it but most will give you a dumb look if there is an electrical parts outfit around they will have it
  15. Jul 3, 2015 at 4:59 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    They have to be powered to deploy. If that was the case when ever you replaced a battery you would set off the air bags. As far as the sensor being corroded with out looking at it it's just a guess maybe it's some thing they have seen before either way in their case repairing some thing like that could result in a huge liability on their part.
  16. Jul 3, 2015 at 8:31 AM
    BALL
    BALL Blackened is the end
    2015 Tacoma SR DCSB 4x4
    Is it the sensor or the wire harness connection? Sensors are easily replaced. Wire harness abs connections should not be replaced. You then would need a new w/h.
  17. Jul 4, 2015 at 6:21 AM
    Old_Skool
    Old_Skool Well-Known Member
    Rich
    Maine
    2017 Subaru WRX, Crystal Black Silica
    ABS = Anti-Lock Brake System
    SRS = Supplemental Restraint System (ie. Airbags)
    OP.... Disconnect the battery then take some muriatic acid and swab it in the connector contacts with a q-tip. Rinse with water and repeat if necessary. Follow up with dielectric grease and reinstall.
  18. Jul 4, 2015 at 8:06 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Muriatic acid will attack the copper.
  19. Jul 4, 2015 at 9:17 AM
    BALL
    I
    I meant airbags. I know the difference, I build Toyotas. And I know that Toyota or the "SRS" manufacturer will not replace a connection on those ends. They will replace the harness every time.
  20. Jul 4, 2015 at 10:40 AM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Bad info right there, regardless of how well you think it's rinsed off.
