air bag sensor...where do i get one and how do i replace it
Discussion in 'Technical Chat' started by tacojack, Jul 29, 2011.
  1. Jul 29, 2011 at 6:22 AM
    tacojack
    tacojack [OP] Member
    chris
    new york
    trd sport 4x4 indigo ink
    Bilstein 5100 front set at 2 1/2" , 1" blocks in rear with Firestone air bags
    i have a 2007 taco 4x4 double cab. the criminals at toyota want to charge me $400.00 just for the sensor plus install. does anybody know where i can order one cheaper and how do i install it? toyota told me it was the sensor located in the front left fender. any help would be awesome! thanks tacojack
  2. Dec 20, 2012 at 11:28 AM
    4x4 Taco
    4x4 Taco Off-road Enthusiast
    Pensacola
    4x4 TRD Sport DCLB
    Heated Leather Seats, Train Horn, Hood Struts
    I found that when looking for info on an air bag issue I have.
  3. Dec 21, 2012 at 6:15 AM
    tacojack
    chris
    new york
    Thanks for the info. I will check it out when the holidays are over. Thanks again merry christmas
  4. Dec 21, 2012 at 6:36 AM
    BamaToy1997
    BamaToy1997 ASE Master Tech
    Bill
    Navarre, FL
    Multi-point tow hooks, new bored 2.7L engine, custom paint. 3 inch adjustable Fabtech front coils, 2.5 inch rear AAL. Front Aussie locker. LED bed lights. Full LED conversion interior and exterior. Relentless Fabrication front and rear bumpers. 4X4innovation sliders. BAMF bed rack. CVT rooftop tent.
    Would you mind posting some more information on the sensor in question? You have several sensors and I would not be comfortable without clarifying that you need to be 100% POSITIVE what part you are replacing when it comes to SRS components.
    Do you have a copy of the estimate with a part number on it? that would be best. Then we can go from there to help you locate the correct part.
    According to my system here, if it IS a front sensor, then the labor time charged should have been no more that 1.5 hours total (including diagnostics) plus the price of the part, as well as taxes and typical shop fees. In New York the labor rate I have found is approximately $92 per hour. The sensor (if it is the one I am thinking) is about $80. This would add up to about $225 before any other fees. I know a lot of people think the dealerships are a bunch of crooks, but I have worked for dealerships for over 20 years, and I find that this is not generally true. Do they charge more than an independent? Yes, but their factory trained techs are better trained on your specific vehicle than most of your independent shops. (And I OWN an independent shop, so no, I am not trying to be biased towards dealerships) THIS is what you are paying for in some cases.
    If their estimate was for $400, then I would love to review their estimate to see where the additional $175 comes from. Perhaps the estimate included something that was not mentioned?
  5. Dec 21, 2012 at 7:20 AM
    Tacoma Mike
    Tacoma Mike 44 Year Toyota Master/ASE Master Tech.
    Southern Maine
    2011 Double Cab V6
    Large Storage Box, 02610 intermittent switch swap, "Hot Wire" Power Outlets, DRL Shut Off, Disable Fob Beep, Disable Seat Belt Buzzers, Parking Light Mod, Battery Tender, 4 Leaf Spring Pack, Rear Headrest Removal, Custom Ultragauge Mount, Factory Tow Package (7 Pin) Rear Diff Mod, Taco Lean Mod
    That does sound kinda hi to me also Bill. Your Labor time is right unless there is something else going on. I'm curious also.
  6. Dec 22, 2012 at 7:09 AM
    tacojack
    chris
    new york
    I do not have the estimate with me at this time. The sensor the dealer said was bad was the driver side front air bag sensor. Not sure how it was broken down into cost. But when they told me it would be $400 to replace the sensor I thought that was a lot of $$$$. Actually anytime I go to my Toyota dealer their prices always make me say hhmmmm. I am not a big fan of going to the dealer, that's why I try to do most of the work myself if I can, within reason. If I find the actual estimate I will let you know. Sorry I couldn't get the info you needed at this time. Thanks for your reply.
