Air Bag Warning Lights
Discussion in '1st Gen. Tacomas (1995-2004)' started by green, Aug 4, 2009.
  1. Aug 4, 2009 at 2:04 PM
    green
    green [OP] New Member
    Hi, I rescently had my oil changed and shortly after realised that my air bag warning lights were flashing. I'm worried because of the possibility that my airbags might have been stolen. I'm kind of lacking in knowledge of these things; is there any way to check if they did steal my air bags?
  2. Aug 4, 2009 at 7:06 PM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    What year / model Tacoma?
    Was any other work done on it while it was being serviced?
    You mentioned 'lights' (plural) ... Exactly what 'lights' are flashing?
  3. Aug 8, 2013 at 9:56 AM
    Jmark55
    Jmark55 Member
    Georgia
    04 TRO 2 WD
    My 2004 Tacoma had the air bag warning light on for several months and I finally went to the Toyota dealer to get it checked out. They said the Spiral Cable Assembly needed to be replaced, so I authorized that work.
    Not long after I left the dealer, the light came back on. So I returned to the dealer where all the technicians went through their manual, and short of replacing the entire air bag assembly ($1600!), finally got the light off.
    The air bag warning light stayed off for a couple of months but now is back on again. I think I will have to live with it since they indicated that replacing the air bag assembly is to only thing left to correct the problem.
    My only other thought is to try another dealer or specialty repair shop and see if they have a different perspective on the problem.
    Does anyone have some experience with this issue?
    Mark in Atlanta
  4. Aug 8, 2013 at 3:22 PM
    TejasYOTA
    TejasYOTA Countinuous improvement
    Nathan
    Country of TEXAS!
    "WOOKIE" 01 Tacoma DC TRD Limited 4WD
    Check the TTORA Garage Section....
    Check the connections to the actual sensors (driver & passenger side) on the wheel well up front.
    The driver one is under the battery, the passenger near the air box.
    Before removing the connections, unclamp the battery.
    That "Spiral spring" is called a clock spring.
  5. Aug 8, 2013 at 6:58 PM
    ethanfoy
    ethanfoy Well-Known Member
    ethan
    Little Rock AFB
    99 toyota tacoma xcab 4x4
    let the truck sit without the battery cables hooked up for 15mins
  6. Aug 8, 2013 at 7:06 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    I know this is in the first gen section but if your truck is 05 and up there was a recall on the spiral cable/ clock spring and the dealer will fix it for free
  7. Aug 9, 2013 at 6:31 AM
    Jmark55
    Jmark55 Member
    Georgia
    04 TRO 2 WD
    Thanks for all the suggestions. I will give them a try.
