AIR BAGS = AWESOME!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MagneticTaco79, Jul 12, 2014.
  1. Jul 14, 2014 at 7:57 AM
    MagneticTaco79
    MagneticTaco79 [OP] COLD ASS HONKY
    AARON
    WV
    Mag Grey 2012 Tacoma AC TRD Sport 4x4
    ALL KINDS OF SHIT
    BF Goodrich AT KO's
    265/70 R17
  2. Jul 14, 2014 at 8:56 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    i would suggest to NOT do this as it would promote body roll as it is essentially the opposite of a sway bar. (when the outside airbag is compressed via body roll the pressure increases expanding the inside one... opposite of what you want.)
    ROlla-Xrs likes this.
  3. Jul 14, 2014 at 9:50 AM
    MagneticTaco79
    AARON
    WV
    ALL KINDS OF SHIT
    ^^^^^^ This exactly. That being said large trucks are valved in a way that air does not shift back and forth from bag to bag. I guess a guy could find him a T with some type of one way/check valve he could pull it off safely.
  4. Jul 14, 2014 at 10:05 AM
    thebaker
    thebaker Well-Known Member
    Byron
    NorCal
    Upgraded to a 3rd gen
    Never ending......$$$
    Has anyone installed this on deaver j66 leaf pack? That's what i'm running and I love them but they don't carry much weight at all. If not, I guess I will be the first!!!!!
  5. Jul 14, 2014 at 10:08 AM
    MagneticTaco79
    AARON
    WV
    ALL KINDS OF SHIT
    If your leaf pack isn't as strong as you want it under a load than you can't go wrong with these. No matter what type of leaves your running. Air them down when your not loaded and you won't even know their there.
  6. Jul 14, 2014 at 10:43 AM
    DEagle
    DEagle New Member
    Don
    Wrightwood, Ca
    2010 4x4 SR5
    My Firestone air bags work great giving me the extra support needed to haul my Four Wheel Camper. Contrary to another post, I use a separate line for each bag so I can level the load (my Four Wheel Camper is heavier on the driver side) which significantly improves handling.
  7. Jul 14, 2014 at 12:47 PM
    ssanders2211
    ssanders2211 Well-Known Member
    Midwest
    '14 DCLB 4x4
    behind the rear seat hi-lift mount bracket, easy-out crossbed toolbox brackets, sliders, ATO plate rear bumper, hood/bed lighting, always-on 12v outlets, dashcam, Viper 5806V w/ GPS
    I want to get these eventually for occasional hauling but I don't want to put in a lift. Is that doable?
    I haven't had it 6 months and I've already overloaded it 3 times.
  8. Jul 14, 2014 at 1:01 PM
    13SilverStreakTRD
    13SilverStreakTRD Insane but Functional
    Republic of Texas
    2013 DCSB TRD OR
    tinted windows, window visors, stubby antenna, wethertech floor liners, dented tailgate
    So is there a kit that already has the Firestones and Daystar cradles together or did you have to get the Daystar cradles separately?
  9. Jul 14, 2014 at 1:12 PM
    thebaker
    Byron
    NorCal
    Daystar cradles are sold separate.
  10. Jul 14, 2014 at 1:13 PM
    muddog67
    muddog67 Well-Known Member
    So I was wondering , when you have air bags on a 4WD , Can you do major flexing with airbags ? I would think that the air bag would tear from flex and strain .
  11. Jul 14, 2014 at 1:16 PM
    thebaker
    Byron
    NorCal
    That's what the daystar cradle is for. The bottom of the airbag isn't connected to the truck. It floats with enough flex and lands in the cradle during normal operation. Search daystar cradle on TW and many threads have pics of how it works.
  12. Jul 14, 2014 at 2:12 PM
    boomer6
    boomer6 Well-Known Member
    TN
    Tacoma TRD Offroad
    disabled DRLs disabled seat belt chime disabled the key in the ignition with door open buzzer Installed Illuminated 4wd switch circuit board Marker lights Flashing with turn signals Toggle switch ABS Disable Fog Lights on AnyTime Mod Changed to Yellow bulbs in the Fog Lights Converted interior lights to leds Installed oem roof rack Installed Firestone Ride Rite Air Bags and Daystar Cradles for the air bags Added oil catch can Relentless Tailgate Protector installed
    With the Daystar Cradles , your suspension retains the full range of motion for off roading. The best of both worlds (heavy hauling and off roading )when you run the Firestone air bags with the Daystar cradles. Also when putting your vehicle on a lift for a shop to work on it , If you have just the airbags you need to take all the air out of them and then add the min. of 5 pounds of air after its off the lift. Not so anymore , if running the Daystar Cradles with the airbags.
  13. Jul 14, 2014 at 2:27 PM
    MagneticTaco79
    AARON
    WV
    ALL KINDS OF SHIT
    Absolutely! No lift required. They work with stock suspension perfectly.
  14. Jul 14, 2014 at 9:09 PM
    parkp81
    parkp81 Well-Known Member
    Fil
    Southern California
    So in regards to the 5psi minimum I see "boomer6" post and if I read it correctly you don't need to maintain the 5psi in each bag with these cradles?
    When you do have 5psi how much does it raise the rear with no load?
    I've heard it is rough with 5psi with no load in the rear is that true?
  15. Jul 15, 2014 at 3:58 AM
    #35
    boomer6
    TN
    Tacoma TRD Offroad
    PARKP81.....You still need to run the 5 psi min. Firestone says if you put your vehicle on a lift you need to remove all of the air and then when done to put min of 5 psi back in. With just the air bags .....the bags are bolted top and bottom. Now IF you run Daystar Cradles with the airbags, The bags are only bolted on top and float freely in the cradle on the bottom. ........ So with 5psi min. or what ever air you have in the bag......you dont need to remove all the air anymore if putting your vehicle on a lift. Hope this explains it a little better.
    I run 8psi and I think its like a factory ride with no load , but thats just my feeling.
  16. Jul 15, 2014 at 4:15 AM
    #36
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    We'll see how the regular cab rides with the less than 5k oem 4 leaf packs I have on the way but see these as a good way to go if I do end up going with a shell and camping setup inside it and need more. Good info here..........
  17. Jul 15, 2014 at 4:16 AM
    #37
    MagneticTaco79
    AARON
    WV
    ALL KINDS OF SHIT
    At 5psi it probably dosent even give me 1/2" of lift. Now this will vary on all trucks, depending on lift (type of leaf springs, blocks etc). Who ever told you they ride rough is full of it. I have bee running 20 in mine since the install, i have factory TSB springs and 1" blocks. Mine has a little bit of spring to it that is more comfortable to me than it was stock. There is no rocking back and forth any more, they even makes the truck feel better under acceleration and braking.
  18. Jul 15, 2014 at 4:17 AM
    #38
    MagneticTaco79
    AARON
    WV
    ALL KINDS OF SHIT
    Yes they would be great for a topper and camping setup in the back. You would love the adjust ability.
  19. Jul 15, 2014 at 6:06 AM
    #39
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    Confirmed ... I'm completely stock and have had mine installed a little over 3 yrs. bought my truck used and missed the 36 mos deadline for TSB springs by a few weeks. The bags are my interim cure. Eventually I'll install a heavier leafpack (maybe Dakar).
    I run 10 PSI and it's a little stiffer than factory, but carries my typical loads without needing to adjust the bags often. I seldom carry more load than the 10 PSI handles.
  20. Jul 15, 2014 at 6:21 AM
    #40
    ssanders2211
    Midwest
    '14 DCLB 4x4
    Awesome, thanks! I saw everybody talking about how it added an inch or so to the back so I wasn't sure if it would mess up the truck's profile if I didn't lift the front to compensate.
