AIR BAGS = AWESOME!!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MagneticTaco79, Jul 12, 2014.
  1. Apr 13, 2015 at 9:03 AM
    #161
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
  2. Apr 13, 2015 at 9:36 AM
    #162
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    nope
  3. Apr 13, 2015 at 11:47 AM
    #163
    Rx7turbo2
    Rx7turbo2 Well-Known Member
    Canada
    2020 TRD OR DCSB (Current) 2005 TRD OR DCSB (Sold)
    Nope
  4. Apr 18, 2015 at 6:50 PM
    #164
    Notoneiota
    Notoneiota Claud Bawls molested my cat.
    Oakdale & Grand Rapids, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    Installed some Firestone air bags today. Highly recommend it. I intend to start hauling a couple motorcycles in the bed so I figured they'd help. Just driving empty the truck has a much smoother ride. I don't feel the little jiggles and bumps like I used to. Ride is much less "truck" like.
  5. Apr 18, 2015 at 7:09 PM
    #165
    lobsterbait
    lobsterbait The Wall
    Not Paul
    Parker CO
    Goose
    Just a couple things
    Ive had my Firestone bags installed for 6 months now with daystar cradles. Originally installed in anticipation of towing all my life possessions across country upon getting out of the military. I towed 4000 pounds in the trailer with five 33 Inch Toyo Mud Terrains in the back without squatting and with no issues. Really helped out a lot. I had my street shoes on for the trip.
  6. Apr 18, 2015 at 7:17 PM
    #166
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
    Whats the most weight you guys have put in the rear with the air bags?
  7. Apr 18, 2015 at 7:31 PM
    #167
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    Don't answer this. The payload nazis are lurking... :D
  8. Apr 18, 2015 at 7:48 PM
    #168
    maxpower29
    Jordan
    Nova Scotia, Canada
    I dont mean jamming as much weight you can, I mean hitting the payload and feeling confident really. I like knowing what people tow because my taller 900lb ATV is different then a bunch of dirt etc
  9. Apr 18, 2015 at 7:51 PM
    #169
    NotRed
    NotRed Well-Known Member
    Jimbow
    Tennessee
    Here's where I mounted my fill valves. I put them under the license plate lights with the hope that being there will protect them from my boot toes when climbing in and out of the bed.
  10. Apr 18, 2015 at 7:56 PM
    #170
    maxpower29
    Jordan
    Nova Scotia, Canada
    dumb question but what do you guys use to fill the bags? Just a hand pump? Must not take long to fill though
  11. Apr 18, 2015 at 7:59 PM
    #171
    CASTRATE
    CASTRATE Well-Known Member
    Gabe
    SW of Tulsa, OK
    2012 4x4 SR5 6spd
    Dammit I need to do this
  12. Apr 18, 2015 at 8:08 PM
    #172
    lobsterbait
    Not Paul
    Parker CO
    Goose
    Like I said earlier on I towed a trailer with 4000 pounds in it from San Diego to PA and it rode real nice. Totally felt normal.
    along with that I used a portable air compressor from Home Depot http://m.homedepot.com/p/Husky-120-Volt-Inflator-HY120/202871788/
    Furthermore a lot of people have had issues with leaks. And I just checked mine after about 2 months without checking and it was still the same with no air loss.
  13. Apr 18, 2015 at 8:10 PM
    #173
    NotRed
    Jimbow
    Tennessee
    I keep one of those little 12v compressors in the rear door pocket of my Access Cab and use that for adjusting the bags and tires both. Did have to get a 12v extension cord to reach the rear bumper but that was less than $10.
  14. Apr 18, 2015 at 8:13 PM
    #174
    Notoneiota
    No lie. I went to pressurize mine today after install and used my shop compressor at 90 psi. One quick trigger pull and they were at 20+ psi. I basically has to hit 'em with a quick burst and then let air out to equalize them.
  15. Apr 19, 2015 at 7:31 AM
    #175
    DJB1
    Dave
    SLC, UT
    I did six round trips with 1500 lbs of pea gravel each trip. I put 40 PSI in the driver's side and 30 PSI in the passenger's side. Rode great and didn't bottom out even going over speed bumps.
    I use a small aluminum bike pump that fits in the glovebox. From 0 PSI to 30 is about 15 pumps per bag. I usually leave the driver's side at 15 PSI and the passenger side at 10. Maybe once every 3 months I have to add a couple pumps. If you use good-quality pipe dope on your fittings you won't have to mess with your PSI much.
  16. Apr 19, 2015 at 9:31 AM
    #176
    maxpower29
    Jordan
    Nova Scotia, Canada
    Thanks for the answers guys, ordering them tomorrow.
  17. Apr 19, 2015 at 11:29 PM
    #177
    Loco38SUP
    Loco38SUP Well-Known Member
    North Seattle, WA
    2011 Double Cab SR5 4X4
    Loud as hell URD exhaust!
    I installed my air bags today. The install time was about 4 hours. I didn't have access to a sawzall so removing those bump stops took some time. Also the 4 bolts that mount to the arched brackets are a pain to tighten. The overall install wasn't bad just time consuming.
    The ride is much better than before. The rear of the truck feels firm but not harsh. I pumped them up to 25 psi just for fun and it still wasn't bad. I'm going to run them at 8 psi for a few weeks and go from there.
    My truck has always had the "Bro" stance since I upgraded the suspension but now it's slightly above level. I was considering going to a firmer leaf pack to get rid of the sag but I'm glad I went this way instead. These things are pretty slick.
    RJM
  18. Apr 19, 2015 at 11:34 PM
    #178
    Chopper678
    Chopper678 Professional Threadjacker
    Devin
    Texas
    '07 SR5 PreRunner V6 DCSB
    5100s@0.85"+Eibachs, Toytec 2" AAL, Weathertech floor liners, WO seat covers, UltraGauge, ammo box mod
    If I wanted a few inches of rear lift leaf springs with a nice ride, but didn't want to deal with bro lean when hauling, would buying both the leaves and these airbags be a win-win solution preventing me from buying stiff springs? Thanks and sorry if this has been discussed.
  19. Apr 20, 2015 at 6:00 AM
    #179
    maxpower29
    Jordan
    Nova Scotia, Canada
    I already have the 5th leaf, so i dont bro lean, but when i tow I do. Thats why im getting the bags. So I would say yes get both, but I have no clue what its like with just the bags?
  20. Apr 20, 2015 at 8:01 AM
    #180
    Jefes Taco
    Jefes Taco Well-Known Member
    Denver, CO
    14' DCLB TRD Sport supercharged
    You could've just loosened the U-bolts for the leaf springs and removed the bump stops completely in about 2 minutes. ;)
    Looks good.
