Air bags for 18 DCSB OF
Discussion in 'Suspension' started by AO1, Jan 5, 2022.
  1. Jan 5, 2022 at 6:47 AM
    AO1
    AO1 [OP] New Member
    2018 DCSB TRD Off-Road 6MT (silver)
    I have an A.R.E. cap which has sagged the back a little bit. I also pull a trailer 1-2 times a month. Anyone have success with Airlift bags ?
  2. Jan 5, 2022 at 2:14 PM
    eurowner
    eurowner Duke Sky
    Scoty
    I installed Firestone bag on stock springs. Ride quality suffered. I ended up putting Deaver leaf springs in and the ride is superior now.
  3. Jan 7, 2022 at 12:56 PM
    Mods2Travel
    Mods2Travel Well-Known Member
    Daniel
    Fort Worth, TX
    2015 DCLB 4x4 SR5
    Level 8 MK6, 16x8, 6x5.5, +0 Offset Rims 285/75/16 (33") BFG KO2 tires 4.56 Gears from ECGS DIY bed/drawer slideout Bed Mounted Deep Cycle Battery/Fuse Box/Inverter/Isolator Yellow Wire Mod Rear Diff Breather Mod DIY Roof Rack Leer 180 Shell Bilstein 6112, Circlip #4 Bilstein B8 5160 Remote Reservoir Firestone Ride Rite 2407 Rear Suspension Airbags DayStar Cradles Camper Shell Radiator Fans for sleeping in warmer climates
    I have the Firestone Ride-Rite's, but on a 2015 DCLB. I bought the truck with the shell already on, and it had OME nitrocharger struts so I don't have a frame of reference for stock. But Even with those struts completely worn out before I replaced them with Bilsteins I was happy with the ride. It seemed to help a lot with body roll in the mountains as well. (or at least when I didn't have them aired up I noticed).
    The installation was a little time consuming, as I recall about 1000 turns with a tiny open end wrench in a tight space on some of the bolts, but not anything very challenging. So far they've held up great over 3.5 years, including hundreds of miles of fire road at 30-40mph. As I just mentioned on another post, look up the daystar cradles if you're worried about droop when crawling.
    I haven't touched the leafs, so I can't comment there.
