Air Bags Not going Off
Discussion in '2nd Gen. Tacomas (2005-2015)' started by butch56, Jun 17, 2013.
  1. Jun 17, 2013 at 4:40 AM
    butch56
    butch56 [OP] Member
    I have a 2012 Tacoma Acces cab. A young kid ran a stop sign and my truck is on its way to the body shop. I "T" bone him the nose of my truck is destroyed. My air bags did not go off. This is a problem has anyone else have or heard of this happening. All info would be helpfull.
    Butch
  2. Jun 17, 2013 at 4:43 AM
    drunktaco
    drunktaco Well-Known Member
    Sage
    Southwest Va
    Icon ext travel C/O's, Total Chaos UCA's, King R/R shocks, All-Pro leaf pack, lights, RCI skid, Brute Force sliders, ect.
    It takes a bit to deploy an air bag. I shot through a guardrail on interstate and rolled several times in my 08 and only deployed the driver side air bag. I was also in another wreck and ended up tagging another car and a rock wall about 55. It ripped the front drivers side axle out completely and destroyed the motor and no air bags deployed then whatsoever.
  3. Jun 17, 2013 at 5:18 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    If you were alone, the passenger side airbag should not have gone off. The airbags, in general, are set off by an inertia sensor. Perhaps your accident did not cause you to slow in a short enough period of time?
    You should not be allowed to drive.
  4. Jun 17, 2013 at 5:28 AM
    drunktaco
    Sage
    Southwest Va
    The 08 tacoma one was a tire blowing out (retread) the other one I got hit into another lane then a car then I went into a wall. Wasn't my fault.
  5. Jun 17, 2013 at 5:45 AM
    ChiefManyWrenches
    ChiefManyWrenches Well-Known Member
    Florida
    '11 Silver DCSB TRD Off Road 4WD
    Pretty sure that if nobody is in the passenger seat, that airbag will not blow. I had a front end collision with a tree in my '10 a few months ago and only the driver bag went off. The impact was ~35 mph.
  6. Jun 17, 2013 at 5:53 AM
    butch56
    butch56 [OP] Member
    On impact his car turned 180 degrees around and I stoped in the middle of the intersection. I am sure I was doing at least 20 MPH
  7. Jun 17, 2013 at 6:09 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    But his car might have been light enough to where it didn't slow your truck quickly enough upon impact. When you say the front end of your truck was destroyed, keep in mind most of the front end is plastic bits and superficial. After you break all the plastic crap, then you get back to the frame of the truck and that's the damage you should be concerned about.
  8. Jun 17, 2013 at 6:15 AM
    Large
    Large Red
    These trucks are pretty robust, I doubt there was any more damage than cosmetics, at least you are okay.
  9. Jun 17, 2013 at 6:15 AM
    Fiveology
    Fiveology Well-Known Member
    MD
    11 DC TX PRO 4X4
    3" Lift OME 885's with a top plate spacer in front, Toytec AAL in rear, OME Nitrochargers, DWreck/FamousFab bolt on sliders, 255/85R16' KM2's
    Were you wearing your seatbelt?
  10. Jun 17, 2013 at 6:34 AM
    butch56
    butch56 [OP] Member
    I am ok and was wearing a seat belt thank god. I am hoping that the damage is cosmetic. I do feel that the air bag should have deployed
  11. Jun 17, 2013 at 6:49 AM
    Pugga
    Massachusetts
    If you walked away perfectly fine and are not injured in any way, why would you have wanted the air bags to deploy? Have you ever been slapped in the face by an air bag? It hurts like hell!
  12. Jun 17, 2013 at 6:58 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Sounds like you live up to your name..
  13. Jun 17, 2013 at 6:59 AM
    drunktaco
    Sage
    Southwest Va
    Haha thanks I guess
  14. Jun 17, 2013 at 7:18 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    OK here is how to figure it out:
    do you have visible bruises from the accident and
    from the seatbelt and shoulder strap ?
    a) yes ?
    airbags should have deployed, have system checked
    b) no ?
    don't be a puss, was not enough of an accident to matter
    :D
  15. Jun 17, 2013 at 7:21 AM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    I've run many wrecks where an airbag didn't deploy. I hate it when we pull up on scene and have to cut someone out of a car that the airbags didn't deploy. It seems there is no rhyme or reason as to why some do and some don't. It takes the right set of circumstances for them to go off and yours seemingly didn't meet that criteria.
    It is extremely dangerous when one doesn't deploy for you and the Firefighters on scene.
    I have been teaching auto extrication for the Fire Department for the last 10 years or so. The VERY first thing we do when we arrive on scene is disconnect the battery. The only problem with this is some vehicles are equipped with capacitors which can hold a charge for another 10 mins or so. Where you cut also plays a huge impact on airbag deployment. Those that have taken the cover off of their "A" pillar noticed the airbag sitting right there. That is why when we cut a "A" pillar we always cut it 2" from the cowling. It is almost a science and each model year they change something up. Now Ford even offers air bags in their seat belts :rolleyes:
  16. Jun 17, 2013 at 8:29 AM
    butch56
    butch56 [OP] Member
    I did not want to be hit with an air bag but I still would like to know that they will deploy if needed. How do you know that your air bag really work?
  17. Jun 17, 2013 at 8:31 AM
    Monkeyboy
    Monkeyboy Well-Known Member
    Grand Junction, CO
    2012 AC TRD Sport
    The only way to know is to have the computer pulled and the logs analyzed by someone who knows what they are doing.
    I can tell you that most cars these days only deploy the airbags in severe circumstances. This is for two reasons: One is reduce the risk of injury from the airbags themselves and to reduce the repair cost. The second - and this is important - is to keep the airbags for use in the event of a secondary collision.
    Based on your description, I would bet that they airbags didn't deploy because the collision profile wasn't severe enough to warrant it. But as I say, only someone who can read the logs and evaluate the system can tell you if that was the case or if there was a malfunction.
  18. Jun 17, 2013 at 10:35 AM
    frankbmg
    frankbmg Member
    SW Virginia
    06 Tacoma Sport Xtended
    From the NHTSA,
    Because air bag sensors measure deceleration, vehicle speed and damage are not good indicators of whether or not an air bag should have deployed. Occasionally, air bags can deploy due to the vehicleÕs undercarriage violently striking a low object protruding above the roadway surface. Despite the lack of visible front-end damage, high deceleration forces may occur in this type of crash, resulting in the deployment of the air bag.
  19. Jun 17, 2013 at 4:23 PM
    Hugh Morron
    Hugh Morron Manic Mechanic
    Bill
    Schuylkill County, PA
    12 DCLB SR5 4X4 Barcelona Red Metallic
    ARE Cap, AVS Bugdeflector II, AVS Ventshades, DTRL delete, ABS/VSC/TRAC disable, Toyota LSD with clutchpacks, N-Fab Lightbar, Hella 700ff lights
    Be glad that your air bag did not go off. First off it would cost thousands more to fix. Second I don't know how the Toyotas are but a lot of vehicles airbags are packed in a white powder to protect them from dry rot. When they go off it scatters the white powder throughout the vehicle. Almost impossible to completely clean from the interior. Most vehicles with airbag deployment get totaled.
  20. Jun 17, 2013 at 4:29 PM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, bed mat, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs and Toytec tps for 3'' front lift, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights, light pods mounted in bed, Devil Horns emblem from Diaz Fabrications, rear facing pod lights in bed, under seat lights,
    I had a recent experience with Toyota air bags. Hit a cow that ran into the highway at about 65mph. Mine deployed perfectly and was like hitting a big marshmallow when I was whipped forward. In your case, 20 mph might not have been enough force to deploy it, as it has to break through layers of fiberglass and plastic before it reaches those sensors. And as someone else said, it costs thousands more per airbag to replace after they've been deployed, not to mention replacing your steering wheel and dash where they explode through.
