AIR BAGS OR AAL ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 07taco09, Dec 1, 2010.
AIR BAGS OR AAL ?
Poll closed Dec 31, 2010.
  1. AIRBAGS
    12 vote(s)
    50.0%
  2. AAL
    12 vote(s)
    50.0%
  1. Dec 1, 2010 at 12:18 PM
    07taco09
    07taco09 [OP] Active Member
    matt
    charleston s.c.
    07 prerunner sr5
    Debadged, tinted windows, tinted tail lights, BHLM, Satoshi grill, Fog light mod, yellow fogs, paint center valance, 265/75/16 at's. TRD cold air intake. borla exhaust
    IM GOING EITHER WITH AIRBAGS OR AAL. WHATS YOUR INPUT
    2007 SR5 PRERUNNER DC
  2. Dec 1, 2010 at 12:22 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    little bit more info on what you planning on doing with the truck? will you use it for off roading? towing? etc
  3. Dec 1, 2010 at 12:25 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    x2.... Air bags would suck off-road but great for towing/hauling. Depends on what you're looking to do with your truck.
  4. Dec 1, 2010 at 12:59 PM
    SplitDecision
    SplitDecision Phones Ringin Dude
    Haywood Jablowme
    NY
    Silver TRD OR
    Bilstein 5100x4, Truxedo lo pro QT,Hid Retro,2011 painted grill,Alpine head unit,Foglight mod,NFAB steps
    AAL IMO. I don't think you can jack the truck up by the frame with bags installed. Something to do with them tearing or something. Just what I read on the Firestone bags but no first hand experience. I was pondering bags until I read that. Also moisture buildup etc . Seems like too much hassle.
  5. Dec 1, 2010 at 6:09 PM
    07taco09
    matt
    charleston s.c.
    07 prerunner sr5
    forgot to mention mainly for towing and bottoming out. i can have my in laws in the back seat and just my tool box in the back and it bottoms out. took it to toyota declined the claim because i had a caulk gun in the truck bed and they told me it was being used as a commercial vehicle. the warranty campany heard a ear full that day.
  6. Dec 1, 2010 at 6:24 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    If you want to haul an elephant in the back of your bed, airbags.
    Jack the rear up a bit and give you some more clearance, AAL.
  7. Dec 2, 2010 at 12:11 PM
    thinkingman
    thinkingman Well-Known Member
    redmond WA
    2006 dbl cab 4wd 6sp
    Foglights are for fog, not oncoming traffic!
    airbags...adjustable.
    AAL=comitted
  8. Dec 2, 2010 at 1:40 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Get a 3 leaf aal set, and a set of 5100s up front to level it out. Better ride, and should get rid of your bottoming out issue (unless you put an elephant in the bed).
  9. Dec 2, 2010 at 1:49 PM
    NicP
    NicP Well-Known Member
    Nic
    colorado
    05 DC LB
    3" Icon CO Icon Rez and AAL ProComp 7089 BFG 285 AT KO
    Sorry to mess things up possibly by adding another option, but I was looking for something to help my occasional towing and full load in the truck bedb and ordered some Timbren bumpstops today. After all the research on this site looked like the best option for my use. I have an Icon AAL which helped to match my front lift but still need something for extra load without altering road handling when empty.
    Bags=more$ and need to adjust/fill and empty
    AAL=stiffer ride all the time
    Timbrens engage when loaded but dont affect anything when not under weight. Makes towing/hauling more stable ride. Do a search on them and see the reviews/opinions on TW or Google for more opinions.
  10. Dec 2, 2010 at 3:51 PM
    Priddle
    Priddle And now for something completely different....
    St. John's, NL Canada
    2014 Tacoma 4x4 TRD Sport DCSB
    Current: Pelfreybilt front and rear bumpers, winch, icon front coils/shocks, Icon rear shocks, Dakar leafs, Camberg UCAs, Pumpkin Android stereo, custom sub box w/ 2x10" RF subs and Kicker amp, short shifter kit, Fuel Beast 18" wheels w/ 1mm offset, BFG AT2 285/65/18
    I have airbags on my Tacoma. I didn't want the rough ride of AAL. I can adjust the bags depending on weight. As long as you deflate the bags prior putting it up on a lift, then they will be fine. I have also off-roaded my bags and flexed the suspension with no problems at 10-15psi. No regrets on the bags at all.
    I have 5100's up front @ 2.5 and the bags @ 15psi level the truck perfectly. I am so glad I didn't go AAL.
  11. Dec 2, 2010 at 8:07 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Wrong...
    Tires are made of rubber, too... and they work off road!
    Ride Rite Air Springs (bags) are made by Firestone, they don't get damaged... In fact, I can say they are BAJA PROVEN!
    Only 15 psi in them for normal loads... and I went to 45 psi for a very heavy load on Baja's toughest roads... no problem. They are rated to 100 psi! (but never go more than you need and not max... you could crack an axle!)
    Here they are along with 5100 Bilsteins on my '05 DC. I was 100% satisfied with them. Recommended to me by Off Road Warehouse.
  12. Dec 2, 2010 at 8:15 PM
    NamBam
    NamBam Member
    Birmingham, Al
    2014 DBSC SSM Off-Road
    OME 887 on Bilistein 5100s. SPC UCA. Revtec Diff drop & OME Driveshaft spacer. AAL rears. SCS F5 16x8 w/ Nitto Ridge Grapplers LT285/75R16.
    AAL for less maintenance and stuff that could go wrong. pump, bags dry rotting. but you have people who will vouch for both so go with what you will be happy with.
  13. Dec 2, 2010 at 8:33 PM
    David K
    I agree on the simplicity of Add A Leaf, but your ride is stiff all the time. I was going that route until I talked to the experts at Off Road Warehouse (who sell both) and given the information and what I used my truck for, Air Springs made more sense.
    No Pump... you add air or remove air the same as you do for your tires. The fill valves (one for each bag) were installed on each side of my license plate. It takes just a couple seconds to change the pressure.
    Dry rotting? They never see sunlight where they are... never heard that as being a concern, before...
    Again, change your ride firmness and height with a bit of air or be firm all the time... what ever works for you!
  14. Dec 2, 2010 at 8:47 PM
    Clelsdah
    Clelsdah Western Alliance: Yeehaw Division
    No California Foothills
    08 SR5 4x4
    Bed mat, tube steps, Ipod interface, Ride-rite air springs
    3 years and counting with the Firestone airbags. Has been on lifts, jacked by the frame several times, off-roading moderately, and loaded over 2500lbs. No issues yet other than when I tried to get the leaf spring TSB... service manager said I took care of the problem by adding the airbags. I told him I would be back in a hour without the airbags as they are that easy to remove and install. He called me before I got home to schedule my truck for the new springs. I like the adjustability of the airbags.
  15. Dec 3, 2010 at 12:30 AM
    arizonataco
    arizonataco Well-Known Member
    Phoenix Arizona
    Firestone Airbags ARE Camper Shell
    Airbags give you a little lift there adjustable.Great for hauling and towing.You don't need s compressor they are very easy to fill.
    I have had two sets. they are great. BUT I don't wheel hard like some as that can be an issue maybe rip or tearing one.
    I just hate a real stiff ride and as I understand an AAL might couse a bit of harsh ness un loaded. Im just guesing on that part people. Please respond
  16. Dec 3, 2010 at 8:24 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    how about an good old "helper spring" an ideas or comments on these?
  17. Dec 4, 2010 at 5:03 AM
    David K
    It was one of the options I considered before going with the Ride Rites.
    The Helpers are good and only come into play when you have a heavy load... otherwise, the softer/ primary springs do the work the rest of the time.
    I like being able to have countless adjustment choices... well at least 35 choices at 10 to 45 psi in my case.
  18. Dec 4, 2010 at 5:14 AM
    SilverTacoZack
    SilverTacoZack Well-Known Member
    Zack
    Elgin, SC
    2011 FJ trail teams
    I voted AAL....I had Air Bags installed on an old 1984 GMC we used to haul stuff around in. They worked ok when you needed to put stuff in the bed, but they were kind of a PIA to be inflating/deflating all the time. AAL is a better permanent solution
  19. Dec 4, 2010 at 5:23 AM
    David K
    You could have just kept them inflated... Why did you deflate them all the time? Keeping air springs at the higher pressure is no different than an AAL which you cannot soften if you want to... right?
  20. Dec 4, 2010 at 6:25 AM
    SilverTacoZack
    Zack
    Elgin, SC
    2011 FJ trail teams
    Well, on this particular truck, it was actually lowered in the front and back. Lowered with special spindles in the front, and leaf springs were flipped upside down in the back. Keeping the air bags inflated to any serious PSI level when there was nothing in the bed caused, for one, the truck to ride extremely badly, and secondly it caused such an extreme rake in the truck that the front tires would starting having issues. Probably the reason we got rid of the damn thing for a couple thousand bucks once we had other vehicles to use to haul stuff around.
