Air Bags or Add a Leaf
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jwhit2848, Jul 14, 2020.
  1. Jul 14, 2020 at 8:00 AM
    jwhit2848
    jwhit2848 [OP] Well-Known Member
    Jeff
    2015 Silver Tacoma TRD sport
    I'm looking for opinions here. I have a 2015 TRD Sport with the towing package. Should I get air bags or should I add a leaf to my existing leaf springs to level out the truck when I'm hauling a lot of stuff in the bed or pulling a trailer? Thanks in advance for your advice.
  2. Jul 14, 2020 at 8:02 AM
    pmstoy10
    pmstoy10 Well-Known Member
    hudson valley, ny
    2010 Tacoma DCLB TRD Sport
    Weathertech Floor Liners, UWS Toolbox, Seatbelt Chime Mod, Coverking Covers, Window Guards, Wheeler's 1.5" Single Leaf AAL, Rear Spring TSB, Front Bilstein 5100's @ 2.5", Rear Extended Travel Bilstein 5100's, removed front mud flaps, Lifetime LED Headlights, Firestone RideRite Air Bags with Daystar Cradles, Light Racing UCA's, ECGS Front Diff Bushing
    I run both. I clear 285's with AAL and use the airbags to handle my 22' camper.
    06Tacooo and TegoTaco like this.
  3. Jul 14, 2020 at 8:03 AM
    Slobber
    Slobber Well-Known Member
    Central PA
    2015 Pyrite DCSB
    I had to make the same decision. It was pretty easy in the end, I only wanted the level it under load and wasn’t ready to have a lift. And as I don’t always have the truck weighed down, I went with bags.
    if you go that route, I’d recommend the Firestone kit, it has been flawless for 4 years now.
    Silentshredr and 06Tacooo like this.
  4. Jul 14, 2020 at 8:07 AM
    jwhit2848
    Jeff
    I don't have a lift and only want it leveled under a load so it sounds like airbags may be the way to go.
    How hard/easy were they to install?
    Silentshredr likes this.
  5. Jul 14, 2020 at 9:05 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    If all you need is to level when towing, air bags are the easier option.
    No experience with the Tacoma, but 3 sets on a Dodge Rams. (They help)
    Before I would add a leaf. I’d throw a whole leaf pack in, If I could afford it.
    The stock springs are “weak” they go flat with out towing.
    If you don’t have axle wrap, just wait, you’ll eventually get it.
  6. Jul 14, 2020 at 9:26 AM
    Hoyle
    Hoyle Well-Known Member
    Cookeville TN.
    2014 DCSB 4x4 Black
    A lot of stuff.
    I also have the Firestone Airbags. Very useful for leveling when towing my 20' RV. I like also having the rear raised a little with the ICON kit installed that also included additional leaf pack.
    The only downside of Airbags... when adjusting air pressure, it effects the headlight beams on the road...
    TnShooter likes this.
  7. Jul 14, 2020 at 9:32 AM
    Slobber
    Central PA
    2015 Pyrite DCSB
    Install was easy, simple bolt on stuff. I didn’t go with the on board compressor though.
    06Tacooo likes this.
  8. Jul 14, 2020 at 10:46 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Im deciding between airbags or the pedal commander lol!
  9. Jul 14, 2020 at 11:30 AM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    Air LIft - Air Ride air bags - #59561 Installed when truck was new (2015 Sport) Lifetime warranty on bags, very easy install. I used a tee in the fill line, pressure equalizes between bags, single fill point. I run about 8 psi with truck empty, 15 psi pulling trailer with golf cart, about 300 lbs tongue weight. (Some will argue separate fill lines, two fill points. Airlift sells kits both ways).
  10. Jul 14, 2020 at 12:12 PM
    jwhit2848
    Jeff
    Thanks for all the responses. I'm going to go with air bags.
  11. Apr 17, 2021 at 12:43 PM
    CoryV
    CoryV Well-Known Member
    cory
    2021 TRD SPORT AC MT
    Did you lift the front of your truck as well with the icon springs?
  12. Apr 17, 2021 at 1:46 PM
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    I would recommend not using the tee to connect the airbags. On turns, pressure will shift to one airbag and can cause increased lean and reduced stability which is one of the reasons for using airbags. I think Firestone says they purposely do not supply a union tee for this reason.
    The airbags are really great. I love the adjustability and don't bottom out. OR springs are so weak, a few hundred pounds and you're bouncing around on your bump stops.
    Installation requires you to jack up your rear end, remove tires, and install. I had a friend who knew what he was doing help me. Took an afternoon.
  13. Apr 17, 2021 at 1:49 PM
    forana
    Kaneohe, Hawaii
    Oh! and get this pump, you will thank me later. Yes it's a ball pump, yes you think it's too small to inflate your airbags but it works wonderfully. You can get precise PSI without having to use a separate tire pressure gauge and loose some of the pressure when doing so.
    https://www.amazon.com/eBall-Inflat...l+pump+with+gauge&qid=1618692445&sr=8-1-spons
  14. Apr 17, 2021 at 1:52 PM
    jbrnigan
    Midwest
    In fact, a "Tee" in the airline is appropriate and reccommended for some applications (onboard compressors, and equalized pressure for towing). If you are considering air bags, do a little independent research before deciding to follow advice here.
  15. Apr 17, 2021 at 1:59 PM
    forana
    Kaneohe, Hawaii
    Agreed, however I have Firestone airbags and Firestone recommends not using a tee. So I'm passing on primary source info.
