Air bags Vs Sumo
Discussion in '3rd Gen. Tacomas (2016-2023)' started by forana, Mar 26, 2022.
  1. Mar 26, 2022 at 2:41 PM
    forana
    forana [OP] Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    Ok, question. I know air bags are better because of adjustability, I had them on my 2nd gen and loved them. Only issue I had was I needed a friend to help me install them. I am not comfortable doing it myself.
    Sumo springs seems easy and I could do that myself.
    I don't tow very much, I want airbags or sumo springs just for when I have heavy loads in the bed. I am leaning toward sumos cause I can do it easily and don't really have heavy loads a lot, just for hauling occasional dirt, rubbish, bricks, camping etc.
    what do you guys think? Am I missing anything?
  2. Mar 26, 2022 at 3:16 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    TBQH, I don’t know why you want to install these things. If contraptions like air bags and sumo springs made sense for every day pickup stuff, they would be a factory standard feature. You aren’t taking your pickup outside its comfort by hauling dirt, rubbish, or camping gear.
    soundman98 likes this.
  3. Mar 26, 2022 at 3:32 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I looked at those, read reviews until I was blue in the face, and ultimately gambled on the third option. Roadmaster active suspension.
    Pros-
    • easy to install. Like super easy
    • Adjustable. Can change the spring rate from non-tow to heavy tow/haul and anywhere in between.
    • No messing with stock bumps or ubolts
    Cons-
    • Adjustability is a bit of a misnomer. You need a solid 20 minutes and be comfortable with jacking the rear tires off the ground to adjust.
    • If you get lazy like me and leave it in heavy tow mode, the rear will be stiff when unloaded. Naturally. Also, the unloaded truck in heavy mode raises up an inch or so, stink-bug stance.
    Overall- I've been running mine since 2017, even kept them when I traded trucks and reinstalled. I still like them.
    eurowner likes this.
  4. Mar 26, 2022 at 4:49 PM
    tshop11
    tshop11 Well-Known Member
    Tyler
    Truckee, CA
    22 Tacoma SR5
    I installed sumos the other day as I'll be adding a pop up shell and have about 500 lbs at all times in the bed. I liked the simplicity of them and the concept, which I admit may just be good marketing.
  5. Mar 26, 2022 at 5:12 PM
    Tacoma091919
    Tacoma091919 Well-Known Member
    Tim
    2019 OR DCLB
    I ran sumos (612-40s) for a couple years due to cap and weight. They firm up the back nicely especially with the softer OR suspension would wallow a bit. Now I have Deaver stage 2s and the sumo springs are extended bump stops to keep from bottoming out Eibach shocks. The sumos worked well for me until I upgraded leaf packs and continue to serve a function.
  6. Mar 26, 2022 at 11:40 PM
    forana
    Kaneohe, Hawaii
    My 2nd gen would bottom out with a few hundred pounds of weight in the bed. This 3rd gen seems much stiffer but I was being proactive and considering options.
  7. Mar 27, 2022 at 8:56 AM
    spamy
    spamy Truck guy
    NorCal
    2017 Tacoma Sport 4x4
    The airbag kits arent much more work than new bumpstops these days. No drilling needed.
    i went with airbags cause ill go between no load and heavily loaded down on any weekend (ditrbike, firewood, misc junk, hungry wife, dog, tools, trailer). It works great for what I need.
    Also I cant see spending 300+ bucks for a chunk of rubber.
    02Duck and Big tall dave like this.
  8. Mar 27, 2022 at 2:41 PM
    Tacoma091919
    Tim
    2019 OR DCLB
    I went with sumos because greater reliability / can’t fail. Bags are certainly better for towing and adjustment. Sumos can be found cheap occasionally. I think I bought mine for around $100 warehouse deals on Amazon.
  9. Mar 27, 2022 at 3:44 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Airbags: Adjustable which is nice. They limit downward wheel travel, droop, and you do not have any bump stops (the bags are not to be used as bump stops).
    Sumo: No limit to droop. Easy to install. Kinda one big bumpstop.
    Roadmaster: Not "popular". Adjustable, does not limit droop, and keeps factory bump stops.
  10. Mar 27, 2022 at 5:42 PM
    forana
    Kaneohe, Hawaii
    Airbags are substantially more difficult to install. Sumos are installed loosening the spring bolts, slip in the spring, and tighten. No need even jack the truck.
    tshop11 and eurowner like this.
