Air Bags while running through the desert in a DD??
Discussion in 'Off-Roading & Trails' started by HAWAIICALIVEGAZ, Jan 14, 2012.
  1. Jan 14, 2012 at 10:55 PM
    HAWAIICALIVEGAZ
    HAWAIICALIVEGAZ [OP] Desert Warrior
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    Dr Coilovers; Camburg UCAs; Sway bar Relocation block; Deaver J66 Leafs; ProComp extended travel rear shocks 6K HIDs & 13" antenna
    I tried searching but didn't really find my answer. I use my truck as a daily but eventually will be taking it through some trails here in the desert.. I have a prerunner so I won't be doing any crawling. But my question is how feasible is it to run air bags with a 3" lift and the occasional trip to the dirt and I do tow from time to time. I do know that there is potential for them to get punctured but my biggest concern is how will the trails affect the bags?
  2. Jan 15, 2012 at 12:27 AM
    sooner
    sooner Well-Known Member
    TX
    2011-4X4-LONGBED
    6-inch pro-comp lift-,n-fab 6 step nerfbars,extang touneau cover,go rhino grille guard,aftermarket fogs,3.5 driving lights,7-inch off road lights.pro comp skid plate,train horns,reese tow hitch,escort 9500ix,blend mount wireless radar mount.avs bug deflector and window vents,5%window tint.28-led back up lamps,sock monkey 3rd brake light decal,magna flow exhaust.klein train horns.nitro,nitro 4.56 gears,pro-comp traction bars,volant super scoop air intake.
    have never actually had the air bags,a buddy does and says great for towing and daily driving.
  3. Jan 15, 2012 at 2:27 PM
    HAWAIICALIVEGAZ
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    that's kind of what I'm thinking...
  4. Jan 15, 2012 at 10:59 PM
    gacandido2010
    gacandido2010 Well-Known Member
    Gabriel
    Inland Empire CA
    01 Prerunner TRD
    Bilstein 5100s, Eibach Coils, All Pro Baja Leaf Pack, Fox 2.5x16", All Pro 1.5 spacers, Deckplate Mod, K&N Filter, Magna-Flow Exhaust System, Cobra Ultra Cb with 3" Firestick, 2 Hella 500 HIDs, custom mesh grill, blacked out lettering, Limo Tint, Fog Light Mod
    wut do u mean under pressure? u can turn them off or something? i kno u can for shotgun
  5. Jan 16, 2012 at 12:14 AM
    HAWAIICALIVEGAZ
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    Not the airbags in the steering wheel or dash... Rear helper air bags to help level the truck when towing or just level the truck in general...
  6. Jan 18, 2012 at 3:47 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    My thoughts too. i wouldn't race Baja with bags, but as long as they aren't under pressure, you should be okay.
    Those things are pretty thick, I wouldn't worry *too* much about a rock or something flipping up and puncturing them...
  7. Jan 18, 2012 at 5:10 PM
    gacandido2010
    Gabriel
    Inland Empire CA
    01 Prerunner TRD
    wow i feel dumb :facepalm:
  8. Jan 30, 2012 at 5:47 PM
    HAWAIICALIVEGAZ
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    LOL It's alright... It happens to us all!.....
    well maybe not that one but you know what I mean LOL
  9. Jan 30, 2012 at 11:06 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    I had Ride Rite air bags on my '05 DC Off Road 4WD, to fix the soft rear spring harsh ride/ bottoming. They were awesome... great in the desert and Baja... loaded truck or empty... just adjust the pressure! 15 psi empty to 45 psi heavy load... raises the truck too.
  10. Jan 30, 2012 at 11:19 PM
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    Seems to me you would add premature wear on them and shorten the life of the material much more. I would think it's not a good idea but not much harm done if you do that on a limited basis either.
  11. Jan 30, 2012 at 11:47 PM
    acdronin
    acdronin Well-Known Member
    I took my ride rites up on the Oregon Dunes and was looking at how the bags responded with flex, my gut feeling is to put straps on the axle to keep the axle from going too far and ripping open a bag
  12. Jan 31, 2012 at 12:35 AM
    stewartx
    stewartx Well-Known Member
    Huntsville AL
    2012 Silver DC SB TRD Off-Road
    Winch, front hitch, step bars, bed extender, bed step, gull-wing toolbox, tailgate lock, security system, cb radio, etc.
    Well, as they say, you are what you feel. :rofl:
  13. Jan 31, 2012 at 10:59 AM
    HAWAIICALIVEGAZ
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    So how did they do?
  14. Jan 31, 2012 at 11:00 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    dont you get less flex with the bags? dont know if that matters to you or not
  15. Jan 31, 2012 at 11:18 AM
    acdronin
    They did fine, my concern was that it was the airbags themselves that determined the limit of travel so I felt that straps that limit the travel to no more than what the airbags could handle would keep them from possibly getting damaged.
  16. Jan 31, 2012 at 11:24 AM
    HAWAIICALIVEGAZ
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    Gotchya... Guess when I install mine, i'll jack the truck up enough to check what's limiting my down travel?
