air bags??
Discussion in 'Towing' started by RZG77, Jul 31, 2011.
  1. Jul 31, 2011 at 7:45 PM
    RZG77
    RZG77 [OP] Active Member
    Perrysburg, OH
    06 trd off road 4x4
    I'm looking at doing some towing with a 06 dc, would it be worth putting air bags on it? I haven't seen much on it. Does it help? Example ..... just towed a heli about 200 miles and would rather of used my truck. (4500 lbs)
  2. Aug 1, 2011 at 4:07 PM
    sechsgang
    sechsgang Well-Known Member
    06 DC TRD OR 4WD 6spd
    You would rather have used your truck?
    I recommend looking at Timbrens, they work similar, but are cheaper, easier to install, and will not break.
    I have them, and several others here, I think. They work well.
  3. Feb 21, 2012 at 10:12 PM
    santas212
    santas212 I'm on a boat!
    Georgetown, CT
    '09 DCLB, TRD Sport, Barcelona Red
    Mostly miscellaneous electronic mods.... -2 spare Electrical fuse blocks hard wired to the battery with a key on relay. -Hard Wired Radar detector over rearview mirror. -2 Dual Whelen Avenger blue LED emergency lights, one on each side of the rearview mirror. -EP911 Blue LED Light Bar & Traffic Advisor, Rear Windows. -4 corner amber strobes in stock lights. -Hardwired RF Scanner with external speaker under center console. -Huskyliner front splash guards -Fireband 2 way radio in center console. -Herculiner painted on hitch and skid plate. -Switch to power one 12v socket when truck is off. -AntiDark LED strip under hood with switch. -Timbren Rubber Springs - Rear -MBRP Offroad Cat-Back with Resonator -Duratrac's -Provisor -Color matched hood bug shield
    Sechsgang- what kind of weights are you loading In your truck with the added timbrens?
  4. Feb 21, 2012 at 10:18 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    this is another member on here. for refference, the atv weighs almost 1000 lbs fully loaded. first shot is just springs, second shot is airbags pumped to 45psi.
