air bags
Discussion in '2nd Gen. Tacomas (2005-2015)' started by l_prettyman, Apr 30, 2010.
  1. Apr 30, 2010 at 8:00 PM
    l_prettyman
    l_prettyman [OP] Well-Known Member
    Logan
    Easton Shore Maryland
    06 4x4 SR5
    12% tint, Leer cap, Pioneer Avh3100DVD headunit, Kinetik 2000 battery, Memphis pr1.1000 amp, Pioneer subwoofer(not sure what kind), Back-up Camera, PA/CB system
    anybody running air bags as a helper? how is it set up? cost? so on and so forth :D
  2. Apr 30, 2010 at 8:28 PM
    sam_i02
    sam_i02 Well-Known Member
    Samir
    Kanata, Ontario
    05 PreRunner AccessCab
    BHLM, Satoshi grill, D-rings, Relentless Fab recovery shackle, DRL, Firestone RideRite airbags, WO seatcovers, added temp gauge, custom interior lights.
    I recently purchased a set of Firestone Ride-Rite airbags from Autoanything.com. Cost $250 shipped to my door.
    Have not installed it yet - plan to, in the next week or so. I got this kit becasue of some reviews I read here.
    Also picked up some used bumpstops and cut them on a bandsaw before hand, to make the install go quicker. This way i dont have to putz around with a hacksaw, cutting the bumstops on the truck while doing the install. I will take pics while I do the isntallation and post here.
  3. May 1, 2010 at 6:55 AM
    l_prettyman
    Logan
    06 4x4 SR5
    thank you for taking pictures when you install them. i was going to get the leaf spring TSB done but im not under warrenty anymore and the dealer said it would be roughly 1400 not including labor. i said f**k that
  4. May 1, 2010 at 7:19 AM
    knayrb
    knayrb Well-Known Member
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    I've struggled with this decision. For 95% of the time I drive with no weight in the back. I actually like the smooth ride on the pavement. I'm worried that if I get the leaf spring TSB done it will stiffen the ride too much for me.
    Now for the rest of the time when I want to tow, haul firewood, mulch, dirt, and other construction material around I want it to stiffen up and not sag the rear end down. I'm looking into airbags as an option instead of the TSB. In my thinking they could be aired down for straight unloaded road use or aired up for heavier loads. I'm even thinking about adding the onboard compressor to adjust the ride on the fly.
    Keep us posted on how your truck behaves after you get the bags installed.
  5. May 1, 2010 at 8:22 AM
    l_prettyman
    Logan
    06 4x4 SR5
    will do. im thinking of doing the same thing you just said. compressor, bags, gauges and a way to air them and deflate them at the flip of a switch
  6. May 1, 2010 at 8:28 AM
    soilsample
    soilsample Well-Known Member
    Donald
    Southwest Louisiana
    '09 4x4 Double Cab
    I have the firestone ride rite airbags on my '09.
    I'm very pleased with them. Truck will remain level even when loaded. I'm running about 3 pounds in the bags when unloaded and hardly notice they're there.
    Install is not too hard, although I'd sugges replacing the supplied locking nuts with a regular nut and lock washer, otherwise you fight the nuts all the way.
    Also I suggest you leave the big bolt that goes through the frame until last. This way you can flex the airbag to move it around and have easier acess to the other bolts.
    Good luck
    Donald
  7. May 1, 2010 at 8:29 AM
    Swerve
    Swerve Active Member
    Jeremy
    SLC, UTAH
    07 DC SR5 4X4
    I just installed the firestone ride rite bags last night with the standard duty compressor mounted in under the hood.
    I was patient enough to find them on our local classifieds for $400 used but in great condition. About three hours to install the bags, lines, compressor and switch/guage unit.
    I started out with a 2" lift and after the bag install it rides at 3/4" taller at 10psi.
  8. May 1, 2010 at 9:08 AM
    Swerve
    Jeremy
    SLC, UTAH
    07 DC SR5 4X4
    Here was my truck yesterday (with a 2" lift):
    I started by lifting the rear and removing the tires. Then I cut the bump stops off where they are level with the leaf spring ubolts.
    Next I found the best way to install the bags is to assemble the unit loosely and only take out two of the four small bolts on the backside of the upper part of the unit. Slide it in and lave the large main bolt loose. This fits pretty tight but not too bad to install. No drilling or any tough work here.
    Run the line between the two sides and then T that line to the engine compartment (watch out for getting to close to the muffler and pipe. i ran mine up the passenger side frame).
    Mount the compressor next to the battery, like Toyota gave you the perfect spot for it! Drill holes and push hardware through. Plenty of room in the wheel well, very easy step.
    Next I chose to mount the gauge in the glovebox to keep the cabin neat and tidy. Plus, the only good place to mount it in the cabin would bump my knee when I got in and out of the truck. You can see two sets of holes...I rotated the gauge and remounted it, try to avoid this misstep!!!
    Now run the air line from the bags into the glovebox, connect to back of gauge and run the other air line to the compressor. Next run the wire for power and ground to the battery. I skipped the illumination wire part because I really dont want that light on in my glovebox whenever I use my headlights.
    This is the finished pic at 10 PSI - adds about a 3/4" to 1" inch incease in height.
    And at 60 PSI - Only for towing as you can see.
  9. May 1, 2010 at 10:35 AM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Nice!
  10. May 1, 2010 at 4:14 PM
    knayrb
    Pure stock
    Great work! You solved another concern for me and that was where to mount the gauge and switch. The glovebox is the perfect hidden location. I do wish the gauge was electronic and had a pressure sensor at the compressor. That way you wouldn't have to run air lines into the cab.
    (BTW Swerve, I recognize those mountains.) I'll have to PM you if I get stuck when I do mine. You can't be too far away.
  11. May 1, 2010 at 10:01 PM
    Swerve
    Jeremy
    SLC, UTAH
    07 DC SR5 4X4
    Always willing to help.
    If you mean you recognize the mountains in my motorcycle pic, that was a 40 degree day in July on the continental divide in So. Colorado. Nasty cold!
  12. May 2, 2010 at 5:16 AM
    sam_i02
    Samir
    Kanata, Ontario
    Swerve - excellent write up. Thank you!
  13. May 2, 2010 at 5:43 AM
    bb609
    bb609 O.F.
    NH
    '09 TRD Sport Access Cab
    Bilstein 5100 CO's @ 1.75" - Icon UCA's - TSB Rear w/Bilstein 5100's - Air Lift System - Flowmaster 50 Duals(RIP...back to stock for now) - Avid Offroad Arctic Bar - Avid Offroad Nerf Bars - Leer 550 Bedcover - AVS Hood Protector(RIP) - Ventshades - Yota Bed Mat - Sheepskins!!! - Weathertechs
    I have an Air Lift system. With controller, it was about $400. The bags mount forward and behind the bump stops (depending on the side) in all predrilled holes.
    I mounted the compressor above the bed cubby to the outside of the bed wall and controls in the cubby to keep everything in the back of the truck.
    Air capacity is 100 lbs. At 40 lbs, they keep my truck level towing a nose heavy 4,000 lb. boat.
