Air blows from vent on all settings
Discussion in '1st Gen. Tacomas (1995-2004)' started by cannonskate, Aug 21, 2011.
  1. Aug 21, 2011 at 4:02 PM
    cannonskate
    cannonskate [OP] Member
    SoCal
    04 Prerunner
    Camper shell
    I just bought an 04 Prerunner (to replace my 07 4x4), and I just noticed that the air vent left of the steering wheel blows air even when I put the switch to feet vents only. It is only that one vent that does it, the others all seem to be normal. What could be causing this?
    Thanks!
  2. Aug 21, 2011 at 4:04 PM
    memario1214
    memario1214 Vivid Illumination Vendor
    Colton
    Gillette, WY
    05 Dub Cab TRD Sport 4x4
    Yeah, I gots boost
    Those two corners (pass and drivers nearest window) will move air at all times... Even if the fan switch is to off. My 03 did it and my 05 does it too. Most if not all vehicles do it.
  3. Aug 21, 2011 at 4:09 PM
    leveltwo
    leveltwo Well-Known Member
    when the ac is off, put the direction on top vents only, and press circulate... it should not blow out at all
  4. Aug 21, 2011 at 4:19 PM
    cannonskate
    SoCal
    04 Prerunner
    Camper shell
    I just went out and checked and your right, the two corners blow air no matter what setting, including if on circulate, ac, heat, whatever. If the fan is turned off, and circulate is on I dont think they will, but any other setting they do. Is this normal? I have never had this in any of my other cars/trucks before, and they have all been Toyota.
  5. Aug 21, 2011 at 4:20 PM
    memario1214
    Colton
    Gillette, WY
    Yeah, I gots boost
    I dunno whether or not it is normal, but it has been the case in every vehicle I have ever owned. And they were not all Toyotas. 2 Toyotas, 2 Nissans
  6. Aug 21, 2011 at 4:20 PM
    Iakopa84
    Iakopa84 Well-Known Member
    Jake
    Escondido, CA
    05 PreRunner TRD Off-Road
    Aries Grille Guard, PIAA 520 xtreme ATP lights, K&N high-flow intake, 2.5" velocity front leveling kit
    Don't they have something to do with defrost for the driver and passenger windows? Maybe that's why they're always on... ?
  7. Aug 21, 2011 at 4:22 PM
    memario1214
    Colton
    Gillette, WY
    Yeah, I gots boost
    Yes, you are correct. If a vehicle has the extra corner vents meant to just defrost, then this all the time corner vent running phenomenon won't happen. Many vehicles do in fact have those. In that case, none of the normal 4 vents would blow out any air
  8. Aug 21, 2011 at 4:26 PM
    cannonskate
    SoCal
    04 Prerunner
    Camper shell
    Ohh ok that makes sense, well thank you guys for the info, sorry for the somewhat silly post, hopefully someone else will benefit from this in the future...
  9. Aug 21, 2011 at 4:28 PM
    memario1214
    Colton
    Gillette, WY
    Yeah, I gots boost
    No worries. That's what we're here for. Oh, and welcome to TW :wave:
