Air Bumps vs Light Racing Jounce shocks
Discussion in 'Long Travel Suspension' started by PLC721, Jun 3, 2012.
  1. Jun 3, 2012 at 4:27 PM
    PLC721
    PLC721 [OP] Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Camburgs, Methods, Vision X, BFG
    for a mid travel front set up, id like to add either 2.0 air bumps or light racing jounces. thoughts? the light racing jounces are really expensive tho! :eek:
    so what are the benefits over the other of the two?
  2. Jun 3, 2012 at 4:30 PM
    nfs257
    nfs257 Well-Known Member
    Menifee, Ca -> Tucson, Az -- April
    09 DCLB PreRunner MGM SR5 Debadged
    Trac Performance built Prerunner
    Subbed...
  3. Jun 3, 2012 at 4:31 PM
    PLC721
    Patrick
    Chandler, Az
  4. Jun 3, 2012 at 4:34 PM
    nfs257
    Pass that... :popcorn:
    :cheers:
    Byb127 likes this.
  5. Jun 3, 2012 at 4:37 PM
    PLC721
    Patrick
    Chandler, Az
    :cheers: :thumbsup:
  6. Jun 3, 2012 at 4:37 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    I think the jounce bumps are just nitrogen charged, no valving.
    Hydrolic bumps like Kings, Foxes, SAWs, etc, are valved and can be rebuilt. You can set them from 100 to 400 psi depending on your setup.
    I rode in a truck with light racing jouce rear bump stops and my back hurt like hell after the ride.
  7. Jun 3, 2012 at 4:39 PM
    PLC721
    Patrick
    Chandler, Az
    maybe it didn't have long enough ones? i was more specifically looking for the front tho, well the rear too potentially
  8. Jun 3, 2012 at 4:42 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    length of travel doesnt matter, it is the way it is charged/valved.
    Hydro bumps only have a little bit of valving, but it is the charge of the bumps that affects how hard they soak up the hits. I dont think you can change the psi on the jounce bumps.
    It sounds like you want the jounce bumps, buy them and give us a full review :)
  9. Jun 3, 2012 at 4:42 PM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
    Either will work fine.
    I'm running LR Bumps in the rear since I got them at such a good deal. They have served me well for what they do (they took awhile to get properly tuned tho). I don't think I'd recommend them for highspeed uses.
    Reg. Hydro/Air Bumps will be cheaper initially & depending on where you get the fab work done or if you do it yourself it could be fairly cheap. They will also hold up better for highspeed uses.
  10. Jun 3, 2012 at 4:43 PM
    theduck911
    Max
    Locked and Geared!
    Yes you can change the PSI in LR bumps as well as the rebound & compression at the turn of an Allen key.
  11. Jun 3, 2012 at 4:44 PM
    PLC721
    Patrick
    Chandler, Az
    I'm thinking jounces for the front and hydro's in the rear, this is all down the road tho.
  12. Jun 3, 2012 at 4:44 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    really? then how come you cant tune them to work at high speeds? They sound pretty good then
  13. Jun 3, 2012 at 4:56 PM
    theduck911
    Max
    Locked and Geared!
    You can tune them fine for highspeeds more for the high heat issue & the durability of the internals that I see as the problem. Mike (Defined) does well with the Donahoe Chubby's (essentially the same) on the rear of his truck tho.
    Not a bad plan, but it'd probably be cheaper just to run hydro bumps on all four corners :cool:
  14. Jun 3, 2012 at 7:28 PM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    That was also with my midtravel rear, LR's PSI was really low, and it was in Barstow :eek:
    As mentioned above Mike and Defined has them on this truck and does well with them. I have high hopes for mine once my rear is complete and can start tuning them.
  15. Jun 3, 2012 at 7:30 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    sounds like they're pretty cool then.
    My buddy Anthony250 has OEM replacement rear leaf pack and mid travel shocks with SAW 2.0 bumps and he keeps up with me in Barstow and Lucerne
  16. Jun 3, 2012 at 7:30 PM
    theduck911
    Max
    Locked and Geared!
    It's like anything, that goes without proper tuning :cool:
  17. Jun 3, 2012 at 7:31 PM
    PLC721
    Patrick
    Chandler, Az
    after going out a few times with my new front the rear is the weak link, but i haven't don't my shock hoops yet, plus when i get a bumper, tire carrier and carry my spare, the weight might help smooth the expos out as well.
  18. Jun 3, 2012 at 7:33 PM
    theduck911
    Max
    Locked and Geared!
    Don't want to burst your bubble, but without an extra 200lbs+ over that it won't exactly be a "smooth ride"
  19. Jun 3, 2012 at 7:36 PM
    PLC721
    Patrick
    Chandler, Az
    we may have different expectations because i don't consider it bad right now :confused:
  20. Jun 3, 2012 at 7:36 PM
    lembowski
    Rolando, CA
    Jeeper Creeper
    Yup
