Air bumps
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12TRDTacoma, Mar 27, 2014.
  1. Mar 28, 2014 at 8:55 PM
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    4544 lbs in front? That's how much the entire truck weighs, front and back. How are you getting all that weight to the front?
    I'll look into wheel studs. That's a great idea. As far as bumps go. I may have to look into those LR jounce bumps. I hear those are somewhat harsh over other hydro bumps though.
  2. Mar 28, 2014 at 9:04 PM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    6)King 2.5 secondary bypass with the last stage tuned as a bump zone.
    There are no more angles, conversations or arguments to made from this statement period!
    Simple fact is bumps are not needed with A) proper valving and B) a bypass setup properly.
  3. Mar 28, 2014 at 9:14 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    According to Username the need for a secondary shock is not required. Some moderate valving and a jounce shock should do the trick. I actually am leaning more towards his statement then yours about the requirement for a bypass. There is a couple ways to skin a cat after all.
  4. Mar 28, 2014 at 9:58 PM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    You do understand physics right?
    If you take a 1000 lbs and toss it at something at 100 MPH it is a little more than a 1000 lbs at the time of impact.
    So.....when you jump and hit the ground your weight is multiplied.
  5. Mar 28, 2014 at 10:05 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I thought of that after the fact. All the weight shifts to the exact spot of impact multiplied due to the inertia. Got it.
  6. Mar 28, 2014 at 10:55 PM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    "harsh". Hmm. No sir. They are infinitely adjustable. If you turn out the screws they aren't harsh in any way. If you cram 500psi in them and crank the compression screw in, I'm sure they are harsh.
    You don't need either one really, but secondary shocks of any kind (bumps or bypass) allow you to have a smooth street ride and take some stress off the main coilover. It has to do less work. Less work= less heat. In your situation, I thought jounce shocks would be a good fit. Of course, it will not be competitive with a well designed long travel system with a bypass, but it will get the job done. To really do it right costs about half a million bucks. How fast can you afford to go? lol
  7. Mar 29, 2014 at 12:39 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    I would use the money on an engine cage, engine mount gussets, coil bucket gussets, and long travel (front and rear) before putting air bumps up front.
    Your coil buckets are probably already bent. The stock LCA is not built to withstand repeatedly jumping the truck.
  8. Mar 30, 2014 at 2:29 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    The coil buckets are fine. I just aligned this beast and I believe my UCA or LCA may be slightly tweaked on the drivers side though. Only reason I say that is because before I was not able to reach a 0 camber situation on my drivers side tire where now, I am at a -.1 on camber, which I'm perfectly okay with anyways.
  9. Jun 7, 2014 at 6:42 AM
    BBtacosurfer
    BBtacosurfer Well-Known Member
    Dave
    ID
    MGM 2012 4x4
    All kinds of awesome info in here! Roberto, what did you decide to do for bumps?
  10. Jul 3, 2014 at 8:26 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Dave! I had no idea you ever even chimed in here! Looking through my more recent posts I stumbled into this one again. :D better late then never!
    I ended up going with Fox 2.0x2 air bumps for the front, with synergy bump cans to mount them on. I should be receiving them in on Tuesday and I'm going to have Jerry mount them on up for me. I'll be adding a 1/4 thick plate on the LCA for proper strike padding made by Synergy as well. Jerry or myself will have to cut it on one end to make it work, but it offers a lot of strike surface. I picked all of it up from Poly Performance for about $400. I can't wait to get them on and really start tearing it up out there!
    As for the rears I'll eventually get to mounting some air bumps as well, but in the meantime, the full size Silverado Polyfoam bumps will and have been sufficing. The rear end is much lighter then the front anyways.
  11. Jul 3, 2014 at 8:40 PM
    Large
    Large Red
    If I was going LT (or plan to jump the truck) there is no doubt I would go this route first, I would also reinforce the frame in the front and fully box the rear.
