Air coming out the vents with dial set to off?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JacksTurdGen, Apr 14, 2019.
  1. Apr 14, 2019 at 7:07 PM
    JacksTurdGen
    JacksTurdGen [OP] 2018 double cab short bed
    third gen OR
    When my a/c dial is set to off, air still blows out the vents at all times. Can't shut it off completely.
    I can adjust the temp of that air with the hot/cold dial.
    Is that normal? Can I make it stop?
    Do not have premium pack. 2018 model.
  2. Apr 14, 2019 at 7:09 PM
    FFBlack
    FFBlack Well-Known Member
    2019 TRD OFF ROAD
    Hit the recirc button with everything off and it wont blow any air at all.
  3. Apr 14, 2019 at 7:10 PM
    jp_flynavy
    jp_flynavy IG: @TrailLimoOverland
    2015 Tacoma DCLB
    I am pretty sure that happens to all vehicles. It does it on my 15. You can select recerc button, that might isolate outside air ramming into the cab.
    Taco_Craig and abhamber like this.
  4. Apr 14, 2019 at 7:12 PM
    CouchlessPotato
    CouchlessPotato Handcuffed to steering wheels still won firefights
    Zach
    You don't buy a truck for its fucking fenders!
    2.5" lift w/35's
    My truck does it too
  5. Apr 14, 2019 at 7:13 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    The 'off' setting turns off the blower motor, but doesn't physically block the air flow. What you feel is basically "wind" from the front of the truck (where the vent intake is) while you drive down the road. You shouldnt feel anything if you turn on the recirculate function as others have said (or if the truck is stopped)
    AKGSD and Jojee117 like this.
  6. Apr 14, 2019 at 7:13 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    close the vent flaps
    CusterFan likes this.
  7. Apr 14, 2019 at 7:19 PM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    And problem solved.
  8. Apr 14, 2019 at 7:20 PM
    OgE
    OgE Member
    Omar
    2017 TacomaBBPTRDSportDC
    mine does the same thing tho its very little amount of air that it doesn't bother me.
  9. Apr 14, 2019 at 7:47 PM
    cricketfire46
    cricketfire46 If it ain't broke, I can change that TTC#231
    Daniel
    Gilmer TX
    2019 DCLB OR
    I've never owned a vehicle that does this but I kinda like it... The recirc button stops it though
    Taco_Craig likes this.
  10. Apr 14, 2019 at 8:48 PM
    BillsSR5
    bill
    2014 SR5
    El Duderino[QUOTED] likes this.
  11. Apr 14, 2019 at 8:49 PM
    Fearthisbeard
    Fearthisbeard Well-Known Member
    Josh
    Gilbert AZ
    Taco
    Hit the recirculation button and it will stop the air coming through
  12. Apr 14, 2019 at 8:57 PM
    AxisCab
    AxisCab Well-Known Member
    Dave
    Bumville, or some dam place
    2018 2.7L 2WD Auto6, utility Axis Cab
    firewood scratches, Labrador hair/slobber, American flag sticker, Total Chaos bed stiffener, Scepter H20 can, onboard air
    "Is that normal? Can I make it stop?"
    I see this as a deep seated psychological-automotive crisis. You will need intense 70's music therapy to come to terms with your subconscious Toyota angst:
    https://www.youtube.com/watch?v=GoyLmJfYZ-8
    bigmw likes this.
  13. Apr 15, 2019 at 12:10 AM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Ummm......stops you from suffocating?
    Cars are required to have a certain minimum amount of airflow, even when everything is “off”. It avoids the hazard of an exhaust leak under the cab from gassing the occupants while driving.
  14. Apr 15, 2019 at 12:49 AM
    naked farmer
    naked farmer Well-Known Member
    Nor Cal
    ‘17 B.Red Off Road
    Does recirculation and non recirculation air get run through the cabin filter?
  15. Apr 15, 2019 at 9:06 AM
    methodtim
    methodtim I eat a lot of salsa
    Umm... really?
    California
    17 TRD Off-Road DCLB
    Aftermarket radio knobs, woot!
    Are they? The Audi’s that I own default to no airflow unless you turn on the fan. There’s no option to leave the fan off but the vents open like there is in all the Japanese cars I’ve owned.
    AxisCab likes this.
  16. Apr 15, 2019 at 9:14 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    All my Toyotas did that. As said above, you can use recirculate to slow it down- farts last longer that way.:D
    AxisCab likes this.
  17. Apr 15, 2019 at 9:16 AM
    OnHartung'sRoad
    Yes.
  18. Apr 15, 2019 at 9:17 AM
    AKGSD
    AKGSD Warranty denied
    Joe
    Alaska
    2019 QSDCSBTRDOR4X4V6MT
    Dog hair, metaltech 4x4 rocksliders, KBVooDoo bed risers, Smittybilt RTT, 3” spacer lift (Removed!), caliraised ditch lights, amazon rock lights, OVtune, Skewp
    I would guess recirculate would not run through the filter, though I've not seen an exploded diagram of the Tacoma's HVAC box.
    And as others have said, it's just the speed of your vehicle pushing air into the cab via the fresh air entrance into the HVAC box. Almost all cars do it, the extent is dependent on the HVAC design. I like it, personally. Don't have to have the fan on all the time, unlike my old Silverado.
    Setting the climate control to recirculate will shut off airflow from outside the cab, and instead "recirculate" air from within the cab (typically from the passenger footwell). Do note that this can lead to condensation blocking your view out the windows, depending on temperatures and humidity
  19. Apr 15, 2019 at 9:22 AM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    I just turn the knob so the air is directed to the floor vents if I don't want it blowing on me.
    Toyota09 likes this.
  20. Apr 15, 2019 at 11:48 AM
    nomnomtaco
    nomnomtaco Well-Known Member
    2019 Black Tacoma Limited
    Hot Stock
    This is one of the best features of the truck.
    Need to change the temperature? No problem. Turn it back on 1. Set Temp. Turn it back off.
    Need to keep the windshield defrosted? Change to defrost Mode. Turn it back off. Crack open the rear window.
    Save your motors and cool down your engine.
    Let physics work for you.
