air compressor advice
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tall_paul, Nov 2, 2016.
  1. Nov 2, 2016 at 10:26 PM
    0210
    0210 Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
    All the specs I've mentioned have been at 0 PSI. It seems the "degradation" at higher PSI is roughly proportional (unit A is 30% higher than unit B at 0 PSI, and is still ~30% higher at X PSI).
    For permanently mounted, ARB's CKMA12 for $275USD shipped on Amazon seems like a value winner to me, but that's assuming the specs they list on their site are accurate (their Amazon listings all show different - lower - specs for the same units).
    For portable, I'd go w/ the Viair 400P. Will almost certainly pick this one up soon.
  2. Nov 2, 2016 at 10:26 PM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    I would never mount an air compressor in the engine bay. The air in the engine bay is heated and the compressor will intake hot air. This will heat the compressor and give you inaccurate pressure readings when filling. Bad idea
  3. Nov 2, 2016 at 10:35 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    lol, it wont matter, the air coming out of any of these is already hotter then the ambient air temp inside the engine bay. dont believe me? go grab the hose coming out of the head of the air compressor.
    the only bad thing could be a shorter life of the air comp due to the hotter temps for its whole life. however, i can say i have had arb pumps mounted under the hood for 10+ years with never an issue on any of them.
    forty2 likes this.
  4. Nov 2, 2016 at 10:37 PM
    0210
    Vancouver, BC
    I saw someone mount a portable compressor in the larger (driver's side) bed cubby. That's what I would do, too. From there you'd pull out the hose to the tires.
  5. Nov 2, 2016 at 10:44 PM
    Z50king
    Eric
    Southern California
    Stock and loving it
    I was thinking of mounting under the bed if I ever mount something. I just have an 88p that I keep behind the rear seat. Plugging it onto the battery and taking it in and out isn't that bad. I only air down once a month, tops, usually
    please read and revise your comment
    https://en.wikipedia.org/wiki/Newton's_law_of_cooling
  6. Nov 2, 2016 at 10:55 PM
    RyanL
    RyanL Well-Known Member
    Indiana
    15 TRD Pro, supercharged, BP-51s, etc
    +1 to the comments above: if you're not adding lockers, keep it portable.
    I love my Viair and for sure won't mount it. I've pulled it out to help other people's rigs, bikes, etc. Then it stows right back under the rear seat.
  7. Nov 2, 2016 at 11:22 PM
    ahkouchi
    ahkouchi Well-Known Member
    Andrew
    Big Island Hawaii
    2016 Magnetic Gray Metallic Tacoma
    Front Elka 2.5 non resi with 650lb spring Rear Serviceable 5160's with AAL 265/75/r16 BFG KO2
    I have the 300p. Love it. I got it from the Amazon warehouse deals for $111 with free shipping. Always check amazon warehouse for shit. I got my 5160's for $100 each too. pretty amazing stuff. all stuff from warehouse is free shipping.
  8. Nov 3, 2016 at 12:56 AM
    jameshartman69
    jameshartman69 Well-Known Member
    Jim
    2016 Tacoma TRD
    As soon as I get all the parts together I am putting a 2nd Optima, VIAIR and dual charging setup in my cross bed tool box with mounted switches and air outlets in the box.
    0210 likes this.
  9. Nov 3, 2016 at 3:10 AM
    vinkon235
    vinkon235 Well-Known Member
    vince
    steubenville oh
    2016 white tacoma trdor access cab
    opt7 cree series fog lights busman aux relay box viair 450c oba opt7 fluxbeam led headlights
    tall_paul[OP] likes this.
  10. Nov 3, 2016 at 3:17 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Viair 450p works great
  11. Nov 3, 2016 at 5:51 AM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    Eh, just open the hood when in use.
  12. Nov 3, 2016 at 8:11 AM
    Z50king
    Eric
    Southern California
    Stock and loving it
    that's not going to help
  13. Nov 3, 2016 at 8:22 AM
    paranoid56
    San Diego
    14 double cab taco
    no need to revise, you obviously have never actually used any of these. you seem like a arm chair wheeler. which is fine. but having used these, after 1min or so, the head of my air compressor is already over 140deg F. weather its outside or under the hood. your discharge air temp isnt going to be noticeably hotter. now if you want to add aftercooler go for it.
    Also putting it under the truck is even a worse idea unless its protected from all elements (say in a box) but then thats even worse then under the hood.
    i feel you should just keep a nitrogen tank with you so you dont have all these issues you seem to have with air expansion due to heat lol
  14. Nov 3, 2016 at 8:56 AM
    SLOBRA
    SLOBRA LET IT EAT®
    Albuquerque, NM
    2012 DCSB 4x4 TRD O/R
    I've had the VIAIR 450p for about a year now and love it, all parts are surprisingly high quality. The quick connect hose is ridiculously long and flexible so I haven't needed to move the unit while in use, even reaches my trailer tires. Auto shutoff once it's primed, it's surprisingly quiet and the gauge is accurate. While not as fast as the 400p (1.8cfm vs 2.3cfm @ 0psi) its duty cycle is what sold me, 100% vs 33% @ 100psi so there are no worries about on/off cycles. I tow an offroad trailer and getting six 33" tires from 15psi to 35psi takes about 25 minutes of continuous running.
  15. Nov 3, 2016 at 10:25 AM
    #35
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    Wrong law.. you want to use the combined gas law which combines Charles's Law, Boyle's Law and Gay-Luccas's Law.
    Newtons law doesn't take into consideration a constant volume which drives pressure based off of temperature change. Yes pressure is proportional to temperature but its not as significant difference under pressure. You are literally talking about a 3 psi which can been seen on cold days to driving temp. So basically put 1.5 psi more air if you are pumping from under the hood if you are going from 15 psi to 30 psi to set cold tire pressure.
    I don't know about you but I can barely read most of the gauges with in 1 psi.
    lordetaco and swordfish like this.
  16. Nov 3, 2016 at 11:19 AM
    #36
    Woodrow F Call
    Colorful Colorado
    Why wouldn't it?
  17. Nov 3, 2016 at 11:24 AM
    #37
    bmgreene
    bmgreene Well-Known Member
    Brian
    L.A. Westside
    2010 PreRunner V6 SR5/OR
    Alcan Leaf Packs, OME884 Coils, 5100 shocks, U.S. Offroad Winch Mount w/Winch, Trail Gear Rear H/C Bumper, Prinsu Cabrack, DIY custom in-bed storage/sleeping deck, Sway bar delete, hidden "snorkel" intake mod, In-dash CB, Bestop Supertop, Undercover Swingbox, hood lifters, assorted lights and front spotting camera
    vinkon235 likes this.
  18. Nov 3, 2016 at 12:05 PM
    #38
    tall_paul
    tall_paul [OP] Well-Known Member
    Paul
    Denver, CO
    '16 DCSB OR M/T MGM
    This was well thought out. thank you for the input.
    This is a good idea. I like it. Does this fit under the rear seat? Considerably smaller than the 400p.
    Nice setup. What would you say your total cost/install time was? Happen to take any pictures documenting your install?
  19. Nov 3, 2016 at 1:56 PM
    #39
    ahkouchi
    Andrew
    Big Island Hawaii
    It might? Never tried TBH. Whenever I go OR I pack a container that has a tool bag with various tools I may need and I just throw the 300p in that container since it came in a handy little bag :). Also, just an FYI, the hose on the 300p also allows you to deflate your tires... I already had a ARB deflater though....
  20. Nov 3, 2016 at 4:00 PM
    #40
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
