Air compressor and AC bed outlet
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2flyfletchguy, Oct 27, 2020.
  1. Oct 28, 2020 at 11:34 AM
    Shellshock
    Iowa
    Yeah it’ll do fine, I’ve used it for that. It’s got plenty of PSI / CFM / Battery power. I’ve been using the 8 or 12 ah battery
  2. Oct 28, 2020 at 11:36 AM
    2flyfletchguy
    2flyfletchguy [OP] Well-Known Member
    Nathan
    2017 tacoma trd off road
    Would the AC oulet in the truck be good enough to charge the batteries?
    Boghog1 likes this.
  3. Oct 28, 2020 at 1:17 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    It will work. It will take some time. Recommend beginning with a full battery charge.
  4. Oct 28, 2020 at 1:31 PM
    wsbowden
    wsbowden Member
    Maine
    2024 TRD Off Road
    I have the same Makita compressor, the outlet in the bed will not power it.
  5. Oct 28, 2020 at 1:51 PM
    Shellshock
    Iowa
    They actually make a 12v battery charger. I’d go that route.. or just make sure they are charged at home before you leave.
    If you are going out for a day, I wouldn’t anticipate needing more than a battery worth of charge. Unless you are airing up a fleet of trucks.. or airing up and down 20 times.
  6. Oct 28, 2020 at 2:33 PM
    TRDs'nLegalese
    TRDs'nLegalese Member
    2020 TRD Off-Road 4x4
    I run a Husky brand portable compressor off my bed inverter to air up/down. Not elegant or terribly compact, but it works. Plus its portable, and it’s cheap enough that I won’t cry if it breaks. Whatever you go with, like others said, check the amp draw to make sure the inverter can handle it.
  7. Dec 24, 2020 at 11:56 AM
    Jaymerica
    Jaymerica Member
    2006 Toyota Tacoma TRD Sport
    Bone stock with a canopy.... with some plans in the works.
  8. Dec 24, 2020 at 3:11 PM
    kwill
    kwill Well-Known Member
    Why make this difficult? Get a compressor designed for 12V and be done with it.
  9. Jul 18, 2023 at 7:18 PM
    Billygoat33
    Billygoat33 New Member
    2020 Trd Pro
    Falken wildpeak
    I got this from Harbor Freight. It works great with the 400w plug.
    Bronxguy likes this.
  10. Jul 19, 2023 at 12:27 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    :rofl:
    Maybe on your Prius.
  11. Jul 19, 2023 at 12:31 AM
    OnHartung'sRoad
    That little guy only draws 2.6 amps at 120v- less than 400 Watts, it’ll work when your inverter is running at 400 watts.
    BoomerGVNG likes this.
  12. Jul 19, 2023 at 8:12 AM
    Bronxguy
    Bronxguy Well-Known Member
    Frank
    New York
    2021 Off Road
    I run the same set up, great for the beach
    Billygoat33[QUOTED] likes this.
  13. Jul 19, 2023 at 4:15 PM
    Trail_Limo
    Trail_Limo Well-Known Member
    G
    Land of fruits and nuts
    Turd Gen OR Limo
    buy once, cry once.
    ARB single portable compressor
    you can even find them used on ebay
