Air Compressor for the Garage
Discussion in 'Garage / Workshop' started by BassMaster06, Apr 7, 2014.
  1. Apr 7, 2014 at 10:00 AM
    BassMaster06
    BassMaster06 [OP] Well-Known Member
    Dan
    South Carolina
    2006 Double Cab V6 4x4
    Mods: sand, dog hair, roof rust
    Hey TW,
    I am looking into getting an air compressor for my garage. I want something reliable that will allow me to run air tools, like an impact wrench, spray gun, etc. I don't need anything too crazy, but I want something that will get the job done. Sears sells a Craftsman 26 gallon 5.5 hp for around $300 but it doesn't have the best reviews. Would like to keep it in that price range, give or take. Any recommendations?
  2. Apr 7, 2014 at 10:32 AM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    I think that is what I have. Mine might be 33 gallon. Mine runs everything I have except my die grinder. It runs it, but it is always on to keep up. Looking back I would have got something bigger, but I just use my electric angle grinder more.
  3. Apr 7, 2014 at 10:34 AM
    Smoke
    Smoke Well-Known Member
    Eastern Ontario
    2006 SR5
    Wait for a big one to go on sale. TSC here in Canada was selling a 60 gallon for 349$ a while back. Thats what you'll most likely want.
  4. Apr 9, 2014 at 2:45 AM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    Mine is a craftsman probably about 15 years old. Has always performed well. Granted I am not a heavy user but I have no complaints.
  5. Apr 9, 2014 at 3:57 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Air tools, spray gun, etc. take allot of cfm. I wouldn't go smaller than a 60 gallon 230v compressor and personally would go big with an 80 gallon two stage compressor which I plan on doing some day.
  6. Apr 9, 2014 at 6:48 AM
    moto932
    moto932 What's the matter, Colonel Sandurz? CHICKEN?
    Eric
    Dayton, Ohio
    04 TRD Off Road
    Basically stock. OME 882s, HD Dakars and nitrochrgers, TG front bumper, custom rear bumper, 4Xinnovations sliders, RAT skids, Softopper, 255/85/16 ST MAXX's on 16" steelies, 1" B.O.R.A. wheel spacers Scangaugae II, deck plate mod, grey wire mod,ECGS bushing, diff breather relocation, alarm mod, defrost w/o compressor mod, de-badged, sockmonkey beside decals.
    My craftsman 12gal compressor is a pile of shit. Its maybe 5 years old now. Within 2 years with very minimal use the head gaskit had to be replaced. Now it can barely reach 100psi if i let it run forever. Smells like its burning up by bthe time it gets there. current craftsman = junk
  7. Apr 9, 2014 at 6:58 AM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Check Tractor Supply.
  8. Apr 9, 2014 at 6:58 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Whatever you get, make sure it is belt driven. Those direct drive, oilless compressors are stupid loud.
  9. Apr 9, 2014 at 8:48 AM
    BassMaster06
    Dan
    South Carolina
    I'm not too concerned about the loudness. Functionality is what I'm after. I will be using it for rotating my tires, freeing up stubborn bolts, etc with the impact. Down the road I'd like to get a spray gun for painting decoys, jon boats, etc. I'd prefer to get a unit that puts out no less than 5 cfms, but id also like to move it easily if I need to (wheels). Trying to keep it under $400. I've seen several 25-30 gallon compressors that will seemingly fit my needs. I've looked at the Dewalt, Husky, and Craftsman so far, found mixed reviews on all.
  10. Apr 9, 2014 at 9:36 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    It's all about CFMs. You need to decide what you'll be using the compressor for. If you plan to use a spray gun, you'll need a bigger compressor. Most HVLP's consume a healthy 10-14 CFM and you want to have a compressor that is bigger so that it isn't running constantly when spraying as you'll get quite a bit of moisture in the air which then requires really good filters. For an impact gun, the size/price point is good enough. Other things to think about are power and mobility. Bigger compressors for a home shop run best off 220V and are stationary. You then have to plumb your area with drops. Keep in mind that noise will be a consideration when it's kicking on and off constantly. I have mine in my unfinished basement so that it's away from the attached garage when I'm out working on the car/truck. It's a 3HP, 220V, 80 gallon very old sears unit - about 40 years old. It puts out 15CFM at 90psi and I have sprayed cars with it with a Deville-Bliss gun that consumes 12.5CFM. I wouldn't consider any smaller compressor that than for my spray gun. Finally, consider Craigslist too.
  11. Apr 9, 2014 at 9:58 AM
    BassMaster06
    Dan
    South Carolina
    Good info, thanks for all the replies
