air compressor in bed of truck
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kinkrider101, Feb 10, 2010.
  1. Feb 10, 2010 at 7:46 PM
    kinkrider101
    kinkrider101 [OP] Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    is there air compressors that will work with the outlet in the bed of the truck
  2. Feb 10, 2010 at 7:53 PM
    tonto340
    tonto340 Well-Known Member
    Gambrills, MD
    The only one I've found is a Craftsman Model # 75117.
  3. Feb 10, 2010 at 7:55 PM
    xodeuce
    xodeuce mmmmmmbourbon.
    Alabama
    2004 UZJ100
    How much do you need in the way of CFM? I'd think a 12v job and small tank would be the way to go.
  4. Feb 10, 2010 at 7:56 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    Most portable compressors are 12v DC.
    Even the smallest 120V ac compressors (2 HP, 10 amp, 5 gal) will draw over 1200 watts, which is way more than the AC outlet will allow.
  5. Feb 11, 2010 at 9:25 PM
    kinkrider101
    santa barbara
    wheels and tires
  6. Feb 12, 2010 at 2:19 AM
    DDD
    Derek
    Santa Clarita, CA
    It doesn't say how many amps it draws. You need to know the amps or watts to know if the inverter in the tacoma has enough power.
  7. Feb 12, 2010 at 5:30 PM
    spp
    spp OC, Kalifornia
    OC California
  8. Feb 12, 2010 at 7:46 PM
    tonto340
    Gambrills, MD
    The compressor I mentioned above is a 120 volt Craftsman model which draws 3.3 amps which equates to 396 watts using the formula, watts = amps x volts.
  9. Mar 6, 2010 at 3:49 PM
    TheMaster
    TheMaster Born to Ride
    Chicky Baby
    NY
    2007 DC TRD Sport
    Bug shield, window visors, skid plate, rust proofing, tonneau cover, paint & upholstery protection, side step bars, navigation system.
  10. Mar 6, 2010 at 4:16 PM
    TheMaster
    Chicky Baby
    NY
    2007 DC TRD Sport
  11. Mar 6, 2010 at 5:04 PM
    JKD
    JKD Well-Known Member
  12. Mar 6, 2010 at 5:29 PM
    kinkrider101
    santa barbara
    wheels and tires
    thank you
  13. Mar 6, 2010 at 7:26 PM
    TheMaster
    Chicky Baby
    NY
    2007 DC TRD Sport
