Air Compressor Issue
Discussion in 'Garage / Workshop' started by Buckaroo1993, Jul 31, 2018.
  1. Jul 31, 2018 at 6:44 AM
    Buckaroo1993
    Buckaroo1993 [OP] Who?? ME??
    Vinny
    Georgia
    2003 3.4L BSP DCSB TRD OFF-ROAD/SR5 4WD
    17x9 HELO HE878 with Hankook RF10 DYNAPRO AT-M LT275/70R17 RCD/Billie's Front and Rear with OME 883's and HS Progressive AAL Resulting in 3"+ Lift LR SPC UCA'S Diff Drop K&N Cold Air Intake LED's Exterior/Interior
    Got a CH 5HP 20 gallon compressor that will, most of the time, build pressure to around 150psi and when I drop the pressure on it, it, as it should, turns on then shuts down at around 80psi. If I unplug it and let it sit, I can turn it back on and it will pressure back up but not always back to 150psi. Should I replace the internal breaker?
  2. Aug 1, 2018 at 9:50 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    sounds more like a pressure switch.
    bagleboy likes this.
  3. Aug 1, 2018 at 11:15 AM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    My first thought as well. If the breaker were bad you'd be resetting it frequently.
    wilcam47[QUOTED] likes this.
  4. Oct 1, 2018 at 7:39 AM
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    On my 2nd CH 60 gallon upright, 3.2 HP, (the first one lasted 25 years with no issues) and the 2nd one is about 4-5 years old and no issues at all when turning it on or off and maintaining the same pressure..
    shakerhood likes this.
  5. Oct 1, 2018 at 8:13 AM
    Buckaroo1993
    Vinny
    Georgia
    Got it figured out a while back. Dirty air filter. Cleaned it and works fine since.
    wilcam47 likes this.
  6. Oct 1, 2018 at 9:28 AM
    Tactical_Panda
    Tactical_Panda Armchair Anarchist
    Tim
    Fredericksburg, VA
    2015 Tacoma Double Cab, Off-Road Edition
    AJT Designs Shifter AJT Designs Battery Hold-Down ARB Awning 2500x2500 ARB Twin Compressor w/ Slee Offroad Mounting Bracket Avid Brush Bar Avid Step Bars Black Rock Wheels Series 997 Type 8 Circuit Breaker/Relay Panel Custom TRD Decals Bulletproof Fabricating Raptor Grill Bulletproof Fabricating Cooling Panel Bulletproof Fabricating Tow Hook Duluth Trading Company Dog Hammock Exhaust Breather Mod eBay Special 3-Gallon Air Tank Expedition Essentials TPAM EZ Down tailgate damper Flagpole Mounts, Dual Foglight Mod Front Camera Rear Camera; full time available General Grabber tires Goat Armor Hella Supertone Horns Iggy Switch Panel Icon Dynamics Stage 3 Suspension Katskin Leather Interior KickAss camp shower LED Bed Lights LED Interior Lights Midland MXT275 GMRS Two-Way Radio OEM Audio Plus Reference 500 audio upgrade Plano Cases. 42" roof mounted, X2 Pop-N-Lock Tailgate Handle Prinsu Cab Rack Prinsu-like Shell Rack Redline Tuning Hood Struts Rigid Industries 40" Light Bar Rigid Industries Ditch Lights Rigid Industries Spotlights Toyota Bed Step UltraGauge EM Plus v1.4 Vixen Air Horns, Four-Trumpet Whole bunch of decals worth about 5HP each Yakima Road Shower, 10-gal
    FWIW, I have a 30gal Craftsman tank, and I've noticed that it will "fill up" to different PSI levels depending on the weather, the temperature, the relative humidity, etc.
