air compressor opinions......
Discussion in 'Garage / Workshop' started by tacomaman06, Jan 5, 2010.
  1. Jan 5, 2010 at 9:04 PM
    tacomaman06
    tacomaman06 [OP] Carolina Alliance: Enforcer
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    getting a compressor for the garage pretty soon...and narrowed it down to 2.
    first i was looking at this one.......
    http://www.lowes.com/lowes/lkn?action=productDetail&productId=221580-14989-LLA4508065&lpage=none
    one by kobalt at lowes. 80 gallon,
    and then i found out i get a work discount, so im looking into this ingersoll rand SS5L5.........and i can get it for around $625. has some pretty nice reviews too.
    http://www2.northerntool.com/air-compressors/electric-powered-air-compressors/item-1592047.htm
    im pretty sure a 60 gallon compressor will do all i need it to do at the house...even working on cars/trucks....running impact guns and such.
    what ya'll think?? i think the ir is probably a better deal, and even tho its smaller...probably alot better quality than the kobalt.
  2. Jan 5, 2010 at 9:08 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    x2
    As I'm sure you know, IR has a good rep in air compressors. It may be smaller, but I'd think the quality would be better.
  3. Jan 5, 2010 at 9:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I gotta throw a vote to the IR....They are great compressors.
  4. Jan 5, 2010 at 9:11 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Definitely go with the IR. It is more industrial, more durable and runs off of a single large piston instead three small ones. The IR is comparable to the recips that we run at work.
  5. Jan 5, 2010 at 9:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Looks like the IR has a higher CFM than the other one too....
  6. Jan 5, 2010 at 9:12 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Actually, I think that model has a 2 piston unit. Its a paralell set up.
  7. Jan 5, 2010 at 9:15 PM
    4low2go
    4low2go Well-Known Member
    Coatesville, PA
    10 RC 4x4 5sp MGM
    Curt hitch, OBX Shift
    IR makes great compressors. Have a 175psi two stage 5hp 80gal, had it for about 5 years, and it runs like a champ. I usually have it regulated down to 100psi, and then increase the pressure when needed, like for a difficult balancer bolt.
  8. Jan 5, 2010 at 9:16 PM
    afd23a
    The Dynamo of Dixie
    The IR looks like it has a 3 year warranty if you get the startup kit (synthetic oil) which is as good a warranty as the kobalt if that's of any concern. The reviews of it on the NT website are really good too.
  9. Jan 5, 2010 at 9:19 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
  10. Jan 5, 2010 at 9:19 PM
    kroggy
    kroggy Well-Known Member
    Idaho Falls, ID
    04 TRD 3.4 4x4
    Grill Guard. PIAA 520's. And ...
    buy a new house and have to fill it up? Looks like the IR is a smokin deal for you, but what do you need all that compressor for.
  11. Jan 5, 2010 at 9:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  12. Jan 5, 2010 at 9:22 PM
    TacoNut
    Adam
    Denver, Co
    WEll I have no experience with either of them and am just being a good post whore......
    and ummm, screw it
    I keel you!
  13. Jan 5, 2010 at 9:22 PM
    xodeuce
    xodeuce mmmmmmbourbon.
    Alabama
    2004 UZJ100
    I just bought a Husky 60 gallon this past weekend. It's a repainted / rebranded Campbell Hausfeld, and I'm pretty sure the Kobalt stuff is too. I was in Tractor Supply and looking at the CH units, and the one that's 399 is the exact same as my Husky that was the same price. The IR units were out of my price range, but they sure look nice!
    I plumbed mine in the basement / garage / shop area with all 1/2" galvanized pipe and used a 24" long 1/2" hydraulic hose rated for 2000 psi as the link from the galvanized union to a shutoff valve on the compressor. That way vibration in the line is minimized and we don't feel it in the floor in the house above.
  14. Jan 5, 2010 at 9:23 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    ive run an impact gun on a 2.5 gallon compressor no problem
    60-80 should do you just fine
  15. Jan 5, 2010 at 9:23 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    oh nO YOU DONT!!
  16. Jan 6, 2010 at 3:40 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i could probably get something smaller....but no point in doing so, since eventually im gonna put a lift in the shop and already have work plans for it. and $630 aint bad at all.
    i think im gonna go with the 60 gallon ir.....hellava deal and the reviews are awesome!
  17. Jan 7, 2010 at 6:55 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    I've got a Harbor Freight 25 gallon (forgot the HP) I have had for about 4 years...still runs like a champ. I have used it to paint multiple cars and use it for all sorts of tasks. I feel like I have gotten my money's worth at this point. I only paid like $200 for it.
    I am going to buy a pancake compressor sometime in the near future for quick projects since it takes a while for the big one to fill up. I always empty it when I'm done to prevent rust from condensation in the tank
  18. Jan 11, 2010 at 8:05 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    I bought a Craftsman (Sears) 30 gal. 1.5 hp compressor in 1997 and it still works great.
    To this day I have done no maintenance to it other than draining the condensation from the tank every few months. BTW, it has a oil less motor.
