Air compressor question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mademan925, Oct 21, 2013.
  1. Oct 21, 2013 at 11:55 AM
    Mademan925
    Mademan925 [OP] Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
  2. Oct 21, 2013 at 12:25 PM
    eazyrider711
    eazyrider711 Well-Known Member
    Jay
    Northern, CO
    Black DCSB T|X Baja
    I doubt its an issue with your power. It sounds more like an issue with CFM. The Amazon link listed a number as SCFM, so that's probably some fudged math to make it sound better than it is.
    I know I've been looking and have settled on this one.
    http://www.amazon.com/VIAIR-Automat...1382383409&sr=1-1-catcorr&keywords=viair+450p
    Its pricey which is why I don't have it yet :D but I think it will be really nice once I get it. If you're looking for speed, check out the CFM chart on Viair's website. Porter-Cable will probably have some similar charts on their site. It gives you the best measure of how much air a compressor can push.
    I think. ;)
  3. Oct 21, 2013 at 12:31 PM
    AR15xAR10
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    I still use the biggest slime brand compressor that walmart sells. It works fine. It is slow but for $60, who cares?
  4. Oct 21, 2013 at 12:48 PM
    Mademan925
    Nick
    Discovery Bay, CA
    My compressor is 120v at 10 amps so I need 1200w to run it. Is that correct? My bed outlet is only 400. what will I damage using something that needs more power than what will be supplied. I mean it worked so I just need to know what I would be hurting.
  5. Oct 21, 2013 at 12:53 PM
    lemons
    lemons LOCO 4X4
    Virginia
    07 TRD DC Offroad 4X4
    Icon coil overs W/King 14 inch 700lb springs and super bump bump stops, Allpro Expo leaf springs, Allpro Ubolt kit W/timbren Bump stops, Dif Drop Kit, Magnaflow Cat-Back Exhaust, Badges painted Rust-Oleum bed liner, Color Matched TRD Sport Grill W/Grille Craft Insert, TRD seat covers, Weather Tech Floor Mats, Flyzeye's , fog light anytime mod, ABS Off mod, ATO skid plates, ATO rear H/C bumper, BAMF sliders w/kick out, CBI front bumper, Engo 10000lb winch, Rigid D2 foglights, Piaa 510 fog lights, cobra CB w/firestix antenna, AFE snorkel
    I have tried pluging stuff in that I knew would be too much for the bed outlet and all it does is not work. As soon as you plug something else in that is sucking the right power it works fine.
  6. Oct 21, 2013 at 3:02 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    x2
  7. Oct 21, 2013 at 3:11 PM
    Mademan925
    Nick
    Discovery Bay, CA
    So because it works does that mean its ok?
  8. Oct 21, 2013 at 4:21 PM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Why would even try if it clearly exceeds the output of the outlet? More than likely, it will blow the fuse. The compressors that seems to work are the smaller 1 gallon tanks that only draws about 3 amps or less at 120v.
  9. Oct 21, 2013 at 4:26 PM
    Mademan925
    Nick
    Discovery Bay, CA
    I tried it because it's what I had. It didn't blow fuse. But I'll look into a one gallon one.
  10. Oct 21, 2013 at 4:36 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
  11. Oct 21, 2013 at 4:38 PM
    Mademan925
    Nick
    Discovery Bay, CA
  12. Oct 21, 2013 at 4:52 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Yes, it will cook the compressor motor those small compressors need RPM to make air. Surprised the inverter ran it.
  13. Oct 21, 2013 at 4:55 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    SCFM means flow rate at standard atmo pressure, corresponding to the 0 psi rating on Viair's web site. 2.6 CFM at 0 psi is better than most Viair pumps, actually. It is possible the Porter Cable pump may not be running at full speed due to the 400W limit. One way around it is to buy a bigger inverter that requires direct connection to the battery, like this 1600W unit: http://www.amazon.com/Whistler-Pro-1600W-Watt-Power-Inverter/dp/B003R7AJ4K/
    The 450P is rated for 1.66 CFM at 0 psi, but is designed to run constant-duty. For inflating tires on the trail, the 440P is more appropriate, being faster at 3.00 CFM at 0 psi: http://www.amazon.com/Viair-44043-VIAIR-Portable-Compressor/dp/B000X9BXQS/
    Me? I have a Viair 85P that plugs into the 12V outlet. It draws just over 15A, however, and blew my 15A fuse. I changed out the fuse to a 20A. :D http://www.amazon.com/VIAIR-85P-Portable-Air-Compressor/dp/B0036E9VB6/
  14. Oct 21, 2013 at 4:58 PM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    348 watts but that is not start current may trip the inverter on start up. I know the DC ones are slow why not buy an inverter you can hook to your battery and run your pan cake one? Probably close to the same price.
  15. Oct 21, 2013 at 5:48 PM
    Mademan925
    Nick
    Discovery Bay, CA
  16. Oct 23, 2013 at 9:30 AM
    eazyrider711
    Jay
    Northern, CO
    Black DCSB T|X Baja
    You're right, it was the 440P I meant to link. Still saving, LOL.
