air compressor suggestions?
Discussion in 'Off-Roading & Trails' started by a.s., Apr 17, 2011.
  1. Apr 17, 2011 at 7:26 AM
    a.s.
    a.s. [OP] Well-Known Member
    Stack
    NY
    Silver '07 DCSB Sport
    KO2s/5100s/Eibachs/TRD
    Smmertime is coming and that means I'll be driving on the beach to do some fishing. My routine has been the same for a few years- deflate the tires to 15 PSI, hit the beach, then get back on the road and drive 8 miles to the nearest gas station to fill back up to 32 PSI. This has worked fine except for the fact that the gas station detour adds 40 minutes to my return trip home. I also don't feel safe driving on the highway with such low pressure and my 2 year old son in the truck.
    I'm looking for a cheap air compressor I can throw in the back of the truck to re-inflate my tires after I get off the sand. I don't mean those little crappy emergency tire inflators that take 30 minutes per tire. I'd like something quick that can get all 4 of my tires to 30 PSI.
    Can you help me determine which compressor would work best for this simple duty? I have an '07 Tacoma with the outlet in the rear cab.
    Thanks in advance.
  2. Apr 17, 2011 at 8:17 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
  3. Apr 17, 2011 at 8:24 AM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
  4. Apr 17, 2011 at 9:40 AM
    singlefin
    singlefin Well-Known Member
    Hood River, OR
    Syncro
    I've been wanting a Viair 400p, but after seeing the MV-50 in use yesterday I think its a good buy for the money. Just decide your intentions for it....like are you going 10-40psi on each tire, want to use it if you have to at home to air a tire, loan it out on the trail? Check the amp draw and duty cycle. 100% duty cycle is perfect, but the most expensive choice.
    Viair is about 180 for the 400p kit
    Smitty Built is about 80 for the MV-50 kit
    *edit check this link on that article, interesting...
  5. Apr 17, 2011 at 9:57 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    MV90
    Puma 12v
  6. Apr 17, 2011 at 9:59 AM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    I've heard good things about the ARB air compressor. They are suppost to be able to run along time before they get too hot
  7. Apr 17, 2011 at 12:27 PM
    bridaw
    bridaw The light was yellow, Sir.
    Brian
    SoCal, East San Diego County
    10 DC 6-speed TRD OR 4x4 tow debadged
    tailgate hose clamp/washer mod ,disable seatbelt warning ,dealer tinted windows ,running boards ,DiamondBack SE bed cover ,OEM rubber bed mat ,TRD Japan shift knob ,bed rail corner reinforcement with angle brackets+square nuts ,Armor Tech Offroad mount for 60" highlift jack ,Scangauge II ,OEM roof rack ,BajaRack basket ,WeatherTech dark tint window deflectors ,removed mud flaps ,debadged ,stubby antenna ,D-rings - 4 in bed floor + 8 on the side rails ,cut four D-ring slots in bedmat ,secured ActionPacker 48 gal cargo box to bed ,center console lock ,relocated 7 pin harness ,Redline Tuning QuickLIFT Elite hood supports ,Pop & Lock PL5300 tailgate lock ,RAM A-pillar mounts for GPS and Drift HD170 camera ,RAM mounts on bajarack for Drift HD170 exterior shots ,relocated rear differential breather ,headrest iPad mount ,ImMrYo rear view mirror lift ,Panavise Indash mount ,265/75/16 BFG All-Terrain T/A KO on TKO black rims ,installed front and rear WeatherTechTacoma DigitalFit FloorLiners ,replaced interior/external lights with Jumpers LEDs +switchback mod +under hood light ,installed rcbs204 Illuminated 4x4 Switch ,installed left and right Relentless Off-road Fabrication hood hinge light mounts ,installed KB Voodoo's Powder Coated Tailgate Cap System ,installed front and rear Wet Okole seat covers ,made and installed mount for Trail Toys NSA Switch Panel ,did ND4's Fog Light Anytime Mod
    I bought the ExtremeAire 12 volt portable compressor about 6-7 years ago. I used it in my '99 Durango until I bought the Taco last year. It is just begging to be taken out of the tool box and mounted under the hood but until then it continues to serve just fine.
    It was in use again this last week on another Mojave/Sonoran desert trip. I use it to fill up our air mattresses as well as air up tires. It works so fast I don't dare walk away from the tire while airing up from 18 to 34 psi. It will overfill quickly if you aren't paying attention.
    It isn't cheap but it will last. Continuous duty cycle, 150psi max working pressure, 4 cfm free flow rate and it requires practically zero maintenance mounted in a solid box that protects the compressor and helps keep it clean. I've used it all these years in the desert and I still haven't had to clean the filter. It sits in the sun running the entire time while I air up all 4 and sometimes 8 tires. Toss it in the back of the truck and even toss gear on top with no worries. :)
  8. Apr 17, 2011 at 12:30 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Theres a new ARB compressor out, 100% duty cycle, just fyi.
  9. Apr 17, 2011 at 12:37 PM
    sierrahsky
    sierrahsky Expedition Style
    MINE! LOL
    I am going to be making some changes to my compressor set up in a few weeks and will probably switch and add a 2.5 gal tank to upgrade the one I have. THat thing sounds pretty awesome!
  10. Apr 17, 2011 at 12:38 PM
    barlowrs
    barlowrs Well-Known Member
    Robert
    So Cal
    06 Toyota Tacoma Sport 4x4
    Build Thread: http://www.tacomaworld.com/forum/builds/74926-barlowrs-06-taco-expo-build-thread.html OME Lift, FJ SE Wheels, 255/85 KM2, Allpro Plate Bumper, 8K Winch, Synthetic Line, Yaesu FT-8800R, Custom Sliders Sockmonkey bedside decals, BHLM, base model grille, TRD offroad (black) trim
    Check out Puma compressors. Not REALLY cheap (around $300 for complete setup including tank), but the best bang for the money by far. Essentailly the same compressor as Extremeair, and much less money...I love it, can do everything from air tools to simply airing up tires..quickly. Very high output (3.4 CFM), 100% dudty cycle, etc. Blows ARB, Viair, etc out of the water. Do some online searches (pirate, Ih8mud, etc), you will quickly see it is VERY highly rated and very few complaints. (its the hidden gem of the compressor world)
    1.5 gallon: http://cgi.ebay.com/PUMA-12-VOLT-1-...=310309608028&ps=63&clkid=8525295591768314899
    2.0 gallon: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=310309839048
    Here is my install: http://www.tacomaworld.com/forum/2nd-gen-tacomas/132817-oba-install-05-tacoma.html#post2582777
