Air compressors
Discussion in 'Off-Roading & Trails' started by Bisop, Dec 19, 2012.
  1. Dec 19, 2012 at 7:05 PM
    Bisop
    Bisop [OP] Active Member
    Andrew
    Bishop,CA
    '10 prerunner access cab sr5 trd off road
    3" Bull bar, trail fx 3" nerf bars
    What kind of air compressors does everyone use when off roading?
  2. Dec 19, 2012 at 7:45 PM
    Madjik_Man
    Colorado Front Range
    I use an MV50.
    Works great for the price.
    I have 31" tires btw
  3. Dec 20, 2012 at 10:50 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    On-Board air, or there are also portable compressors.
  4. Dec 20, 2012 at 3:44 PM
    Strautins
    Strautins Well-Known Member
    Nick
    SL,UT
    2019 TRD OR; 2011 TRD OffRoad TX Pro
    2019- 265/70R17 on methods, GFC to be installed: Yukon 5.29, ARB oba, snorkel. (Lift tires armor TBD) 2011- Retired:OME lift, Light Racing UCA, Demello Front, Demello sliders, Brute force rear, TX pro wheels, 285/75s, snorkel, M8000, ARB OBA, Century shell, Relentless skids, Cobra 75
    I have an ARB compressor mounted under the hood that I use to air up after offroading
  5. Dec 20, 2012 at 4:02 PM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    I use a portable home compressor that I plug into bed outlet.
  6. Dec 20, 2012 at 4:09 PM
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    I got the big smittybuilt. It works great for airing up. 265/75r16 from 15 to 40 psi in under 2 minutes a tire. Filling up a small tank is very fast from 1 - 70 psi, but slows substabtially 90 - 115. Over all a good deql since i paid $125 for it.
  7. Dec 20, 2012 at 4:31 PM
    Infra
    Infra Well-Known Member
    Az
    2010 MGM DCSB 4x4 TRD OR 6spd
    CBI Bushmaster 2.0 rear bumper with swing out tire carrier & fold down camp table, CBI Moab 2.0 front bumper, Warn M8000-S, Icon 2.5 RR CDC Extended travel CO's with 700lb springs, Icon 2.5 RR CDC rear shocks, Icon hydro bumps, Total Chaos uniball UCA's, All Pro Expo leafs, U-bolt flip kit, Softopper, diff breather mod, extended rear brake lines, Grillecraft mesh grille, Elusive Elements behind grille light bar with B.A.M.F. LED light bar brackets, okLEDlightbars.com 20" double row LED light bar, Relentless Fabrication hood cb antenna mount, Wilson Silver Load CB antenna, Uniden 520 Pro XL CB radio, Wet okole seat covers, Weather tech floor liners, Weather tech in channel window deflectors, trasharoo spare tire trash bag carrier, Box Rocket 2nd gen bed rack with (2) 2 gallon gas rotopax mounted on drivers side, (2) 2 gallon water rotopax mounted on passenger side, (1) 3 gallon gas rotopax & (1) 2 gallon gas rotopax mounted on CBI swing out, Avid weld on sliders, Mattgecko LED bed light
    Viair 300P portable air compressor, made for 33" tires
  8. Dec 20, 2012 at 4:40 PM
    Bisop
    Andrew
    Bishop,CA
    Thanks guys. I need to pick one today to put on my Christmas list. I think I'll end up going with the Viair 300p.
  9. Dec 20, 2012 at 4:46 PM
    Infra
    Az
    Good choice....it's been a great little portable compressor with 1 small drawback. It has alligator clamps to attach to the battery, and that cable is kinda short, when airing up I can only reach 3 tires. I intend to take my compressor to an electrical company and see if they can splice 3 - 4 feet of cable on there so I can easily reach all 4 tires.
  10. Dec 20, 2012 at 4:51 PM
    Zac808
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    You can prolly do it yourself. Home depot should have the stuff you need.:D
  11. Dec 20, 2012 at 4:59 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    C02 FTW! 33's filled from 15psi to 35psi in 15 to 18sec :cool: OBA is too slow for me and I can run air tools with no waiting at a full 90psi
  12. Dec 20, 2012 at 5:01 PM
    rsbmg
    rsbmg Well-Known Member
    Rob
    Vista,CA
    2011 Tacoma Doublecab TRD Offroad
    Front Aluminum bumper by Relentless Fab. Smittybuilt Winch Complete set of skids by ATO TC UCA's Fox Ext. Travel Front Reservoirs.
    Been eyeing this.........:spy:
  13. Dec 20, 2012 at 5:04 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    since you've already picked a compressor, i'll just ad this as a little trick that makes airing up a lot easier.
    a great little system to fill up all of your tires at the same time, and to the same pressure (no need to extend wires either) is to use a multiport manifold and multiple clip-on chucks.
    you can run hoses to each tire and the chuck clips on, so all you have to do is turn off the compressor once the correct pressure is reached. (make sure not to exceed your duty cycle)
    allows you to run hoses to one or all tires vvvv
    clips on to the valve stem for hands free airing up vvvv
  14. Dec 20, 2012 at 5:07 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    It's a beautiful thing! you can build your own for about $200 as well if you take your time gathering parts.
    only system i've ever seen fill tires faster than the CO2, was a massive belt driven compressor on an older land rover. he filled all 4 of my tires with a 4-way fill setup like i mentioned above, and filled his onboard tank, faster than CO2. crazy CFM :eek:
