Air Compressors
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ghostrider52, Jan 20, 2020.
  1. Jan 20, 2020 at 7:19 AM
    Ghostrider52
    Ghostrider52 [OP] Well-Known Member
    Nick
    Tampa, FL
    2020 Toyota Tacoma TRD Off-Road AV4
    6” Zone Suspension Lift 20” Fuel Rebel Wheels 305/55r20 Falken Wildpeak AT3W Tires
    Hi all,
    I'm new to off-roading but I have gathered that I probably need an air compressor for the times when I should air down and then have to air back up to get home. I wanted some opinions of good air compressors, keeping in mind that I don't want to spend 400 dollars for one when I'm a weekend warrior at best. Let me know your thoughts!
  2. Jan 20, 2020 at 7:43 AM
    jlemmond
    jlemmond Well-Known Member
    josh
    Monroe, NC
    2006 GX470
    Also curious about this. Been looking into various ARB offerings as well as other manufacturers. Still undecided as to what's "enough" for somebody that just gonna air tires back up every once in a while.
  3. Jan 20, 2020 at 7:53 AM
    LTG4087
    LTG4087 Well-Known Member
    LT
    DFW
    2019 TRD Off Road
  4. Jan 20, 2020 at 7:54 AM
    AZ_Tumbleweed
    AZ_Tumbleweed Well-Known Member
    Wilmington, NC
    2020 TRD OR DCSB Cement 4x4 AT
    I suggest an MV50 air compressor for around $70-100.
    Its been bouncing around in my Jeeps trunk for about 5 years now and dropped several times, still works perfect. Able to fill four 35" tires without overheating in the 110 plus degree sun in AZ.
  5. Jan 20, 2020 at 7:57 AM
    jlemmond
    josh
    Monroe, NC
    2006 GX470
    Def will be looking into these! Thanks
    strongrob likes this.
  6. Jan 20, 2020 at 7:57 AM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
  7. Jan 20, 2020 at 8:02 AM
    Blais03
    Blais03 Guess I'll bring a spare wheel bearing...
    Nick
    Easthampton MA
    '08 Reg. Cab 4WD + '06 Reg. Cab 2WD
    I just got a Smittybilt 5.65 CFM compressor and it seems really powerful! I bet with a tank this thing could run an air tool.
    Astr0Aar0n, ST77 and VE7OSR like this.
  8. Jan 20, 2020 at 8:03 AM
    jet speed
    jet speed Well-Known Member
    Ohio
    2017 TRD OR DCSB
    The Viair 300p is a great choice, I’ve used one for years.
    m603holden likes this.
  9. Jan 20, 2020 at 8:03 AM
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    Ensemble88 and m603holden like this.
  10. Jan 20, 2020 at 8:13 AM
    Ghostrider52
    Nick
    Tampa, FL
    I've been looking at the 300p and Smittybilt 5.65. Neither have any issues with bigger tires before cool down? I am running 305/55/r20 (33.5") tires and wanted to make sure they will do the trick. Leaning 300p as the connections aren't wonky as it appears the smittybilt is.
  11. Jan 20, 2020 at 8:15 AM
    m603holden
    Marteeen
    New England
    You won't have any issues. With it being a 20" rim there's not that much more volume than stock.
    Skydvrr likes this.
  12. Jan 20, 2020 at 8:27 AM
    Ghostrider52
    Nick
    Tampa, FL
    Would it be better to go with the 400p if I were considering going 35's on the 20" rim? Have been throwing that around once these tires wear out (will be a while obviously). Not sure there is a huge difference between the 300p and 400p
  13. Jan 20, 2020 at 8:32 AM
    m603holden
    Marteeen
    New England
    Just for reference you're tire has less volume than the common 265/75/r16 tire. I can run math for the 20s after.
    Really, I'd just say it's up to your financial situation. If you can swing the 400p and feel like you'll end up on 35's after then it's up to you.
  14. Jan 20, 2020 at 9:08 AM
    snozberries
    snozberries is forever trying to find a campsite
    Cory
    Martinez, CA
    2016 Quicksand
    Tires, Rack, LED bar, RTT, etc.
    Another vote for the 88P. Got mine last week and already used a couple times - filled up quick without issue. I cut off the stock fitting and replaced with a locking air chuck :thumbsup:
  15. Jan 20, 2020 at 9:19 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    The MV50 is a great little pump. I ran one of these for years. Used it to charge a tank for an airhorn in my old Chevy, then mounted under the hood of my Tacoma for the horn and for tires. On a summer day at the dunes it couldn't quite fill all 4 of my OEM 265/70r16s from 15 to 35 before shutting down and needing to cool off. I usually got 3 tires full and the last one up in the 20s. I'm betting if it wasn't in my engine bay, it would have got them all filled.
    I'm now running the ARB CKMA12, but that's nearly $300.
  16. Jan 20, 2020 at 9:24 AM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    Duty cycle is a key factor to look at when shopping for small compressors.
    I have a fast fill kit which has a 300C compressor and a 2gal tank. It has worked fine for several years:
    https://www.viaircorp.com/ask/ask200fastfill
    The compressor has a 100% duty cycle rating at 100psi. 50% at 200psi....
    However I scuba dive and have quite a few 80cf aluminum tanks. I also have old first stage regulators that I don't use for diving anymore since they can't be serviced any longer and they have IP creep. A tank and old first stage has been far more convenient for me for filling tires. You can get used tanks on craigslist and used regulators on ebay cheap. A 3000psi tank will last forever in this application....
  17. Jan 20, 2020 at 9:25 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    I too have been a fan of the MV-50. It never overheated for me, but mine was not in the engine compartment, either!
    It fills my 265/76-16 tires from 15 psi to 34 psi in just 3 minutes each. They are not too expensive, either.
    MSN88longbed and YF_Ryan like this.
  18. Jan 20, 2020 at 10:12 AM
    AZ_Tumbleweed
    Wilmington, NC
    if you do get one and find it overheats often and the cord is long enough, you can stick it on your drivers or passengers floorboard and max out the floor A/C to cool it down and stop it from overheating
  19. Jan 20, 2020 at 10:15 AM
    Woodrow F Call
    Colorful Colorado
    To be honest, I like the stock fitting better than the locking one. Locking ones are ok, but I like that the screw on is just promotes a positive engagement.
    snozberries[QUOTED] likes this.
  20. Jan 20, 2020 at 11:15 AM
    Fishnwiz
    Fishnwiz Well-Known Member
    Bill
    2019 Silver TRD ORDCSB 4x4
    Anybody try running a AC small compressor off the truck?
