Air Compressors
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ghostrider52, Jan 20, 2020.
  1. Jan 20, 2020 at 11:23 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    You talking about an AC Compressor on the serpentine belt under the hood, or an AC powered compressor on the 400w outlet in the bed?
  2. Jan 20, 2020 at 11:26 AM
    Fishnwiz
    Fishnwiz Well-Known Member
    Bill
    2019 Silver TRD ORDCSB 4x4
    On the bed outlet, small older one, don’t know if I can find the wattage info on it. Only thing I’ve run of the bed plug in is a shop vac and hedge trimmers.
  3. Jan 20, 2020 at 11:35 AM
    YF_Ryan
    Kent, WA
    did your vacuum work well? I've tried my little 1.5 gallon shop vac and it didn't have much suction. Looking it up now, it takes around 800 watts.
    You might be able to find a tiny AC compressor, but a cheap one that just has alligator clips to hook to your car battery would probably be much better.
  4. Jan 20, 2020 at 11:36 AM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    I don't know what Toyota uses for their inverter.... But inductive loads and DC inverters are generally a bad combination. Inrush current is usually large, 3-4x running current. And If the inverter isn't clean, the AC motor will get real hot, real fast.
  5. Jan 20, 2020 at 11:41 AM
    bot102
    bot102 The guy who ask a lot of questions
    Alec
    Castle Rock, CO
    2017 DCOR
    Beat up armor and broken stuff
    "Technically" speaking, just about any compressor will do just fine. It's all a matter of how fast do you want to air up.
    I got tired of the buddies I wheel with and their ARB Twins filling up all of the tires by the time I was wrapping up my second with my Harbor Freight pump. So I just got the ARB Twin. Plenty of "Dammit we're waiting on Alec again" shit talk lol
  6. Jan 20, 2020 at 11:43 AM
    YF_Ryan
    Kent, WA
    Wait til one of your buddies gets something like the Warn Powerplant... Seems at least 2-3x as fast as the ARB Twin.
  7. Jan 20, 2020 at 11:47 AM
    MSN88longbed
    MSN88longbed Sporty Shorty
    Goleta, CA
    2014 Single Cab 4x4, Auto, Blinding White
    Kings all around, Method 306, Cooper STT Pro 265 75/R16, JBL amp, Morel Speakers, Undercover tonneau, Alcan leafs, SOS sliders, RCI skids, SSO Slimline, Engo winch.
    I have this one and love it. Saved money for other things.
    Fishnwiz, David K[QUOTED] and YF_Ryan like this.
  8. Jan 20, 2020 at 11:56 AM
    bot102
    Alec
    Castle Rock, CO
    2017 DCOR
    All of them are wayyyy to cheap to buy something that expensive :rofl:
  9. Jan 20, 2020 at 11:58 AM
    YF_Ryan
    Kent, WA
    I just remember him hooking up the Warn, then his Twin arb, walking back to his tire being filled by the warn and it being WAY overinflated. He then proceeded to fill up a couple more tires while the ARB was still working on it's first.
  10. Jan 20, 2020 at 11:59 AM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    I got the ARB twin. Works like a champ. If it breaks I will swear like a drunk Aussie.
    WrecklessAbandon likes this.
  11. Jan 20, 2020 at 12:02 PM
    velogeek
    velogeek Well-Known Member
    Andrew
    Gilbert, AZ
    2024 4Runner
    Not remotely enough juice for the small pancake compressors (e.g. Dewalt) if that's what you're thinking. Those draw something like 10A@110v peak which is about 3x what the truck can provide.
    The ARB twin is the standard because it's easily mounted and ubiquitous in the market but I have a hard-mounted Viair 450C that has been dead nuts reliable. You can do a dual Viair setup if you need more flow while the ARB twin is already just two of the smaller ARB units in a single assembly.
  12. Jan 20, 2020 at 12:10 PM
    Rottencotton
    Rottencotton Well-Known Member
    Stinkin Rincon
    Superwhite 2019 Tacoma SR 4x4
    Or you could throw a refillable air tank in the back and call it a day.
  13. Jan 20, 2020 at 12:23 PM
    Fishnwiz
    Bill
    I have a 3 gal, seems to do ok, I just use it for my driver side floor, country living equals mud, gravel, leaf litter so I clean it every couple days. Usually about two three minutes with truck running.
  14. Jan 20, 2020 at 3:18 PM
    Fishnwiz
    Bill
    Just ordered on after looking at several
    AZ_Tumbleweed[QUOTED] likes this.
  15. Jan 20, 2020 at 4:58 PM
    #35
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Just make sure you don't accidentally pinch the air line while it's running! While stretching the coiled line going around the front tires, the tube pinched and blew the internal check valve. That was that.
  16. Jan 20, 2020 at 7:37 PM
    #36
    dclbYak
    dclbYak Well-Known Member
    19ssmDCLBtrdOR
    UncleBubs likes this.
  17. Jan 21, 2020 at 10:08 AM
    #37
    David K
    That plugs into a cigarette lighter... which means it will take several minutes per tire to inflate. There is just not enough power to be fast like the ones that clip directly onto the battery.
    I had a Coleman pump back in the 80s that plugged into the lighter. It took 9 minutes to add 20 psi to each tire (compared to about 3 minutes with the battery clip compressor). That was with 13" tires, too! Try the outlet in the Tacoma bed and see if it has enough amps to run the 110v option, I think not.
    I will be curious to hear what you find out!
    GillyLink likes this.
  18. Jan 21, 2020 at 10:26 AM
    #38
    WrecklessAbandon
    WrecklessAbandon They call me skippy
    Travis
    Olympia, WA
    Crocs with socks
    Buy once, cry once. This is the route I took as well.
    Pablo8[QUOTED] and GillyLink like this.
  19. Jan 21, 2020 at 10:39 AM
    #39
    Astr0Aar0n
    Astr0Aar0n Well-Known Member
    Portland, OR
    19' Tacoma TRD OR V6 4x4 DCSB cavalry blue
    Quite a few things at this point..
    If you're just going out occasionally, you could get away with just about any air compressor. It really comes down to how much time you mind spending airing back up, usually the more expensive the faster it'll go. I go out almost every single weekend and just use a Ryobi dual air compressor as I have tons of Ryobi batteries (though only 1 it's needed for fil all 4 tires) and it's extremely precise, you can also set it to the exact pressure you want and leave it to trend to your vehicle inspections post offroading and it'll shut off on its own. The only issue, it can take about 7 minutes per tire to go from 20psi to 35psi but I personally never care as I'm easily entertained.
    ThePlumber and dclbYak like this.
  20. Jan 21, 2020 at 10:41 AM
    #40
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Puma is popular with the LC crowd.
