Air Condition always running?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mxer256, Dec 15, 2012.
  1. Dec 17, 2012 at 7:16 PM
    Madjik_Man
    Colorado Front Range
    My 98 doesn't do that.
    The A/C is only one when I engage it with the button or am using either of the defrost settings.
  2. Dec 17, 2012 at 7:18 PM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    :cheers:
  3. Dec 17, 2012 at 7:41 PM
    david2011sr5
    david2011sr5 Well-Known Member
    take a guess
    MA/VT
    2011 SR5 4x4
    afe pro dry, weather tech floor liners,5100's on all four corners@ 0, eibach 620 coils. toytec 3/4" spacer driver/s & passenger/s, rear spring tsb w/toytec 1" blocks, 4runner sport wheels, in channel vent visors, 1.25 spidertrax wheel spacers on the front, Wet Okole's, smity tow hook.
    Yea since day 1
    Yea... That's what I have to do.
  4. Dec 17, 2012 at 7:45 PM
    david2011sr5
    take a guess
    MA/VT
    2011 SR5 4x4
    Ahh. +1 for you sir.
  5. Dec 17, 2012 at 8:29 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    :cheers:
  6. Jan 16, 2013 at 7:37 PM
    Sky King
    Sky King Well-Known Member
    Sam
    Memphis, Tn
    07 PreRunner SR5
    Serious sound deadening in the cab and extensive audio system.
    The A/C compressor will cycle anytime the fan switch is in any setting except "off". You can hear the compressor kick in and the engine will load up in response. It doesn't matter what the outside temp is. If the fan is on, the compressor will run no regardless of the A/C switch being off.
  7. Jan 16, 2013 at 9:10 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    The AC compressor will operate only if the system is set to AC or to Defrost.
    If it is cold outside, pressures could run outside of design limits and the compressor will shut down to prevent the system from freezing, but it will cycle as pressure normalizes.
  8. Jan 16, 2013 at 10:20 PM
    Wheeler18
    Wheeler18 Member
    Brady
    Torrance ca
    2004 3.4 tacoma dbl cab
    DeckplateMOD,FJ cruiser TRD wheels
    On my 04 I had the same issue, all you need to do is push the little button for the ac that shows the air recycling thru the car and it closes all the vents. The ac dosnt need to be on for this to work.
  9. Jan 17, 2013 at 7:27 AM
    BamaToy1997
    Bill
    Navarre, FL
    I agree with Rich here. The compressor will only operate in AC or Defrost modes.
    As for the OP, others have mentioned all the good points. EVERY vehicle has a small percentage of fresh air allowed in, even when on recirculate mode. This allows fresh air into the car. This amount is different by manufacturer, but is usually around 5-10% fresh air at all times. Why would they do this? Believe it or not, for safety concerns. If your HVAC system were to fail, it will try to put the mode doors into default, which is defrost. Even if it can't go into defrost, a small percentage of fresh air, even if it were cold, would help in trying to keep the windshield clear, which is of course a safety concern.
  10. Jan 17, 2013 at 8:36 AM
    Sky King
    Sam
    Memphis, Tn
    07 PreRunner SR5
    Ok, let me see if I have this straight. With the A/C push button switch "OFF", outside air temp can be below freezing, if the "RECIRC" switch is "ON" OR if the selector is in a "DEFROST" position, the air conditioner compressor CAN or WILL cycle?
  11. Jan 17, 2013 at 9:46 AM
    BamaToy1997
    Bill
    Navarre, FL
    Yes, it can cycle. The AC is used to help dry the air before it warms it. This causes lower humidity inside the vehicle. Also the dry air is the only proper way to clear off a fogged up windshield.
  12. Jan 17, 2013 at 10:22 AM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    it's because recirculate is off. it's let's
    letting outside air into the cabin because air is being forced in by sheer speed. the faster you go to more air will be crammed into the intake vents regardless of fan speed. turn your recirculate on and it SHOULD redirect the incoming air. this is how I deal with it on my 2000 although it's a mechanical system rather then electrical
  13. Jan 17, 2013 at 5:24 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Yup.
    And if it is slightly humid, you'll discover quickly why it is not recommended to use "recirc" when the AC compressor is not running.
  14. Jan 17, 2013 at 5:29 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Also safety for passengers.
    When my dad bought his Vega, one of the features was referred to as "flow through ventilation"... it was simply the addition of vents on the rear of the doors outside of the weather stripping, coupled with the blower running on low speed any time the engine was running.
    Supposedly this was added because occupants of well-sealed vehicles had been killed due to exhaust gas leakage into the cabin.
  15. Jan 18, 2013 at 7:57 AM
    #35
    BamaToy1997
    Bill
    Navarre, FL
    I had thought about that point, but failed to mention it. You are quite correct there Rich!
