Air condition problems
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sideways, Jun 27, 2010.
  1. Jun 27, 2010 at 8:45 AM
    Sideways
    Sideways [OP] Well-Known Member
    Maryland
    05 TRD dbl cab
    Anyone else had issues with there air conditioning system leaking freon?
    This will be the third time I've had to trace a leak and add freon to my 2005 Dbl cab, it's only got 39k on the odometer. :annoyed:
  2. Jun 27, 2010 at 8:49 AM
    MrGuitarguy
    MrGuitarguy Well-Known Member
    Houston, TX
    PreRunner Longbed SR5
    My AC turns on and off between low and medium. But it is an 05, so problems arise about now. meh
  3. Jun 27, 2010 at 8:53 AM
    Brunes
    Brunes abides.
    Rotorhead
    Yeah man- It's 5, almost 6, year old parts at this point....Stuff gets old and leaks.
    Are you finding the the leaks in the same section of the system??
  4. Jun 27, 2010 at 9:01 AM
    Sideways
    Maryland
    05 TRD dbl cab
    No, each time has been a different fitting that had loosened up.
    Yes, I checked them all each time.
  5. Jun 27, 2010 at 9:04 AM
    Brunes
    Brunes abides.
    Rotorhead
    So there are just fittings coming loose?? No actual holes or anything??
  6. Jun 28, 2010 at 4:23 AM
    Sideways
    Maryland
    05 TRD dbl cab
    So far just loose fittings.
    It is definitely a slow leak as it has taken about a month and half between each repair attempt to leak back down.
  7. Jun 28, 2010 at 4:55 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    That is annoying to say the least.
    I think the 5 year-old-parts argument it just bung. I have a 10 year old Maxima and just a few years back traded a 13 year old Rodeo that blew air as cold as brand new. Before that a 10 year old Acura...the electricals were causing problems (mainly intermittent connections), but the A/C blew as cold as ever.
  8. Jun 28, 2010 at 5:19 AM
    buck
    buck Don't sweat the petty - pet the sweaty
    Ontario, Canada
    08 DC V6 4x4 TRD Indigo Ink
    High-flow coconut smiley-face air freshener.
    Mine was leaking at the valve (the one that looks like a tire valve).
    This is the first vehicle I've ever had problems with the A/C. My current car with 265K still blows as cold as it did when it was new.
  9. Jun 28, 2010 at 6:36 AM
    akdisney
    akdisney Well-Known Member
    Alan
    CA
    PreRunner SR5 V6
    Thule 422xt rack w/ XK1 rack adapter, uvw tool chest box, nerfBars
    you may Have slow leak in the compressor
    I have my replace in my old GMC truck and it work cold then when got the truck new.
  10. Jun 28, 2010 at 7:30 AM
    ShadowFalken
    ShadowFalken Well-Known Member
    Jim
    Maryland
    10 Off Road
    Raptor stainless bars, Wet Okole covers, RollBak bed cover, PopNLock, Redline hood struts, XM radio factory kit
    How are you tracing the leaks?
  11. Jun 28, 2010 at 9:31 AM
    buck
    Ontario, Canada
    A/C dye & UV light.
  12. Jun 28, 2010 at 10:55 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    sucks but..... wouldn't it be wise to just go through the entire system and tighten everything down instead of waiting for the next leak to arise, that way you're good for some time? Just a thought...
  13. Jun 28, 2010 at 6:00 PM
    Sideways
    Maryland
    05 TRD dbl cab
    Not much on the age thing either.
    Both times we went thru the entire system and tightened everything possible.
    Schrader valves seem to be fine.
    Dumped some more dye into the system yesterday and going to drive it around a couple of days, maybe something else will show up.
  14. Jun 29, 2010 at 7:25 AM
    ShadowFalken
    Jim
    Maryland
    10 Off Road
    Just an FYI. I have worked on vehicles where the dye did not work. What was happening was that the leak was in an area with little to no oil flow so the dye would not come out. These leaks were typically on the low side of the system in the evaporator area. When running, the pressure is low. When you shut them off and park them in the sun, the pressure goes up and the leak gets more intense. Picking it up with a GOOD quality sniffer works in those cases.
    Just a thought.
  15. Jun 30, 2010 at 6:37 PM
    Sideways
    Maryland
    05 TRD dbl cab
    Well it turns out the condenser has a slight leak.
    Showed just a spot of dye on the left side where the tube goes into the tank (for lack of better wording)
    Since this is the 2nd truck my wife and I bought from Toyota as well as the 2010 Prius we picked up last week I decided to take the truck to them and see what they would do even though it is out of warranty.
    You would not believe what they said and did! :D
    The wife and I are customers for life!
  16. Jun 30, 2010 at 6:40 PM
    chich2000
    chich2000 Well-Known Member
    AK
    Tacoma 4WD TDR
    care to share what exactly they said and did?
  17. Jun 30, 2010 at 6:47 PM
    FreeHeel
    FreeHeel Not Dead But Definitely Dying
    Rambler
    2006 Reg Cab 4x4
    I had to replace my AC clutch and compressor at 39K so you are not alone. The root of the problem is that the newer Tacomas have a crappy Delphi AC system not the tried and true Denso parts that originally earned Toyota it's reputation for reliability.
  18. Jun 30, 2010 at 7:22 PM
    Sideways
    Maryland
    05 TRD dbl cab
    They called it "good will" and warrantied the condenser.
