Air Condition/Recirculation buttons do not work
Discussion in '2nd Gen. Tacomas (2005-2015)' started by trtripoli, Jun 23, 2016.
  1. Jun 23, 2016 at 5:09 PM
    trtripoli
    trtripoli [OP] lower management
    Denver, CO
    07 4,0 L, 6M, Dbl Cab, TRD Off Road
    Eclipse AVN6620 JL 500/1 amp JL 13TW5 sub JL 300/4 JL XR-650CSi Mr Marv Box Blu tooth XM radio Back Up camera, RAAMmat and Ensolite everywhere but ceiling
    Back story. My AC died, the compressor seized up, I replaced all the components myself. The AC hasn't worked correctly since. I say hasn't worked correctly because the button won't operate the AC, but I can bypass the magnetic clutch (jump power) and it works. I know the magnetic clutch works, because I can operate it with wires and operate the AC by putting power to the side that's asking for it. The re circulation button doesn't work at all either. The fan, temperature controller and the hvac position knob work correctly. I replaced the unit with a brand new figuring that was the problem. The buttons light up when I push them, but don't actually turn the ac on or operate the re-circulation function.
    Any one have any ideas on what could be wrong or how to diagnose them?
    -Ted
  2. Jun 23, 2016 at 6:23 PM
    Roadapple
    Roadapple New Member
    Southern Maine
    2015 V6 SR5 Barcelona Red
    Falken Wildpeaks, TRD skid plate
  3. Jun 23, 2016 at 6:36 PM
    trtripoli
    Denver, CO
    I'm pretty sure I've pulled and checked everyone at this point. Not ones in the cab, but not sure which one it would be at this point.
  4. Jun 23, 2016 at 6:47 PM
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    Id check the relay. I had to replace the clutch relay on a Lexus ES300. Was doing pretty much the same thing, except the light on the button would flash.
  5. Jun 23, 2016 at 6:55 PM
    trtripoli
    Denver, CO
    I was able to force the relay to fire with wires and touching the battery terminals. I can run the ac with wires through the relay this way.
  6. Jun 23, 2016 at 7:10 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Did you check the recirc doors to see if they actually don't operate? You can see them by pulling the glove box down, the doors are located directly over the cabin filter housing... it's just 2 butterfly doors.
  7. Jun 23, 2016 at 7:28 PM
    trtripoli
    Denver, CO
    Well it wasn't, then I plugged it in and it worked. Opps. The a.c.still doesn't though. Any ideas?
  8. Jun 24, 2016 at 6:33 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Are you sure you have the correct pressure in the AC Coolant. There is a pressure switch that will prevent operation if the pressure is low.
  9. Jun 24, 2016 at 6:35 AM
    trtripoli
    Denver, CO
    I had it checked and leak tested about a month ago. The repair shop couldn't figure out what was wrong and didn't end of charging me anything because of that. They left scratching their head. I'm bringing it to the Toyota dealer next week if I can't figure it out.
