Air Conditioner/Compresser problems?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TilTheWheelsFallOff, Aug 12, 2017.
  1. Aug 12, 2017 at 6:11 PM
    TilTheWheelsFallOff
    TilTheWheelsFallOff [OP] Well-Known Member
    Josh
    Southern Indiana
    13 MG DCSB TX
    Loading...Loading...Loading...
    I have a 2013 TX TRD 4wd, and recently I was sitting at a drive thru window at a pharmacy on 106 degree day, when all of a sudden a terrible smell overwhelmed the cab and the cold air quit blowing, I pulled over checked everything out, could find nothing wrong, left the air off for a few minutes and when I turned it back on the air came out cold as ice again, it seems to have been working fine since then...fast forward to sometime mid week last week when I have begin to notice a rattling sound at idle and it's been getting increasingly louder, now coupled with a sound I could only describe as sort of a hiss/screech (intermittent, noticeable mostly at low speeds and idle) type...truck seems to be running just fine, AC is still working just fine, just wondering if anyone with a 2nd gen had experienced anything like this with theirs, Thank you
  2. Aug 12, 2017 at 6:17 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Possible bearing on one of the pulleys.
  3. Aug 13, 2017 at 11:04 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    My '15 Tacoma 4.0L with just 25K on the clock recently received new belt - belt tensioner & the 2 idler pulleys closest to alt/ac compressor. Warranty work. My situation was different than yours, but there was "noise" that wasn't there before.
    I see a lot of these types of posts here.
    If it's happening to a 2+ yr. old truck with 25K, who knows how many other older trucks are experiencing this sort of thing.
  4. Aug 13, 2017 at 3:58 PM
    TilTheWheelsFallOff
    Josh
    Southern Indiana
    13 MG DCSB TX
    Well today it blew the 10a IG1 No2 its going in for service this week, it's a 13 and only has 40k miles
  5. Aug 14, 2017 at 1:00 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    IG1 No2 Fuse supplies these loads:
    I wish you the best of luck.
    ABS (w/ VSC), TRAC, VSC, Auto LSD, Downhill Assist Control and
    Hill–Start Assist Control
    ABS (w/o VSC)
    Accessory Meter
    Air Conditioning
    Automatic Glare–Resistant EC Mirror
    Charging
    Cruise Control (1GR–FE)
    Cruise Control (2TR–FE)
    Door Lock Control
    Electronically Controlled Transmission and A/T Indicator (1GR–FE)
    Electronically Controlled Transmission and A/T Indicator (2TR–FE)
    Engine Control (1GR–FE)
    Engine Control (2TR–FE)
    Headlight
    Illumination
    Interior Light
    Light Auto Turn Off System
    Multi Mode 4WD and Rear Differential Lock
    Power Outlet (115V)
    Power Window
    Rear Differential Lock (2WD)
    Shift Lock
    Starting
    Stop Light
    Tire Pressure Warning System
    Trailer Towing
    Wireless Door Lock Control
  6. Aug 14, 2017 at 2:35 AM
    TilTheWheelsFallOff
    Josh
    Southern Indiana
    13 MG DCSB TX
    I'm gonna guess AC, I think that's the noise I've been hearing
  7. Aug 14, 2017 at 2:47 AM
    Halena Molokai
    Halena Molokai Well-Known Member
    Black 2016 TRD DCSB OR 4x4 MT6
    BFG KO2 265/70/17 Moto Metal 17x 9 -12mm ToyTec Boss 2.0 lift Kit Wet Okole, Ceramic tint 35% Bakflip F1 Flowmaster Exhaust Single in /Dual out with 3"stainless tips DashMat Covercraft Custom windshield shade Tilt Alarm Weatherbeater Mats Diode Dynamic LED upgrade to interior OEM Bed Mat OEM 5" Chrome Side Steps
    It's your clutch on the compressor. There's a rubber coupling that's worn but not broken leaving the AC to still work. Check where the pulley is and see if there's any black rubber particles. This just happened to my son's 2005 Prerunner. $.02 Good luck
    jboudreaux1965 likes this.
  8. Aug 14, 2017 at 2:50 AM
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    The terrible smell.......if the smell was burnt rubber it sounds like it would be the serpentine belt, but you'll have to figure out the cause. Could been dragged over a bad pulley, or even smaller chance, the tensioner gave out momentarily and the crankshaft pulley was burning up the belt, or the rubber in the AC clutch burned a little or the compressor froze and burned the belt. As was suggested already, I would give your belt a good inspection, if it looks good I would seriously start looking at the AC compressor clutch.
    I had to change out the tensioner on mine at 45000mi on mine, it was rattling for a while and was getting worse. And no, it wasn't the bearing, I pulled everything off the front of the engine and checked all the bearings and pulleys to make sure. Changing out the tensioner is a pain in the ass, especially with shock tower gussets. And prior to that I had a serpentine belt give out at 40k and took out the main crankshaft shaft oil seal.
  9. Aug 14, 2017 at 4:09 AM
    TilTheWheelsFallOff
    Josh
    Southern Indiana
    13 MG DCSB TX
    That sounds terrible, but that sounds exactly like what I'm experiencing, because there is also a mysterious rattle, almost like a "knocking" but I figured something is also overloading a circuit somewhere thus the blown fuse...thank you guys
  10. Aug 15, 2017 at 6:22 PM
    TilTheWheelsFallOff
    Josh
    Southern Indiana
    13 MG DCSB TX
    Well got it in to the dealership yesterday and sure enough it was the AC compresser clutch assembly, good as new today! Thanks everyone :bananadance:
    Split|Circuit likes this.
