Air conditioner compressor when using defrost
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Volt, Oct 5, 2019.
  1. Oct 5, 2019 at 9:27 AM
    Volt
    Volt [OP] Well-Known Member
    Overland Park, Kansas
    2022 SR5 4x4 Double Cab V6
    My fourth red Tacoma
    I would like to be able to not activate the air conditioner compressor when using the defrost. Has anyone figured out a way to manually control the activation of the air conditioner compressor when using the defrost? Does anyone know if the air conditioner compressor is or is not activated when the blend knob is set in between floor and defrost?
  2. Oct 5, 2019 at 9:31 AM
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    Push the AC button and it shuts off. You get faster/better defrost with it on.
    GreyBaldTaco and Boghog1 like this.
  3. Oct 5, 2019 at 9:34 AM
    TacoMamba35
    TacoMamba35 Well-Known Member
    PNW
    2021 Tacoma TRD OR DCSB 3.5
    Pretty much every make and model uses the air conditioning compressor intermittently for defrost. It acts as a dehumidifier. You're better off letting it operate as designed.
    Comb, Anchovy, WARPED5 and 3 others like this.
  4. Oct 5, 2019 at 9:46 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Any time you do anything HVAC the compressor is turned on. The reason? Two fold..
    1. So the compressor seals won't dry out in the winter months where it gets cold.
    2. During defrost, the AC will pull moisture out of the air and speed up defrost.
    Modern vehicles have a complex system. Much more than a compressor turning on and off when you want cold air.
    Boghog1 and Drainbung like this.
  5. Oct 5, 2019 at 9:55 AM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    over60 and hiPSI[QUOTED] like this.
  6. Oct 5, 2019 at 10:14 AM
    WARPED5
    WARPED5 Well-Known Member
    Ted
    NW IN
    2017 Blue TRD OR
    ... and some folks don't realize that it's DRY that does the job, not so much warm air.
    Good reply, BTW!
  7. Oct 5, 2019 at 10:17 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    WARPED5 likes this.
