Air Conditioner Dial: Either Full-Blast or Off
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Raymondo17, Sep 4, 2019.
  1. Sep 4, 2019 at 4:15 PM
    Raymondo17
    Raymondo17 [OP] Well-Known Member
    Ray
    Sacramento
    '06 PreRunner
    I'm having kind of an odd issue with my '06 Tacoma's air conditioning: It's either full-blast or off. When I turn the dial to any of the less intense settings, it stays at full-blast until I get down to the totally-off setting. Granted, this is much better than not working at all, but now I'm either freezing or broiling. Any clue as to what the scoop is?
    tato187carlos likes this.
  2. Sep 4, 2019 at 6:23 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    So it blows HIGH Speed on ALL settings?
    Usually the problem is that it Blows on High Speed only. No other settings will work.
    In that case it is usually the blower resistor.
    If it blows high on all speed, I believe something is by-passing the resistor.
    As on High speed the resistor is not used.
    Maybe @Muddinfun can help us?
    12TRDTacoma, TireFire and Muddinfun like this.
  3. Sep 4, 2019 at 7:57 PM
    Raymondo17
    Ray
    Sacramento
    '06 PreRunner
    Either the issue changed or I got it wrong initially. Now it only blows on High. Otherwise it’s off.
    Is this something a willing novice can fix or should I put a call into my mechanic?
  4. Sep 4, 2019 at 8:03 PM
    Bishop84
    Bishop84 Well-Known Member
    Blower motor resistor.
    Its easy to change, but often the connector is burnt as well and requires a new pigtail.
    Google Tacoma Blower Motor Resistor for more info.,
  5. Sep 4, 2019 at 8:05 PM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    COMMON ISSUE. i HAVE REPAIRED IT 5 TIMES
    12TRDTacoma and Skyway like this.
  6. Sep 4, 2019 at 8:07 PM
    TnShooter
    Deogee
    STOCK
  7. Sep 4, 2019 at 8:50 PM
    Raymondo17
    Ray
    Sacramento
    '06 PreRunner
  8. Sep 4, 2019 at 9:54 PM
    Raymondo17
    Ray
    Sacramento
    '06 PreRunner
    One more thing... the repair video calls for crimp connectors. A quick visit to Amazon shows a bewildering selection of them. Can anyone suggest a good quality set of crimp connectors. I'd probably cheap out on something like this and regret it later, so if anyone has recommendations... One of the videos I watched recommended nylon insulation, but what do I know?
  9. Sep 5, 2019 at 12:17 AM
    TnShooter
    Deogee
    STOCK
    If you ordered the kit in the link you posted above from Amazon, it looks like it comes with connector.
    They look to be Nylon to me?
  10. Sep 5, 2019 at 6:32 AM
    Raymondo17
    Ray
    Sacramento
    '06 PreRunner
    Lol. How in the heck did I miss that?
    Thanks. What a fantastic forum this is.
    pudge151, Skyway and REDdawn6 like this.
  11. Sep 5, 2019 at 7:09 AM
    fathomblue
    fathomblue I used to be disgusted; now I'm just amused.
    Richard
    Eastern Kansas
    Cavalry Blue 2019 DCSB SR5 4x4
    Those crimp connectors pictured in the Amazon ad have heat shrink tube over the insulation. Personally, in a high current draw situation like this I would prefer to solder the connection rather than use crimp connectors.
    FastEddy59 and Skyway like this.
  12. Sep 5, 2019 at 10:56 AM
    chiefO
    chiefO Well-Known Member
    Fresno, CA
    2005 Tacoma 4x4 Double Cab SB
    Im having the problem with that blows at high speed only. How were you saying I should fix it?
  13. Sep 5, 2019 at 4:07 PM
    Raymondo17
    Ray
    Sacramento
    '06 PreRunner
    In late breaking news... after researching how to fix it and purchasing the necessary replacement parts, the fan seems to be working normally today. What the...
    I'm guessing it's a matter of time before it gives up the ghost entirely, but... weird.
    pudge151 likes this.
  14. Sep 5, 2019 at 4:15 PM
    Acabsurf
    Acabsurf Well-Known Member
    Alex
    San antonio, Tx
    2015 silver SR5 4x4
    Fabfour vengeance front bumper, XD series wheels. Leveling kit.
    I can co firm. Blower resistor, thats how mine was. Luckily the dealership replaced that part.
  15. Sep 5, 2019 at 4:51 PM
    TnShooter
    Deogee
    STOCK
    Take a look at the link in post #6 above.
  16. Sep 5, 2019 at 5:34 PM
    TacomaJack099
    TacomaJack099 Well-Known Member
    Jack
    Orlando Florida
    Blue 2007 Tacoma 2.7 / 5 speed AC 4x4
    usually, you can wiggle the wires and harness (passengers foot well, above the carpet edge in front of the passengers left foot) and that will clean the burnt connection enough to last a few days till you get the replacement. I wiggled mine two or three times over a few months and managed to delay the part change till it was super hot and humid, just so I could sweat off a few bags of Cheetos...
  17. Sep 5, 2019 at 6:27 PM
    skeighter
    skeighter Well-Known Member
    Buy the parts. It's gonna go eventually and you'll need them.
    Had the same thing happen to me. Then it went. I cleaned the connections up and it went for a while. Eventually it died at the wrong time (not on the coast in southern california where it's cool but in the Mojave desert). Did a fix job in less than thirty minutes during my first camping stop in Tahoe, back in business. Cost me a bit more because I couldn't Amazon on the road. Had to O'Reilly.
  18. Sep 5, 2019 at 7:22 PM
    doityerself
    doityerself Well-Known Member
    The Deep South
    2006 SR5 DCLB 4x4
    Not Enough and it continues...
    Yep, this one is common. I changed the resistor some while back...I forget. Lol. A few days ago it was only blowing on high. A couple of hours later its working on all speeds again. Sounds like time for a new connector.
  19. Sep 7, 2019 at 8:09 PM
    Raymondo17
    Ray
    Sacramento
    '06 PreRunner
    Ok, so did the install of the new parts. Now I have two speeds instead of one. Soooo, close but no cigar. My guess is my first foray into using crimping butt connectors was where I went wrong. So I'm guessing tomorrow I'll try disconnecting the wires and try again.
  20. Sep 7, 2019 at 8:23 PM
    TnShooter
    Deogee
    STOCK
    What are the speed that work?
