Air conditioner fail
Discussion in '3rd Gen. Tacomas (2016-2023)' started by LPTaco, Jun 9, 2023.
  1. Sep 18, 2024 at 12:04 PM
    dmq400
    dmq400 Member
    Dan
    tacoma 2's
    so my 2019 stopped working as well. Compressor turns like it should when I switch the AC on but light goes off and compressor switches off within 5 seconds. I understand that to be low 1234yf. The refill canisters sold do not include the pressure gauge like the earlier refrigerant recharge kits. Do you think its save to just hook it up and dump the whole canister in it? Of course the instructions say DO NOT OVERFILL
  2. Sep 19, 2024 at 5:00 AM
    Nirango kid
    Nirango kid Well-Known Member
    Gilles
    Ontario
    2021 Tacoma TRD Sport Premium in Barcelona Red
    My AC is on Auto 24/7 and I regulate the temps with the temperature knob and works fine. Cool and warm when needed.
  3. Sep 19, 2024 at 9:03 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    It becomes a trade-off between doing that and having your gas mileage drop significantly, plus more wear causing the shorter overall lifespan of the compressor. It’s definitely more economical to just use it when you need it but if you’re not worried about that then cool.
  4. Sep 19, 2024 at 9:24 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    To be honest with you, I dont think low level is the reason yours turns on then off a few seconds later.
    Low level seems to show as cold on drivers side and not cold on passenger side.
    But a fault in the AC compressor will give you what your getting. Go look at the ground wire on your ac compressor clutch, its right there on the top of the clutch and grounds right there to the body of the compressor. The wire they used is not well protected and is just bare copper. Mine turned green and fuzzy at 23k miles and caused the same issue you have. Replacement ac compressor under warranty fixed it, but I think you can replace just the clutch too.
    OnHartung'sRoad likes this.
  5. Jun 12, 2025 at 8:52 AM
    FishTaco143
    FishTaco143 New Member
    Jasper
    2008 Silver Tacoma DCSB
    Hi all, reviving this thread. I have a 2021 TRD Sport with only 43k miles...and the A/C is not working. Last week I when I was casually driving on the road I heard a loud squeal and the A/C hasn't worked since. When I turn the A/C button on the light comes on for about 5 seconds and then turns off. I opened the hood and tried turning the A/C on and getting a look -- the clutch spins for about 5 seconds then turns off. Soooo ... I suspect a seized compressor. :(
    This truck has way too low of miles to have this EXTREMELY expensive failure. What gives? Could it be something else?
  6. Jun 12, 2025 at 1:22 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Same here, mine went out after 5 years, and that's all I needed too. 3 years later and still running great!
