air conditioner only blows on high
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 07tacomapreerunner, Aug 23, 2021.
  1. Aug 23, 2021 at 9:18 AM
    07tacomapreerunner
    07tacomapreerunner [OP] Well-Known Member
    tacoma
    Good morning.
    My air conditioner has always worked perfectly until yesterday. Settings 1-3 blow barely any air with no change being made between flipping the switch to the higher power. When I put the air on full blast it works perfect. It doesn't make a difference wether its just the outside air or A/C. Any suggestions on how to fix this or what the problem could be? thanks!!
    2007 tacoma double cab, 4x4, trd sport
  2. Aug 23, 2021 at 9:23 AM
    CajunCubsFan
    CajunCubsFan Well-Known Member
    Scott
    NE Texas
    White 2015 Tacoma TRD 4x4
    3" lift OME Nitrocharger 16" SCS Ray 10's Utility cap AL Offroad Roof rack Prototype SSO Tacoma Rock Sliders
    Do a web search, there are literally hundreds of posts about this. Replace the blower and the module connector thing and you're good to go.
  3. Aug 23, 2021 at 10:45 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    It is the blower motor resistor.
    Check the connection on it and the blower motor for signs of melting or over heating. If so, replace the connector too.
    It is a common occurrence with these truck. Nothing to get too worried about.
    It happens, it can be fixed relatively cheap. And all is good to go:thumbsup:
    mysubiewasalemon and dTed like this.
  4. Aug 23, 2021 at 4:38 PM
    dTed
    dTed Well-Known Member
    2013 DCLB SR5 4x4 MGM
    x2.
    Replace the blower motor resistor.
    TnShooter[QUOTED] likes this.
  5. Aug 24, 2021 at 6:20 AM
    miketyler
    miketyler Well-Known Member
    Agrred with TnShooter Mine did this and was only the connector. Easy fix and even easier to test. Simply select one of the non-working speeds and reach down under the glove box and wiggle the connector to see if the fan comes on. I'd bet many just jump right into replacing motor or resistor when all they need to do is clean and slightly crimp the female contacts.
  6. Aug 24, 2021 at 7:14 AM
    Horhey232
    Horhey232 Well-Known Member
    2013 Toyota Tacoma
    Does anybody know if there is a better fix? I am about to replace the resistor for the second time in roughly a year. Now this may have been my buddy's fault as he was in the passenger seat and stretched his legs out and the blower went from the medium setting to high with out touching the nob. I jiggled it and it fixed itself for a month or two and now it works only on high so I guess it is time to change the resistor.
  7. Aug 24, 2021 at 7:32 AM
    miketyler
    Did you try the connector again? I had to crimp the female connections on the plug to permanently fix mine. When I say "crimp" I mean take a tiny screwdriver or pick and insert in the plug and slightly bend to shrink the opening of the connector.
  8. Aug 24, 2021 at 12:52 PM
    TnShooter
    Deogee
    STOCK
  9. Aug 24, 2021 at 2:50 PM
    Killowatt
    Killowatt Well-Known Member
    Citrus County Florida
    2013 4x4 TRD OFF ROAD
    You can also unplug the resistor, and replace, about 10 times. Cleans the contact points a bit, I've done mine twice in the last 4 months. Parts ready, but it still runs.
