Air conditioner question...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JPinCowtown, May 14, 2009.
  1. May 14, 2009 at 6:04 AM
    JPinCowtown
    JPinCowtown [OP] Well-Known Member
    Texas
    09' SR5 4x4
    I've had my 09 about a month so I'm still figuring a few things out. For example anytime I turn the fan on, even on it's lowest setting the AC comes on automatically. Pushing the AC button does not turn it off - if the fan is on, the AC stays on. The manual says you can run the fan without the AC which would just blow "unconditoned" outside air through the vents but my truck doesn't want to do it. Any suggestions?
  2. May 14, 2009 at 6:08 AM
    JeffRock
    JeffRock Well-Known Member
    Capital region, NY
    09 Tacoma accesscab 4x4 SR5 2.7L
    Toyota all weather floor mats. Mag light that clunks around in the jack compartment. Dog hair. Dog drool on the windows.
    if you turn the temperature knob all the way cool, the ac, And recirculate automatically comes on. there is a slight, very slight click in the knob before this happens. try this. turn the temp control up, turn opn the fan. make sure ac, and max/recirc are off. then tunr the temp knob all the way cool. you will see what I mean.
  3. May 14, 2009 at 10:25 AM
    dw77x
    dw77x Those are not my pants
    SE Wisconsin
    2009 Tacoma Sport LB
    5100's all 4 corners (front at 2.5"), rear tsb springs with 1.5" AAL, 265/70/17 General Grabber AT2's
    I do that all the time by mistake. . .there should be a much stiffer detent there.
  4. May 14, 2009 at 10:37 AM
    JPinCowtown
    Texas
    09' SR5 4x4
    Thanks - I've never noticed the click - I'll give that a try.
  5. May 14, 2009 at 10:39 AM
    A_Ninja_Racer
    A_Ninja_Racer Well-Known Member
    Tampa, FL
    08 PreRunner TRD Debadged
    that just sounds Crazy:eek:
  6. May 14, 2009 at 10:51 AM
    javajunk-e
    javajunk-e Well-Known Member
    So. Cal
    '09, Super White, DCLB, 4x4, Sport.
    Tacoma all weather floor mats, N-Fab Prerunner light bar w/ Hella 500ff lights, mag-lite mod, Hi-lift jack, Wet Okole seat covers, Revenge Fab sliders, ARE MX shell with Thule racks, and a Bed Rug.
    What he said!!!
  7. May 14, 2009 at 11:17 AM
    papabear050
    papabear050 Well-Known Member
    11 dc 4x4 TRD OR Auto
    If you read the knob it should say, MAX AC at the bottom of the temperature range on the blue side.
    So if you turn it to MAX AC, the AC will kick on. Just turn it a notch above that and you should be able to turn on or off the AC at will.
  8. May 14, 2009 at 11:22 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I've never noticed this. I'll have to give it a shot.
  9. May 14, 2009 at 11:38 AM
    Cap
    Cap Active Member
    Montgomery County, PA
    09 Prerunner SR5
    Took me a while to get used to that as well. Definitely different than my prior taco.
  10. May 14, 2009 at 11:51 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Thats weird. My 07 isnt like that. I have to actually push the AC button to turn it on.
