Air conditioner recirc
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MyTacoma2023, Aug 16, 2023.
  1. Aug 16, 2023 at 6:45 PM
    MyTacoma2023
    MyTacoma2023 [OP] Member
    Rich
    2023 TRD Sport
    Hello all,
    I wanted to run an annoyance by you regarding my 2023 TRD Sport. Every time i start the truck the AC starts in recirculation mode regardless of the mode i left it in the last time i drove.
    Is there a way to stop the recirc default? As i mentioned it's just an annoyance and i set it to non recirc.
    Thanks
  2. Aug 16, 2023 at 6:48 PM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Is the AC in AUTO?
  3. Aug 16, 2023 at 6:50 PM
    Bishop84
    Bishop84 Well-Known Member
    AC is way more efficient and effective in recirc.
    I dont know how to stop it from switching.
    Same goes for defrost in the opposite. Fresh only.
  4. Aug 16, 2023 at 6:52 PM
    DNguyen1033
    DNguyen1033 Well-Known Member
    Nguyen
    Southern California
    07 OR | 21 OR 4X4
    Following…
    @MyTacoma2023 , same here, I’m trying to do this for my 2017 sienna as well.
    @faawrenchbndr , not auto, just a set temp.
  5. Aug 16, 2023 at 6:53 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome to TW…
  6. Aug 16, 2023 at 7:00 PM
    MyTacoma2023
    Rich
    2023 TRD Sport
    Thanks all. I checked and i am not using Auto on the climate control.
    I guess it could be designed that way, not sure as to the efficiency thought, but rarely used recirc in my vehicles unless it was very hot out
  7. Aug 16, 2023 at 7:03 PM
    Azrael's Gaze
    Azrael's Gaze Well-Known Member
    Steve-O
    Springfield, Oregon
    2022 Black Tacoma TRD Offroad
    Most new vehicles auto turn on recirc when the ac is turned on. Its easier to keep colder air cool than it is to cool warmer outside air.
    Murd3rd, PoolFixer, SmoothTRD and 4 others like this.
  8. Aug 16, 2023 at 7:09 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    It’s going to choose recirc pretty much all the time whether in auto or not. In auto it will switch to fresh air occasionally, I believe with it’s below 70F or something like that outside. The conditions are listed in the owner’s manual.
    personally, I just use auto and choose the temp I like. Simple and works well.
    musicisevil and Chew like this.
  9. Aug 16, 2023 at 7:13 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Recirc is more efficient since the ac is not having to cool outside air continuously.
    PoolFixer, SmoothTRD and Chew like this.
  10. Aug 16, 2023 at 7:30 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    also better mileage using recirculation…
    TacoPacific likes this.
  11. Aug 16, 2023 at 10:22 PM
    tiap
    tiap Active Member
    Do you leave the windows open at home with the A/C on?
    Another advantage with recirc is to cut down the poor exhaust fumes such as diesel fumes.:thumbsup:
    PoolFixer, doublethebass and Chew like this.
  12. Aug 16, 2023 at 10:41 PM
    betrayus
    betrayus Milk steak connoisseur
    Denver, CO
    2021 SR5 DCSB 4x4 AT (MGM)
    Stock
    https://www.youtube.com/watch?v=xb0fDfzV41I
    Nice video about the topic. I started to get AC stink occasionally, I only run recirc for the first 5 mins or so, then turn it off. My smells have subsided over the last few weeks.
    Okkine 2.0 and LeakyAC like this.
  13. Aug 17, 2023 at 3:38 AM
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    this is interesting. I turn my AC off before I turn the truck off. When I restart the truck, it does not automatically turn the air-conditioning on. When I restart mine it comes on in vent
  14. Aug 17, 2023 at 3:39 AM
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    The greater efficiency also comes from the lessened humidity.
    PoolFixer likes this.
  15. Aug 17, 2023 at 5:47 AM
    Gfenza89
    Gfenza89 Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    Prepare yourself for water dripping on the passenger floor liner if you’re using fresh air mode for extended periods of time.
    bigsmirt and LeakyAC like this.
  16. Aug 17, 2023 at 7:50 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    one thing a mechanic told me at the dealership was to make sure recirculate was on before turning the truck off. He said it shuts a flap that allows mice to get into the system.
    CB350G, Tacoma Mike and TRDRed like this.
  17. Aug 17, 2023 at 8:12 AM
    DNguyen1033
    Nguyen
    Southern California
    07 OR | 21 OR 4X4
    I think I got this, yesterday I was playing around with the AC and everytime I restart the car it would turn on recirculation. This morning I play with it again and it did not. I play around with the temperature setting and find out that if the outside temperature is higher then the set temperature, recirculate will be on automatically & you need to turn it off manually. I know it’s more efficiency, but to me I don’t care about it. It’s just a bit annoying that’s all.
    TRDRed likes this.
  18. Aug 17, 2023 at 8:18 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    General rule is that if the outside is warmer than you want the inside, recirculation is best.
    TRDRed, Chew, SmoothTRD and 1 other person like this.
  19. Aug 17, 2023 at 8:39 AM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    Set it and forget it. Adjust the temp to where you want it and let the truck do the rest.
    The auto setting is smarter than most owners as this forum has taught me. The sheer number of people who live in hot/humid states and don’t understand the correlation between a/c and recirc (or use a/c with the windows down) is bonkers
  20. Aug 17, 2023 at 8:42 AM
    BLtheP
    Plano, TX
    Indeed. It’s also funny how many folks have auto and don’t even use it or maybe don’t understand it. I get in so many cars with others and the auto light is off and they’re constantly fidgeting with the fan speed and moving the temp back and forth the entire drive. It drives me nuts and I want to inform them but I don’t want to insult them in case they do know how to use and just choose not to.
    Then of course you have those who think they know it all and immediately turn off AC when they switch to some form of heating mode so they can get hotter air, while fogging up their windows and wondering why.
    Jesse H, Chew and musicisevil[QUOTED] like this.
