Air Conditioner Smells!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TryingTacoma, Sep 20, 2011.
  1. Sep 20, 2011 at 3:30 PM
    TryingTacoma
    TryingTacoma [OP] Member
    Canada
    2010 AccessCab 4X2 2.7L 4cyl Auto
    Engine Hour-Meter, Fumoto Oil Change Valve, Rear RideRite Helper Air Springs and Left/Right Pressure Guages.
    The A/C on my 2010 Tacoma smells badly this spring. I assume moisture has remained trapped somewhere and is causing the mouldy smell. Anyone know how to get rid of the smell and how to avoid it in future?
    Thanks
  2. Sep 20, 2011 at 3:31 PM
    inesshell
    inesshell blah blah blah
    john
    Oregon
    Superwhite 10' AC
  3. Sep 20, 2011 at 3:31 PM
    Tigahshark
    Tigahshark Senior NEWBIE
    Isaac
    On a volcano, literally!
    2011 DC TRD off road 4X4
    Tint Weathertech floor liner, weathertech window visor Roll n lock tonneau cover Rubber bed mat Smoked license plate covers
    Take it back to the dealer or at least ask them why
  4. Sep 20, 2011 at 3:33 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Where do you park your truck, outside? I know a guy that had dead mice somewhere under his dash and it made his A/C stink.
  5. Sep 20, 2011 at 3:34 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner
    Stuff
    I would like to know also. Wife Mazda STINKS
  6. Sep 20, 2011 at 3:34 PM
    hogeyphenogey
    hogeyphenogey Rotted frame = New Truck!
    Dave
    Chicopee, MA
    2015 TRD Off Road Crew Cab
    new truck... No mods yet!
    When you turn off your vehicle, open the vents to the outside air and any condensation that forms will evaporate out instead of staying in the ducts. That will cause a moldy smell. Also, change your cabin filter. Then, you can buy aerosol "bombs" and get rid of the smell in your car. Try an auto part store.
  7. Sep 20, 2011 at 3:42 PM
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    Try changing the cabin filter; this is usually where the small comes from. Some people change theirs once a year to avoid the smell and maximize air flow. Some people never change it and when they run the AC/Heat it smalls like dirty socks.
    If it still smells after you change the filter, try taking a shower or mask the stank by loading up on cheap cologne. I recommend Drakkar.
    Best of luck to you TW member and happy trails.
  8. Sep 20, 2011 at 7:19 PM
    myname150
    myname150 Well-Known Member
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/106490-diy-get-rid-c-stink.html
    I've also learned that since then, don't leave the air vent open when you're going to park your truck, keep it on recirculating.
    Oh and this only seems to work for like a week or so. After that it comes back, but not as badly.
    If anyone has a more permanent solution, please share! I've also considered using one of these to clean the inside but just haven't gotten around to doing it yet:
    I got the idea from here
    http://www.youtube.com/watch?v=dNMAmhGrxR8&feature=sh_e_se&list=SL
  9. Sep 20, 2011 at 7:27 PM
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Selkirk, NY
    4x4 reg cab, 5 speed
    Better tires Hurcules Terra Track, trimmed front mud flaps, (access limited tonneau-took off) softopper, ats running boards, Piaa fogs, window vents, Wireless thermometer, extra bed rings, valley hitch
    The book says make sure recirculate vent is open when you park.
    Extra step is make sure you turn off ac a few miles before you park to give it time to dry out.
    I don't use the recirulate vent unless some stink is getting in. One oddity to the 2011 ac is that it goes to recirculate when you put ac on.
  10. Sep 20, 2011 at 7:36 PM
    saugus
    saugus Well-Known Member
    Fram cabin filter at walmart has baking soda and what looks like charcoal. The haines book shows some air freshener being sprayed on the cf as well. Maybe that fabreeze will work.
  11. Sep 20, 2011 at 7:36 PM
    Snowman11
    Snowman11 Supreme Ruler
    Snow
    Near Philly
    2011 DCLB TuRD Sport
    5100 Billies
    Not really, only when you turn it all the way to cold. Leave it turned up just a notch and it won't do that. So if you mess up and turn it all the way to cold, you have to turn it back and un-puch the re-circ button.
    IMO this is absolutely retarded that Toyota would do something like this.
  12. Sep 20, 2011 at 7:38 PM
    Snowman11
    Snow
    Near Philly
    5100 Billies
    Also if your truck smells like mildew, there is something wrong. The dealer should fix it. There's no reason a 1 year old truck should be doing that, I don't care how often you leave it on re-circ.
  13. Sep 20, 2011 at 7:39 PM
    Snowman11
    Snow
    Near Philly
    5100 Billies
    Is that a Miata? They are known for that, I had water leaking on the floor on mine and it stunk. Was an easy fix... got rid of it.
    Actually there is a drain hose that got clogged regularly in the cow that you have to un-clog to fix that.
  14. Oct 8, 2011 at 5:06 PM
    btacoma
    btacoma Well-Known Member
    Roger
    texas
    05 prerunner DC v6 4.0L
    hankook tires pioneer avh-p4300 headunit
    im having the same problem, it smells like something died in my ac. my truck doesnt have a cabin filter but it has a slot for one. im gona buy one and hope it works, if not i need some help on how to look into the ac. the smell comes and goes so i dont know what it is.
  15. Oct 8, 2011 at 5:45 PM
    jtice
    jtice Well-Known Member
    West Virginia
    2011 TRD Off-Road
    Pioneer P4100DVD, 10" Pioneer Shallow Mount Sub
    I have a 2011 and it STINKS like glue or something.
    Its really bad if I have the AC off, and the recirculation. on, I have no idea what it is but it drives me nuts.
    Maybe its an adhesive in the system somewhere?
  16. Oct 9, 2011 at 3:29 PM
    Snowman11
    Snow
    Near Philly
    5100 Billies
    Haha why on earth would you have it on recirc without the ac on unless you are boxing in some gas... that just fogs up the window. Ok maybe if you are going thru a tunnel and you don't want to breath in exhaust. Even so, my AC is on 90% of the time even the winter. Just push the button. It removes moisture from the vents and keeps it from stinking.
  17. Oct 9, 2011 at 3:42 PM
    jtice
    West Virginia
    2011 TRD Off-Road
    well most the time I dont, but lets say I have the recirc and AV on, I will turn off the AC for a bit once its cold enough, and just let it recirc the cabs cold air, then if it gets warm again I will turn the ac back on.
    I try to keep it off as much as possible, save gas. :/
  18. Oct 9, 2011 at 9:02 PM
    mac360
    mac360 Well-Known Member
    Long Beach, Ca
    2017 Tacoma OR DC LB
    I have the same problem.. It goes away after a few seconds on high. Not sure how to fix the problem. I have a 2010.
  19. Oct 10, 2011 at 1:28 AM
    Rellik01
    Rellik01 Well-Known Member
    Craig
    Windermere, Florida
    2012 TRD Sport 4x4 White
    Bull Guard powder coated white, chrome aftermarket tail lights,Led interior lights, Factory roof rack, Bug deflector, Factory tow package, Garmin GPS, Viper 5901 alarm with auto start, Weather tech window wind deflectors, , 3" Tube steps powder coated white, CB Radio, Radio Scanner.
    x2 on the Fram Febreeze cabin air filter.
  20. Nov 7, 2011 at 11:11 AM
    mk7
    mk7 Active Member
    Michael
    Austin, TX
    '11 4x4 TRD Off Road
    I have the same issue. Sometimes when I first start the trunk there is a strange chemical smell from the AC, it goes away after a minute or so. I'm not sure if this only happens when the re-circulation is left on, I will try turning off the re-circulation before I stop.
