Air conditioning blowing unconditioned air
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RedWiscoTacoma, Sep 5, 2022.
  1. Sep 5, 2022 at 1:57 PM
    RedWiscoTacoma
    RedWiscoTacoma [OP] Member
    2006 Tacoma 4 by 4 manual
    None
    2 days ago the air conditioning worked fine. The car has been parked since and today warm air. The button lights work, the fan works, the engine loads up (rpm decreases)when when I turn it on.
    I went to the store this am and didn’t use the A/C. For the second trip of the day the truck was completely dead. I did some poking around and found the ground cable loose from the battery.
    after reconnecting and driving some is when I discovered the A/C problem.
    could this electrical be related to the grounding terminal coming loose?
    I checked the 7.5a fuse in the cab and the 50a under the hood. They seem good.
    previously, when my A/C has failed it’s become gradually ineffective or the compressor went in a dramatic, noisy fashion.
    Sudden coolent leak? thoughts?
  2. Sep 5, 2022 at 3:36 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    It sounds like the system works it just is not cooling. Most like!y a leak. Get the system checked for refrigerant fill. Step 1.
    TnShooter likes this.
  3. Sep 5, 2022 at 3:41 PM
    RedWiscoTacoma
    None
  4. Sep 5, 2022 at 4:11 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Did the mag clutch short to ground and drain the battery?
  5. Sep 5, 2022 at 9:30 PM
    RedWiscoTacoma
    None
    I don’t think so. I found the ground cable loose on the battery. I fixed that but wondered if it could of cause an A/C problem since the A/C was working right before this.
  6. Sep 5, 2022 at 9:32 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Is the compressor clutch engaging when you turn on the A/C?
  7. Sep 5, 2022 at 9:45 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    It’ll start working again soon is my bet. Each time my battery is disconnected, it takes the AC system about 20 minutes to start blowing cold air. This is typical for Tacomas, very common quirk
    mray and whatstcp like this.
  8. Sep 6, 2022 at 4:06 PM
    RedWiscoTacoma
    None
    Yes, the compressor engages and disengages with the switch.
    I’ll have to keep trying it I guess.
  9. Sep 6, 2022 at 4:17 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    If the compressor is engaging see if the suction line is getting cold, if it is you have a blend door problem if it isn't you need to put service gauges on it and see what your pressures are.
    b_r_o likes this.
  10. Sep 6, 2022 at 4:25 PM
    TireFire
    Olympic Peninsula
    See my post above. Do you know why this could be happening? I’m not sure what kind of information the AC system could be losing after battery reset vs say rough idle, which would be expected
  11. Sep 6, 2022 at 5:09 PM
    RedWiscoTacoma
    None
    I just ran the vehicle and tried the A/C. It’s still not working and turning on the A/C no longer draws down the engine rpm.
    I hunted around for the suction line. There are 2 metal lines coming out of the fire wall on the right side, neither is cold. The slightly smaller one might be less warm than the bigger one. There’s another similar line that comes up just inboard of the battery and this one is not cold either.
    I have an appointment next week. Lucky for me no heat waves in Wisconsin next week. 8 hours of driving with the windows down just like the old days. :)
  12. Sep 6, 2022 at 5:13 PM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    When my condenser sprung a leak my AC worked one day and didn't the next day (after the refrigerant had leaked out). I'm guessing a rock or something got kicked up and punched a hole in the condenser.
    Similar to the issue you described, everything electronically appeared to work - AC lights came on, fan blew, blend door moved with adjustments, compressor clutch engaging and disengaging with the switch, just no cold air.
  13. Sep 6, 2022 at 5:21 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Yea the larger line should be cold when the system is operating properly, since it's not you have a refrigeration issue.
    Do not continue to operate it as you could damage your compressor, you may want to pull the MG CLT relay until you can have it diagnosed to prevent it from running.
  14. Sep 6, 2022 at 5:25 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Are you sure it isn't low on charge?
    I've never seen an A/C issue happen after a battery disconnect, some vehicles lose their actuator calibration and run a recalibration after a battery disconnect but that only takes a couple minutes at most.
    TnShooter and 6 gearT444E like this.
  15. Sep 6, 2022 at 5:36 PM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    Huh, never noticed that on my 2010. Only thing that happens to mine when the battery is disconnected is that on first start it starts and dies right away. Then its all good.
    6 gearT444E and Dm93 like this.
  16. Sep 6, 2022 at 6:40 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    As I stated in Post # 2. Get the pressures checked. It finally leaked out to where the pressure switch is stopping the Magnetic Clutch from engaging.
    TreeFortRichard and TnShooter like this.
  17. Sep 6, 2022 at 11:29 PM
    TireFire
    Olympic Peninsula
    All I’m sure of is what I described, and that there is no obvious leak. I haven’t been bothered enough to rent the gauges to check. Owned the truck (2007) for nearly 10 years and it’s always done this after each battery disconnect. Once I changed my dead battery in Montana, and drove all the way back to San Diego. Didn’t need AC until I got into SoCal. Turned it on, and it blew warm air. Left it on, and after maybe 30 minutes it got cold. Blew cold reliably until the next time the battery was disconnected, and then the cycle repeats itself.
