Air Conditioning Clutch failed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RustyBucket, Jul 8, 2014.
  1. Jul 8, 2014 at 9:03 AM
    RustyBucket
    RustyBucket [OP] Well-Known Member
    2010 4 cyl 2WD Taco with 70,000 KM...
    Last weekend whild rriving down the highway, I hear a whining noise from the engine bay followed by the A/C light blinking and the vents no longer blowing cold air.
    When I got to my destination, I had a look under the hood and it was clear that the air conditioning compressor clutch had failed. The outer steel ring separated from the rubber. When you turn on the air conditioning, you see the clutch try to engage, but it doesn't catch. Thankfully it still freewheels properly so it's not chewing up the serpentine belt.
    No luck getting it addressed under any warranty :(
    In my search for replacement parts, I can't find the clutch pulley anywhere! You can buy a full compressor, but it seems like a waste of parts, time and money to swap the whole compressor when it's just the clutch that's bad. So, I have a few questions:
    - Is the A/C compressor the same on 4 cyl and v6 models?
    - What is the part number/model of the compressor? (I believe it's a Delphi unit)
    - Is there ANYWHERE that I can find the A/C clutch without having to buy the whole compressor?
  2. Jul 8, 2014 at 9:10 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Yeah with out special tools you never get it off. Before you go any order a clutch it might be a good ideal to find out why the clutch quit.
  3. Jul 8, 2014 at 9:41 AM
    RustyBucket
    Every thread I've seen seems to talk about replacing the compressor with a new one.
    I think the reason the clutch quit is pretty simple... I'm not the only one who's had this issue:
    The compressor (and clutch) was made by Delphi, A supplier to GM who, at the time the compressor was manufactured, was going through bankruptcy. I would not be surprised if there were quality control issues there.
    Bloody dealer wants $1300 to replace the compressor. :mad: Nope, not gonna happen.
    Why, Toyota, Why did you have to cheap out and go with Delphi???
    Is there a Denso compressor that's a drop-in replacement?
  4. Jul 8, 2014 at 9:58 AM
    CRU
    CRU Well-Known Member
    Seminole Cnty, FL
    07 SSM TuRD Sport DCLB
    20" Enkei WT4 wrapped in Bridgestone Dueler A/T Revo 3 265/50, Steel braided brake lines, Pioneer AVH-X5500BHS deck w/JBL GTO cones, OEM Smoked headlights, OEM LED tails, Clazzio seat covers, aFe Pro-Dry S air filter, Fumoto oil valve, Grillcraft MX grille w/Land Cruiser "TOYOTA" emblem, Redline QuickLIFT hood struts, Leather TRD shift knob, 13" shorty antenna
    Auto parts stores should have multiple replacement options. Should only run you $300 to $500.
  5. Jul 10, 2014 at 1:02 AM
    Cornman1
    Cornman1 New Member
    You don't need to replace the compressor if the rubber on the clutch separated. You can get an aftermarket clutch kit and slap on the new clutch in 30 minutes. No special tools required and you can do it with the compressor still on the truck. For those of you who have ac lights blinking, look at the front of the compressor to see If the rubber seal is frayed along the edge. If so, it's an easy fix. My 2010 ac compressor clutch went at 65k.
    Here is what I did:
    Unbolt and remove skid plate 12 mm?
    Unhook serpentine belt
    Unbolt fan shroud, tilt it out of the way 10mm
    Unbolt fan and remove 10mm
    Unbolt compressor clutch and remove. 8mm
    Curse at Toyota for their diminishing quality
    Bolt new clutch with air gap (I used .025" with a feeler gauge between clutch and pulley)
    Put back together
    Enjoy cold crisp air for another 60k and repeat.
    Kolter45 likes this.
  6. Jul 10, 2014 at 5:58 AM
    RustyBucket
    :yes:Now That's what I like to hear!
    Do you have a link you could post for this kit you speak of?
  7. Jul 10, 2014 at 6:13 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Your entire HVAC system is Delphi.
  8. Feb 23, 2016 at 10:17 PM
    GARCIAC951
    GARCIAC951 Member
    Carlos
    2021 4x4 Off-road
    So was there ever a link to this clutch kit? Same exact thing has happened to me and I'd rather not replace the whole compressor
  9. Mar 5, 2016 at 4:02 AM
    RustyBucket
    The clutch kits that I could find were about as much as the compressor itself, so I ended up getting the whole compressor replaced.
  10. Mar 5, 2016 at 6:08 AM
    GARCIAC951
    GARCIAC951 Member
    Carlos
    2021 4x4 Off-road
