air conditioning fans squeaking help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 808Raider, Oct 3, 2012.
  1. Oct 3, 2012 at 12:27 AM
    808Raider
    808Raider [OP] Well-Known Member
    HAWAI'I
    '10 PreRunner SR5 AC
    Bilstein 5100s @1.75, AAL TSB, Pro Comp 7089s, 265/75/16 Firestone Destination A/Ts, Debadged, Black Billet Grille, Tinted, Nerf Bars, Mudflaps Removed, AFE Pro Dry-S Air Filter, Secondary Air Filter Removed, Sock Decals,
    for the last 6 months i have this sound from the ac that gets worse and worse when i run it. when the fans turn they squeak like eee eee eee eee eee and its really annoying. has to be from the ac fan blades rotating because the faster it squeaks the higher i run the ac. coming up on 3 yrs on my truck and i think ac isnt covered after that on warranty, am i correct? so wondering if i should take in or is this an easy do it yourself fix? thanks
  2. Oct 3, 2012 at 1:40 AM
    fixer5000
    fixer5000 the logical one
    massachusetts
    11 trd sport longbed
    weathertech visors,remote start,lojack, ARE z type topper, wet okole seat covers, pop n lock tailgate lock
    take it to your dealer before warranty runs out. theyll replace the motor free under a tsb
  3. Oct 3, 2012 at 4:52 AM
    ssault
    ssault Active Member
    Maine
    '11 TRD Sport
    URD short throw
    Get it done before you start hearing that noise in your sleep.
  4. Oct 3, 2012 at 6:47 PM
    GreyTacoNorCal
    GreyTacoNorCal Member
    california
    SRS preRunner
    i Got the same problem... I got to get it fixed!!! Damn #### sound!!!
  5. Oct 3, 2012 at 6:58 PM
    photonashville
    photonashville Well-Known Member
    Nashville, TN
    06 Silver DCLB TRD Sport 4x4
    Basic stuff, Leer 100R, Yakima rack, Billy 5100s
    I assume this sound you speak of is the infamous chirp from the blower motor. There is a NEW replacement blower motor as of 2012. I bought the new one from ebay for $119 with free shipping. Installed in minutes and the cabin is as quiet as can be at any blower speed setting.
  6. Oct 16, 2012 at 12:38 PM
    808Raider
    HAWAI'I
    So I just dropped it off at the stealership and they said they have to charge me 55$ to look at it and then see if its under warranty and then if it is they would take off the charges?! I told them the ac just started squeaking after 2years why would it not be under warranty?! It's only the far right side fan. Like a really high pitch whirring squeak. Anyone know what exact repair I might be looking at or part of the warranty that says this stuff is covered? Thanks
  7. Oct 16, 2012 at 12:52 PM
    WVTacoma08
    WVTacoma08 Well-Known Member
    West Virginia
    '13 TRD Sport
    My '11 had the same chirp. Took to dealership, they didn't even come out to inspect the problem. They are aware of the TSB so I made an appointment, they replaced blower motor under warranty. No questions asked & no chirp now.
  8. Oct 16, 2012 at 1:14 PM
    808Raider
    HAWAI'I
    What is the tsb? Blower motor?
