Air conditioning on the fritz
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nirav2011, Jun 28, 2020.
  1. Jun 28, 2020 at 5:27 PM
    nirav2011
    nirav2011 [OP] Well-Known Member
    2011 Tacoma TRD Sport
    Hi all,
    I have a 2011 TRD Sport Double Cab. My air condition seems to want to take a break every now and then. It’ll work fine for periods of time (nice cold air) then just stop working for a few days/weeks, then start working again.
    Any of you have similar issues? Is there anything I can/should check myself or is this something that requires a trip to a service department? Help/guidance will be greatly appreciated.
    Thanks,
    N
  2. Jun 29, 2020 at 1:56 AM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    It kinda sounds like your ac compressor. But hopefully its not
  3. Jun 29, 2020 at 2:36 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Is the AC Compressor not working or is it just the air blower in the ventilation system not blowing. There is a huge difference.
    From the intermittent failure I would guess that the Blower Connector and Resistor more so than the AC System.
    https://www.tacomaworld.com/threads...pp-tried-it-all-already.667405/#post-23410740
    https://www.tacomaworld.com/threads/ac-stopped-working.666917/#post-23394984
  4. Jun 29, 2020 at 2:44 AM
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    My A/C took a dump this summer. Wouldn't be so bad but my passenger window stopped working too. Gets a bit toasty at times, but I just don't want to spend the money on A/C right now. I'd rather sweat than be broke.
    BillsSR5 likes this.
  5. Jun 30, 2020 at 11:27 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    It's always a choice now isn't it...
  6. Jun 30, 2020 at 11:29 PM
    Texas T
    Texas T Well-Known Member
    TX
    '14 T Force
    $100 to fix the window. Sux about the A/C still
  7. Jul 1, 2020 at 6:17 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    Any flashing AC light?
    claudine19 likes this.
  8. Jul 1, 2020 at 9:05 AM
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    The AC on my 2013 crapped out this spring. There was a pinhole in one of the hoses so all the coolant leaked out. New hose and charge and was good to go!
  9. Jul 2, 2020 at 7:16 PM
    nirav2011
    Thank you all for the responses. I had to get the annual inspection done and while at the service center I had them recharge the coolant $150 but it has dye which will indicate any leaks. They promised me the $150 put toward fixing the leak if one exists.
    For now I have cold air...the wife will be ok with riding in the truck.
  10. Jul 2, 2020 at 8:45 PM
    anndel
    anndel Member
    Mililani, Hawaii
    14 PreRunner TRD Off Road Dbl Cab
    M a/c died last year. Noticed it was getting warmer and oily liquid was coming out of the drain pipe. The it never got cold. Took it to a a/c shop and $2,000 later, it was the the evaporator that was leaking and they said it was common amongst Tacomas. When I went to pick up my truck, another customer just drove in and said his a/c isn't cold anymore.
  11. Jul 3, 2020 at 11:09 AM
    kodiakisland
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    My AC compressor doesn’t kick on. Is there a mechanism to keep that from happening if the coolant is too low, or is it just a compressor problem? The A/C button lights up like normal.
  12. Jul 3, 2020 at 11:18 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    There is also a simple relay that can take a dump. Google it
    12TRDTacoma likes this.
  13. Jul 3, 2020 at 11:31 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Yes, there's a low-pressure sensor which can prevent the clutch engaging if charge is insufficient. I would have thought your system would indicated a fault if that were the case though (blinking light).
  14. Jul 3, 2020 at 11:37 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  15. Jul 3, 2020 at 11:50 AM
    kodiakisland
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    yeah, I thought it would blink if it was the relay or pressure not causing it to kick on. As it is, the light is on like normal but it does not kick on.
  16. Jul 3, 2020 at 11:52 AM
    BillsSR5
    bill
    2014 SR5
  17. Jul 3, 2020 at 1:05 PM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    The AC light will blink only.... if the compressor rpm does not match the engine rpm. OR lol, if the sensor for compressor rpm took a dump.
  18. Jul 3, 2020 at 1:09 PM
    kodiakisland
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    OK. I thought it just blinked it the circuit was not completed.
    But that does confuse me. The compressor didn’t kick on, so I would think the rpm wouldn’t match???
    I think it’s gonna be a hot summer
  19. Jul 3, 2020 at 1:23 PM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Correct, if the compressor didn't kick in, the rpms wouldn't match so blinky light.
    Next step, connect a gauge manifold. Any pressure at all?
  20. Jul 3, 2020 at 1:25 PM
    kodiakisland
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    yeah, but I got a continuous light, which is what I don’t understand.
    I don’t have a pressure gauge, so that will be my next step
