Air Conditioning Problem. Help needed.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by friendlyphil, Aug 8, 2018.
  1. Aug 8, 2018 at 4:32 AM
    friendlyphil
    friendlyphil [OP] Member
    2015 Prerunner Dbl Cab. Barcelona Red. TRD
    Sometimes when the A/C is on max in my 2015 Taco, hot air begins blowing out and I look to see that the A/C button is flashing off and on. When I push the button to turn it off, then turn it back on, the A/C begins working again. This has happened 3 or 4 times in the past few weeks. It happened a few times on my 2005 Taco, when I had it.
    Can someone please tell me what is going on here? Thanks
  2. Aug 8, 2018 at 5:32 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Possibly a bad magnetic clutch a/c relay which is located under the hood fuse box. Look for MG CLT and see if you can swap it for another similar one such as the "towing tail" or horn relay to test the a/c.You could also take that fuse out, curse at it while you gently tap it against the ground , reinstall to see it if that resolves the issue. Go with the 2nd option only if the first option proves that it's a bad relay.
    DukesTaco likes this.
  3. Aug 8, 2018 at 11:03 AM
    friendlyphil
    Thanks, I'll try that.
  4. Aug 9, 2018 at 11:59 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    WTF is tapping a fuse on the ground supposed to do? I've read some funny shit, but that is up there.
    LOL
  5. Aug 9, 2018 at 12:02 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    Can you show us how with a youtube video :frusty:
  6. Aug 9, 2018 at 12:14 PM
    Wattapunk
    Uncle K
    TX
    2005 DCLB 4WD
    LOL! I had the same thing happen to my camry. A/C flashing so I took out the fuse and tapped it against the ground. Reinstalled and it worked. Sometimes the relay may get stuck internally so I figured to try that before driving to buy a new one. Still working 6 mos later. Yeah, that's not covered in the service manual.
  7. Aug 9, 2018 at 12:21 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I could see tapping a stuck relay to loosen the mechanical contacts, but a fuse is just a link of metal ( no moving parts inside ). Trust me the fuse was not your problem.
    LOL
  8. Jun 20, 2019 at 3:20 PM
    Wakecoach
    Wakecoach Kiwi in FL
    Kurt
    2015 White TRD Sport 4x4 2001 Subaru Legacy Wagon Bilstein Touring Edition
    King ext, res/adj...3leaf Aal. ECGS bushing. Bullaculla relocate bracket. Pelfrey bilt skids. TC UCA. K+N, Weathertech Mats, TRD side steps, BROV Tacoma Attic, Prinsu Cabrac, TRD OR Tow Hook
    Hey TW .. 2015 owner here but trying to fix stepsons 2011 Sonata AC problems
    Didn’t want to start a new thread
    Yes I have googled , but don’t seem to find help with current problem
    The air doesn’t come on for a while .. and when I search intermittent problems it’s all talks about things freezing up when it’s on and then it stops
    Sometimes it comes on after 3-5 mins and sometimes it comes on after 30 mins . Sometimes not at all
    When it comes on , it’s cold ..
    I recharged it last fall.
    So it’s works, but not for a while
    Is there some kind of relay problem ?
    Or any other suggestions
    Thanks for any help
  9. Jun 20, 2019 at 9:02 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    How did you recharge it? Did a shop properly recharge it or did you use a suicide can?
  10. Jun 20, 2019 at 9:18 PM
    Gixerkiller
    Gixerkiller TW...what a silly place
    Dennis
    Taylor, TX
    2015 Tacoma Pre Runner DCLB White
    decals, morale patches, headlights, tail lights, toytech lift w 5100s, Falken Wildpeaks.....
    Ahh, the lovely Hyundai/Kia no a/c issue....
    I saw this while working on them, I wish I could help but I was not A/C certified so I was not allowed to touch it.
    I do know that the fuse/main switch unit under the dash does fail on one system only quite regularly. That might be the issue.
    Hade a Forte with a power draw...had to check every terminal and fuse in both engine and cabin boxes, was a constant power on in the cabin.
    You might be experiencing the same. Ended up finding it by pulling the fuses one at a time to see which systems were affected.
    The key was off and out of the lock cylinder yet the cabin fuse block did not shut off.
    Sounds confusing......it was a last resort test.
    Those cars have issues with switches and sensors also. 2011, it might still be under the 10 year 100,000 mile warranty....
    Hope this helps a bit.
  11. Jun 20, 2019 at 9:22 PM
    jong34
    jong34 Member
    Jonathan
    2012 T|X Pro
  12. Jun 21, 2019 at 4:36 AM
    Wakecoach
    Kurt
    With a suicide can haha .. worked better after doing it
  13. Jun 21, 2019 at 4:37 AM
    Wakecoach
    Kurt
    Thanks , I’ll check
    This method out .. it’s hot as balls in Florida ....
  14. Jun 21, 2019 at 5:10 AM
    Taco'09
    Taco'09 Well-Known Member
    I like the ones that have had so much additional oil put in that you think you discovered an oil well :eek:
  15. Jun 21, 2019 at 5:34 AM
    Bebop
    Nick
    Probably part of your problem. You need to start with the basics. Like making sure the system is properly evacuated and recharged with the PROPER amount.
    Wakecoach[QUOTED] likes this.
  16. Jun 21, 2019 at 7:26 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Biggest issue. It’s a HYUNDAI
  17. Jun 21, 2019 at 7:46 AM
    Wakecoach
    Kurt
    Well it’s a hand me down to them from their mother when she bought a 19 RAV4 .. thanks for the helpful advice though
