Air Conditioning taking way longer to cool down
Discussion in 'Arizona' started by bajaracer, Aug 17, 2013.
  1. Aug 17, 2013 at 12:49 PM
    bajaracer
    bajaracer [OP] Well-Known Member
    Charly
    Chandler
    05 PRERUNNER DBLCAB SPORT 4.0
    AEM DRY BRUTE FORCE, FLOWMASTER 50 SERIES, 285/70/17 BFG'S AT KO2'S MOTO METALS 17X8 885's with 5100's LOUD STEREO
    The past couple of weeks ive noticed that the AC on my Taco is taking longer to cool down the cab. Before I would set the setting on high and within a few minutes the air would be freezing cold. But lately the air is coming out "cool" but not cold when set on high. My question is, could it need time for recharging? Ive had 2 other Tacos and never dealt with issue. Do you guys recommend any shop that could do it without charging an arm and leg? I called a local shop and they wanted $190 to do it. Has anyone tried AC Pro, the one announced on tv?....Or any of those r134 cans from Wally World work? PLease chime in, Thanks.
  2. Aug 17, 2013 at 12:59 PM
    GTABurnout
    GTABurnout Well-Known Member
    Tucson AZ
    2012 Tundra Crewmax Rock Warrior TRD SC
    Icons, TRD Supercharger, TRD Exhaust, TRD Intake
    I would take it a place you trust to charge it. Don't waste your time on the do it your self kits.
  3. Aug 17, 2013 at 3:53 PM
    bajaracer
    Charly
    Chandler
    Does anyone have any recommendations where to go?
  4. Aug 17, 2013 at 4:23 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    $190 is not expensive.
    If the system needs a recharge, that means it is leaking. The leak needs to be repaired.
  5. Aug 17, 2013 at 5:30 PM
    bueller
    bueller Well-Known Member
    AZ
    This is correct.
    Technically, it's illegal for a shop to recharge your system without first fixing the leak. Refrigerant does not wear out. If it isn't cooling, the refrigerant leaked out or something else is wrong.
    Whatever you do, DO NOT use any refrigerant with a leak stop in it. It'll cost you BIG if you have to have your system repaired in the future, trust me.
    And I used to work in an auto AC repair shop.
  6. Aug 17, 2013 at 5:55 PM
    bajaracer
    Charly
    Chandler
    Do you recommend any shops?
  7. Aug 17, 2013 at 5:57 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    All Town Auto Repair
    2542 W. Broadway #11
    480-967-6606
    Its right next to Sierra Expeditions, so you can go drool over cool off road stuff while they fix your truck. Its on the east side of the 101, north side of Broadway.
  8. Aug 17, 2013 at 6:20 PM
    bueller
    AZ
    The shop I worked at is Arizona Mobile Air. The unfortunate thing is the owner is the worst person I've ever met, a horrible human being. The upside is that the lead tech (Jack) is probably one of the best AC mechanics in Arizona. If you can get past dealing with the owner (you may get lucky and be there on a good day), then they do good work. Closest cross streets are 35th ave and Indian School.
  9. Aug 17, 2013 at 9:39 PM
    tensecondchevelle
    tensecondchevelle Well-Known Member
    Eric
    Mesa Arizona
    2006 Tacoma Double Cab
    I had almost the same problem on my Tacoma. I did AC PRO on my 06 tacoma, my girlfriends Sentra, and her little brothers 03 Tacoma and it worked awesome for all three of us!
    I would recommend it. If you spend $30 and it doesn't fix it owell, if you spend $30 and it works you just saved $150 because you didn't have to go to a shop....
  10. Aug 18, 2013 at 12:49 AM
    Rich91710
    Rich
    Los Angeles
    08 Base
    And when it doesn't work, you've just destroyed your system.
    If you have a small leak in a line at the condensor, when a shop opens the system to perform the repair, the system sealant in the DIY kit will foul the compressor.
    It will also really piss off the tech because he will not be able to recycle and reuse the R134a that he pulled from your system.
    Half of the shit sold at auto parts stores is only useful for used car salesmen trying to get problems to move off of their lot.
    That goes for any "stop leak" product and any oil additive. Fuel additives are for the most part harmless, but they are also pretty much ineffective with very few exceptions.
  11. Aug 18, 2013 at 7:47 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    This ^^^^^
    Shops can pull a vacuum on the system, and see if its leaking. Afterwards, they can properly fill it, so as to keep ambient air out of the system.
  12. Aug 10, 2015 at 4:08 AM
    chayydtayloor
    chayydtayloor New Member
    Chayyd
    2005 Honda Civic
    Make sure to hire some professional contractor or Air Condition repair professional for better service
    Regards
    Air Conditioning Repair Phoenix Company
  13. Aug 10, 2015 at 4:49 AM
    Clearwater Bill
    Billy
    Largo Florida
    You realize you just posted to a thread that has been inactive for 2 years, right?
    Not a great way to start advertising your business........ by not showing attention to detail
  14. Aug 10, 2015 at 6:05 AM
    ccent
    ccent 2006
    San Antonio , Texas
    2006 TRD Off Road
    Bumper guard
    I had similar problem. I replaced the cabin air filter & now my ac is very cold.
