Air conditioning won't work on high setting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by srender23, Jul 30, 2018.
  1. Jul 30, 2018 at 9:47 AM
    srender23
    srender23 [OP] Active Member
    2006 Black Toyota Tacoma Access Cab (Base model)
    2006 Toyota Tacome base model w/ extended cab. I replaced the resistor two times thinking that was it. Does anyone know if this is commonly the motor that needs replacing now or a circuit board or something? thx.
    Scott
  2. Jul 30, 2018 at 2:21 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Check the plug that goes to the resistor connection and the white plug that goes to the motor? If they have burn marks you need to replace the connector plugs.
    Part number 90980-10916 Connector
    Part Number 82998-12380 Wire and terminal
    Not sold as a kit, sold as each. So you will need one of the plugs and two of the terminal and wires.
    Connector:
    Terminals:
    You may also have a burned resistor connector and may need these:
    Plug Number 82141-04M40
    Resistor Number 87138-04052
    Markcal and mach1man001 like this.
  3. Jul 31, 2018 at 4:01 AM
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Great post!!!
