Air conditioning won't work when in 4HI?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ardrummer292, Jun 24, 2020.
  1. Jun 24, 2020 at 10:23 PM
    ardrummer292
    ardrummer292 [OP] 500k or bust
    Austin
    ESVA
    2015 DCLB V6 A/T 4x4, 2011 Camry LE
    Overbuilt daily driver
    I've got a bit of an oddball issue. I was doing my monthly drive in 4HI (as directed by the owner's manual) and had the AC going. Once 4WD engaged, the amber AC indicator started blinking and the air coming out of the vents got noticeably warmer. Not hot, just not as cold as it was when in 2WD. When I switched from 4WD back to 2WD, AC function resumed as normal.
    Is this to be expected, or is it something I should bring to the dealership's attention? I bought my truck in certified condition, so I'm still covered by the 12 month bumper-to-bumper warranty.
  2. Jun 24, 2020 at 11:06 PM
    Marc70
    Marc70 Well-Known Member
    Marc70
    Northern Ontario
    2012 TRD Sport 4.0L, 6MT
    2” lift, ARB front bumper, steel rear bumper, Trail Gear weld-on sliders, aFe cai, 2lo kit, air bag suspension, RA Motorsports AL skid plates
    Still covered? Yes, let them know. Make sure they'll fix it, cause they'll have no problem taking your money to fix anything in the future.
    ardrummer292[OP] and QMEDJoe like this.
  3. Jun 24, 2020 at 11:12 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Is this the case every time you shift into 4Hi? Or was this a one time thing?
    The two systems are not linked together so one should not have any effect on the other.
  4. Jun 24, 2020 at 11:13 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    No it's not normal and it sort of sounds like your AC compressor is failing, the compressor RPM pick up sensor is bad, or your relay is sticking.
    Your dealer should have more info on this when you take it in.
  5. Jun 24, 2020 at 11:40 PM
    Burica
    Burica Raptor Deracinator
    Texas
    I read your post, so I decided to go test this on my truck as I have just bought this truck new Jan 31st. Started the truck. Put the AC on. Put it in 4HI. AC was fine. Took it out of 4HI and drove down the road with the AC on and put it back in 4HI. No problems. Continued to drive down the road switching it in and out of 4HI with the AC on. No problems.
    Hope this test helps.
  6. Jun 25, 2020 at 6:33 AM
    ardrummer292
    Austin
    ESVA
    I'm going to test it again today. If the issue isn't repeatable in cooler weather, that would be good to know. It's around 80 degrees today, versus 95 degrees when I noticed the issue.
    Thanks for the pointers.
    That does help, thank you.
    My concern here isn't a loss of functionality, since I rarely use the AC in the first place. I'm more worried about this issue being a sign of impending parts failure. I'll be sure to update this thread with the results of my test later today.
    Burica[QUOTED], SR-71A and DG92071 like this.
  7. Jun 25, 2020 at 6:19 PM
    ardrummer292
    Austin
    ESVA
    So I tried to replicate the issue today. I was (thankfully?) unable to do so. The ambient temperature was 82 degrees at the time of the test, which is lower than when I first noticed the issue (95 degrees). Does anyone have any idea what might be causing this to happen?
  8. Jun 25, 2020 at 6:24 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Imo. It was coincidence. I’d keep trying to duplicate not in 4hi.
    Gunshot-6A likes this.
  9. Jun 25, 2020 at 6:31 PM
    ardrummer292
    Austin
    ESVA
    Yeah, that sounds like a plan. July is gonna be here soon, so 100+ degree days will be plentiful. That should make testing easy.
  10. Jun 25, 2020 at 6:31 PM
    Bishop84
    Bishop84 Well-Known Member
    The 4x4 system is actually separate from all else, it's very low tech and 100% did not affect the air conditioning.
    Jimmyh likes this.
  11. Jun 25, 2020 at 6:38 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    It wouldn't hurt to check your cab air filter. Restricted airflow through the evaporator can cause way more A/C issues than 4wd. :)
    SR-71A, Gunshot-6A and Jimmyh like this.
  12. Jun 25, 2020 at 6:45 PM
    ardrummer292
    Austin
    ESVA
    I'd bet that the high ambient temperature caused the issue. I'll be doing more testing as summer weather starts in earnest.
    The cabin air filter has only been installed since December, or 9000 miles. That said, I'll take a look to make sure nothing is blocking it.
    landphil[QUOTED] and SR-71A like this.
  13. Jun 25, 2020 at 8:32 PM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    If so, you need to make sure your radiator and condenser are clean, and that your fan clutch is working properly.
    Jimmyh likes this.
  14. Jun 25, 2020 at 9:42 PM
    ardrummer292
    Austin
    ESVA
    You think that's covered under the bumper-to-bumper warranty?
  15. Jun 26, 2020 at 5:56 AM
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    I doubt the cleaning is, but the clutch should be.
  16. Jun 26, 2020 at 8:34 AM
    Plucky was his name
    Plucky was his name Well-Known Member
    Carl
    Central East Texas
    2007 Reg Cab Taco 4x4 5-speed manual
    ARB Front Bumper, Wet Oakle Seat Covers, Aftermarket Stereo, OME suspension with Heavy Duty Dakar Leaf Springs
    I just did a quick search for any related A/C issues, and found this. Perhaps it may be helpful. It’s an old thread, but after reading through most of the posting seems like a known issue with some 2nd Gens. And if it is fuse related at least it’s easy and quick to check/remedy. Here it is:
    https://www.tacomaworld.com/threads/a-c-light-blinking.107982/
    ardrummer292[OP] likes this.
  17. Jun 26, 2020 at 8:53 AM
    ardrummer292
    Austin
    ESVA
  18. Jun 26, 2020 at 9:03 AM
    Plucky was his name
    Carl
    Central East Texas
    Yes, Sir!
