Air Conditioning?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Oat, Sep 24, 2011.
  1. Sep 24, 2011 at 6:25 PM
    Oat
    Oat [OP] Well-Known Member
    Florida
    2001 Prerunner
    Gibson Exhaust, Painted factory steel wheels, Chrome wheel caps, K&N Air intake, Tint, Regular Bilstein (yellow/blue) all around, Leveling spacer kit upfront, Partially de-badged, Westin Bullbar with skidplate, White, Double Cab Prerunner SR5
    On my 2001 D/C the ac is starting to not have as much pressure as it had before. The air is cold but i find myself turning it up higher to actually get it to me, whats the worse case replacing the compressor?
  2. Sep 24, 2011 at 6:29 PM
    davestaco
    davestaco TW's number one gear whore
    David
    Schofield Barracks
    00' tacoma xtra cab trd v6 4x4
    pretty much...compressors are the most common things to go. Is it making anykind of noise? when my compressor went it sounded like a wild banshee....i ended up just taking the belt off and living with out ac
  3. Sep 28, 2011 at 9:50 AM
    ao6902
    ao6902 Well-Known Member
    Arya
    Fayetteville, Georgia
    01 Std cab taco 2.4
    Underdrive crankshaft pulley, k and n filter, dynomax muffler, spectre intake, doug thorley headers
    How hot is it outside? On hot days, ur its not going to be as cold inside. You say pressure is lower? What are the guage readings on the high and low side?
  4. Sep 28, 2011 at 11:02 AM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    Sounds like lack of airflow problem.
    If your supply air is still relatively cold as it always has been but you were getting better airflow towards you out the vents, but now your not...then it's an airflow problem.
    Check your blower motor? It might be going out?
    It could be time for an AC service though. I noticed you live in Florida, I'd have the system pulled into vac, then re charged.
    Your compressor will start making funny noises when it's going out..on automotive compressors at least. Usually 95% of the time how it works.
    Got any leaks you know of?
  5. Sep 28, 2011 at 11:17 AM
    bicklebok
    bicklebok Well-Known Member
    Ronnie
    Montgomery, AL
    2000 Xtra Cab 4x4 SR5
    If it's blowing cold it's not the compressor. Buy a little thermometor and place it in the vent so you can see what temp it blows. I leave one in my vent all the time.
    As mentioned, the fan motor would be the culprit of not blowing enough air from the vent.
